openHASP: An MQTT driven Touchscreen / Scene controller
Hi folks! Quick question. In the documentation about ESP32-2432S028, it says that the firmware can be flashed using https://nightly.openhasp.com/, but I can’t see the device name on the list. Am I missing something?
If i see correct driver is ili9341, so i’d try any of that firmwares. One of them will fit…
User Areakode, in Discord, explained that it is under Sunton. Just leaving here in case someone is looking for this in the future
Yes it is sunton
Hello all,
I use a Display with openHASP 0.7.0. I use it with openHAB. It works great. But I can’t make it to push a image to it. I have a Image in a item of the openHAB with following Infos:
{"link":"http://192.168.2.222:8080/rest/items/Weather_OWM_ConditionIcon","state":"data:image/png;base64,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\u003d\u003d","stateDescription":{"pattern":"%s","readOnly":true,"options":[]},"editable":false,"type":"Image","name":"Weather_OWM_ConditionIcon","label":"Icon","tags":[],"groupNames":[]}
I think this is a RAW or BIN format, isn’i it?
Is it possible to push this Imag to openHASP over mqtt?
If yes, which topic and payload do I have to use for example the object p5B100?
Thanks a lot, Bye
Hi folks! I am having this error on openHASP:
But the device looks as connected on mosquito-mqtt.
Any ideas how can I fix it?
Do you have an entry for it in configuration.yaml?
No, how should that entry look like?
Like it says in the docs
openhasp:
  plate1:
I have added it to configuration.yaml, but I still have the same error :frowning:
I did experience this, and am slightly struggling to recall exactly what I did to fix it. Maybe I also needed to add an objects line, like
openhasp:
  plate1:
    objects:
Plus there was some rigmarole around restarting various things. Try restarting HA, then rebooting the plate, or it may have been the other way round.
Sorry, I know I should make notes…
Great work! I am working on something similar albeit EU size.
  1. Could you share your schematic on how you used the GPIOs to trigger the relays - perhaps mosfit/transistor?
  2. Could you please share the json code for your plate?
    Thanks in advance!
Hi lads
Can someone explain to me how can I use mdi icons other than which is included in the firmware? I’m missing the old window opened/closed icons which are in HA. The mdi.ttf file is already uploaded to the root of the device (which I think is a bit too big), but I don’t know how to use them, and I didn’t find any explanation other than that they can be used. Thanks in advance.
I don’t get the image send to my plate.
In HA I tried this with the developertools
This is my code
action: openhasp.push_image
obj: p1b2
width: 128
height: 128
image: /config/www/passat.jpg
entity_id: openhasp.plategarage
in the mqqt i see following
https://xxx.xxx.org:8123/api/openhasp/serve/31e3201888e4d9d03c9e5b3a92592117
So something is send, but the plate does not show anything
i replaced my real site with xxx.
when I try to open this in a browser then I also don’t see any image.
Can you help me with this please
Yaml please.
Hi everyone and a Happy New Year.
Not sure if this is the right place to ask but…
I have a Panlee ZX3D95CE01S-TR-4848 480x480 touch display which works great with the openhasp binary I was able to find online and have designed a super weather station for it together with HA.
I have also managed to create my own custom image as I wanted to display an analogue clock with a seconds hand.
The display hardware also has an SHT20 built in and when flashed with the standard image the temperature and humidity is published in MQTT.
However this is missing from the source code on Github and my question is can someone help me with how to code this sensor into my custom code to restore this function.
I am not aware of any code in openhasp to support temperature sensors, but you can add custom code. See here openHASP: An MQTT driven Touchscreen / Scene controller - #164 by fvanroie
Edit: the link in that post doesn’t seem to work for me so see Custom Code - openHASP
Yeah, that’s one of the reasons i “took the plunge” and learned esphome for these LCD’s… i came to a brick wall pretty quickly with openasp. I’ll quote myself not so long ago, when i thought differently:
but the problem hit me practically immediately:
So, perhaps this is the time when you decide the same… ?
I have a lot of esphome devices so I will see if I can incorporate it. Which config did you use in esphome?
Maybe you have a sample yaml you could share.
Dear friends! Is it possible to change the size of the slider knob? I want to make a wide slider, but the knob increases with it. It’s getting huge. I wish the knob to be like a narrow strip.
