My first attempt of customizing Lanbon switch panel and two WT32-SC01 Plus with openhasp.
4 pages.
First page is quick setting scenes and quick look at indoor outdoor temperatures and what pellet stove pellets level , heat settings and cooler is set at.
Heating boost and antiboost
2nd page.
Living room area lights
3rd page.
Weather
4th page
Living room media players control with Spotify and album cover in background of what is playing.
Page jasonl layout code
I will post changed and improvements on my gethub.
Gethub repo
Added a human presence detector
HI-LINK LD2410 to end of hall SC01 plus.
It’s close to my HA so HA integration with blue tooth works fine. Just used the cable with connectors that came with the SC01 plus and grabbed power from the plate.
So now I have automation to turn on screen when motion is less than 2 feet from it for over 1 second.
And shut off screen when the sensor has no occupancy detected.
As a test I also have aniburn run if no occupancy in the room for 60 min at night.
Home assistant Automations
Some of my Automations to go along with Wall\Desk Panels.
Text box on Homeassistant dashboard.
Using Helpers I added a Text box to put on HA dash board So I can easily display a pop up message on All dash boards. The automation then deletes the Message box when Text box is cleared.
First Create A text box using Yaml or Helpers and add to a Dashboard.
Automation:
This automation will use the “text” from the text box and Publish to all my panel and turn on the back light to all panels.
In the payload_template you will see
{"page":0,"id":75,"obj":"msgbox","bg_color":"white","text_color":"Red","text":"
{{ states("input_text.ha_panel_popup_text_box") }}
","options":["Close"]}
,Page"0"` is all pages and “id”:75 is the ID of the Message box so if you have other message boxes give them another ID so the will not be overwritten or cleared by this automation.
In the last part of the automation will Delete the message box (popup) when the Text box is empty
- condition: state
entity_id: input_text.ha_panel_popup_text_box
state: ""
- service: mqtt.publish
topic: hasp/plates/command/p0b75.delete
FULL AUTOMATION
alias: Openhasp POPup text box
description: >-
display popup on all openhasp panels the Dashboard text box data. Clear popup
if text box is Empty or cleared. popupID#75
- platform: state
entity_id:
- input_text.ha_panel_popup_text_box
enabled: true
condition: []
topic: hasp/plates/command/jsonl
payload_template: >-
{{ states("input_text.ha_panel_popup_text_box") }} ","options":["Close"]}
- type: turn_on
device_id: 88b53314416b4ce885e73c349b11de1b
entity_id: light.desk1_backlight
domain: light
brightness_pct: 100
- type: turn_on
device_id: ff2aa76f6ac729f1e9e243fa22ce23e1
entity_id: light.plate35_backlight
domain: light
brightness_pct: 100
- type: turn_on
device_id: e8173c788aa326e57adbc645b2d954c8
entity_id: light.desk_backlight
domain: light
- condition: state
state: ""
mode: single
Automation to automatically Clear Text box in Homeassistant when someone Closes message box popup.
alias: clear popup box
description: >-
Deletes Message box when "Close" is selected on any Openhasp Panel message
box.
- platform: mqtt
topic: hasp/desk1/state/p0b75
payload: "{\"event\":\"up\",\"val\":0,\"text\":\"Close\"}"
- platform: mqtt
topic: hasp/desk/state/p0b75
- platform: mqtt
topic: hasp/plate35/state/p0b75
condition: []
- service: input_text.set_value
value: ""
mode: single
More Message box animation here.
