Yes, same as you, I don’t have anything, even the uptime, CPU Load, …
Will try to read myself into the code and see what i can find…any idea where the debug logs are stored?
Soo, I found the log files and it appears that it gets all the data it needs and that the two syncworker threats return values and don’t throw any errors.
Right now it looks on first glimpse as a parsing issue on addon site here in hass.
Will keep looking
Ok, the workaround with disable smart in the addon config works.
Does anyone here have a downloaded diagnostics file from a pre shaitan setup that works with smart?
Would like to see what actually changed in the data the gets returned to eventually update the parser which is probably finding something odd and jumps into error uncaught.
Cause the shaitan data def includs drive and smart data but is triggers a problem.
Looking forward to more info
So, Em I the only one, where it still works? (Except the long time ago reported issue with CPU load).
All SMART entities are working just fine. HAOS 11.1 and OMV 6.9.8-1 (Shaitan)
So it is an issue affecting only some config, i guess.
Interesting.
Could/would u post your diagnostics file from the integration?
Would like to see if there are any major differences
I have 8 drives in my nas for example
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2023.11.3",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.11.6",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/Amsterdam",
"os_name": "Linux",
"os_version": "6.1.59",
"supervisor": "2023.11.6",
"host_os": "Home Assistant OS 11.1",
"docker_version": "24.0.6",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"spook": {
"version": "1.3.2",
"requirements": []
"sonoff": {
"version": "3.5.3",
"requirements": [
"pycryptodome>=3.6.6"
"anniversaries": {
"version": "5.2.0",
"requirements": [
"python-dateutil>=2.8.1",
"integrationhelper>=0.2.2",
"voluptuous>=0.12.1"
"p2000": {
"version": "1.0.23",
"requirements": [
"feedparser"
"neerslag": {
"version": "2022.07.07.1",
"requirements": []
"thermal_comfort": {
"version": "2.1.1",
"requirements": []
"spook_inverse": {
"version": "1.3.2",
"requirements": []
"garmin_connect": {
"version": "0.2.17",
"requirements": [
"garminconnect==0.2.3",
"tzlocal"
"openmediavault": {
"version": "0.0.0",
"requirements": []
"hacs": {
"version": "1.33.0",
"requirements": [
"aiogithubapi>=22.10.1"
"watchman": {
"version": "0.5.1",
"requirements": [
"prettytable==3.0.0"
"smartthinq_sensors": {
"version": "0.35.5",
"requirements": [
"pycountry>=20.7.3",
"xmltodict>=0.12.0",
"charset_normalizer>=2.0.0"
"smart_thermostat": {
"version": "v0.1.0",
"requirements": [
"simple-pid==1.0.1"
"integration_manifest": {
"domain": "openmediavault",
"name": "OpenMediaVault",
"codeowners": [
"@tomaae"
"config_flow": true,
"dependencies": [],
"documentation": "https://github.com/tomaae/homeassistant-openmediavault",
"iot_class": "local_polling",
"issue_tracker": "https://github.com/tomaae/homeassistant-openmediavault/issues",
"requirements": [],
"version": "0.0.0",
"is_built_in": false
"data": {
"entry": {
"data": {
"name": "OMV",
"host": "192.168.188.65",
"username": "**REDACTED**",
"password": "**REDACTED**",
"ssl": false,
"verify_ssl": true
"options": {
"scan_interval": 60,
"smart_disable": false
"data": {
"hwinfo": {
"hostname": "shitdumper.local",
"version": "6.9.8-1 (Shaitan)",
"cpuUsage": 0.0,
"memTotal": 16693219328,
"memUsed": 3477893120,
"loadAverage_1": 0.28,
"loadAverage_5": 0.41,
"loadAverage_15": 0.36,
"uptime": "4525802.16",
"configDirty": false,
"rebootRequired": false,
"availablePkgUpdates": 0,
"memUsage": 20.8,
"pkgUpdatesAvailable": false,
"uptimeEpoch": "2023-10-08T06:04:17+00:00"
"plugin": {
"openmediavault-anacron": {
"name": "openmediavault-anacron",
"installed": false
"openmediavault-apttool": {
"name": "openmediavault-apttool",
"installed": false
"openmediavault-autoshutdown": {
"name": "openmediavault-autoshutdown",
"installed": false
"openmediavault-backup": {
"name": "openmediavault-backup",
"installed": false
"openmediavault-borgbackup": {
"name": "openmediavault-borgbackup",
"installed": false
"openmediavault-clamav": {
"name": "openmediavault-clamav",
"installed": false
"openmediavault-compose": {
"name": "openmediavault-compose",
"installed": true
"openmediavault-cputemp": {
"name": "openmediavault-cputemp",
"installed": true
"openmediavault-diskstats": {
"name": "openmediavault-diskstats",
"installed": true
"openmediavault-downloader": {
"name": "openmediavault-downloader",
"installed": false
"openmediavault-fail2ban": {
"name": "openmediavault-fail2ban",
"installed": false
"openmediavault-filebrowser": {
"name": "openmediavault-filebrowser",
"installed": false
"openmediavault-flashmemory": {
"name": "openmediavault-flashmemory",
"installed": false
"openmediavault-forkeddaapd": {
"name": "openmediavault-forkeddaapd",
"installed": false
"openmediavault-ftp": {
"name": "openmediavault-ftp",
"installed": false
"openmediavault-kernel": {
"name": "openmediavault-kernel",
"installed": false
"openmediavault-kvm": {
"name": "openmediavault-kvm",
"installed": false
"openmediavault-locate": {
"name": "openmediavault-locate",
"installed": false
"openmediavault-luksencryption": {
"name": "openmediavault-luksencryption",
"installed": false
"openmediavault-lvm2": {
"name": "openmediavault-lvm2",
"installed": false
"openmediavault-mergerfs": {
"name": "openmediavault-mergerfs",
"installed": false
"openmediavault-minidlna": {
"name": "openmediavault-minidlna",
"installed": false
"openmediavault-nut": {
"name": "openmediavault-nut",
"installed": false
"openmediavault-omvextrasorg": {
"name": "openmediavault-omvextrasorg",
"installed": true
"openmediavault-onedrive": {
"name": "openmediavault-onedrive",
"installed": false
"openmediavault-owntone": {
"name": "openmediavault-owntone",
"installed": false
"openmediavault-photoprism": {
"name": "openmediavault-photoprism",
"installed": false
"openmediavault-podman": {
"name": "openmediavault-podman",
"installed": false
"openmediavault-remotemount": {
"name": "openmediavault-remotemount",
"installed": false
"openmediavault-resetperms": {
"name": "openmediavault-resetperms",
"installed": false
"openmediavault-rsnapshot": {
"name": "openmediavault-rsnapshot",
"installed": false
"openmediavault-s3": {
"name": "openmediavault-s3",
"installed": false
"openmediavault-sftp": {
"name": "openmediavault-sftp",
"installed": false
"openmediavault-shairport": {
"name": "openmediavault-shairport",
"installed": false
"openmediavault-sharerootfs": {
"name": "openmediavault-sharerootfs",
"installed": true
"openmediavault-snapraid": {
"name": "openmediavault-snapraid",
"installed": false
"openmediavault-snmp": {
"name": "openmediavault-snmp",
"installed": false
"openmediavault-symlinks": {
"name": "openmediavault-symlinks",
"installed": false
"openmediavault-tftp": {
"name": "openmediavault-tftp",
"installed": false
"openmediavault-tgt": {
"name": "openmediavault-tgt",
"installed": false
"openmediavault-usbbackup": {
"name": "openmediavault-usbbackup",
"installed": false
"openmediavault-wakealarm": {
"name": "openmediavault-wakealarm",
"installed": false
"openmediavault-wetty": {
"name": "openmediavault-wetty",
"installed": false
"openmediavault-wireguard": {
"name": "openmediavault-wireguard",
"installed": false
"openmediavault-wol": {
"name": "openmediavault-wol",
"installed": false
"openmediavault-zfs": {
"name": "openmediavault-zfs",
"installed": false
"disk": {
"nvme0n1": {
"devicename": "nvme0n1",
"canonicaldevicefile": "/dev/nvme0n1",
"size": "128035676160",
"vendor": "0x1e95",
"model": "SSSTC CL1-8D128-HP",
"description": "SSSTC CL1-8D128-HP [/dev/nvme0n1, 119.24 GiB]",
"serialnumber": "UJDJA01ZTDV489",
"israid": false,
"isroot": true,
"isreadonly": false,
"temperature": 33,
"Raw_Read_Error_Rate": "unknown",
"Spin_Up_Time": "unknown",
"Start_Stop_Count": "unknown",
"Reallocated_Sector_Ct": "unknown",
"Seek_Error_Rate": "unknown",
"Load_Cycle_Count": "unknown",
"UDMA_CRC_Error_Count": "unknown",
"Multi_Zone_Error_Rate": "unknown"
"sda": {
"devicename": "sda",
"canonicaldevicefile": "/dev/sda",
"size": "3000592982016",
"vendor": "ATA",
"model": "TOSHIBA HDWD130",
"description": "TOSHIBA HDWD130 [/dev/sda, 2.72 TiB]",
"serialnumber": "89JEU6DCS",
"israid": false,
"isroot": false,
"temperature": 51,
"Raw_Read_Error_Rate": 0,
"Spin_Up_Time": "423",
"Start_Stop_Count": 532,
"Reallocated_Sector_Ct": 0,
"Seek_Error_Rate": 0,
"Load_Cycle_Count": 1317,
"UDMA_CRC_Error_Count": 2,
"sdb": {
"devicename": "sdb",
"canonicaldevicefile": "/dev/sdb",
"size": "8001563222016",
"vendor": "ATA",
"model": "TOSHIBA HDWG480",
"description": "TOSHIBA HDWG480 [/dev/sdb, 7.27 TiB]",
"serialnumber": "6230A08AFA3H",
"israid": false,
"isroot": false,
"temperature": 44,
"Spin_Up_Time": 9606,
"Start_Stop_Count": 38,
"Load_Cycle_Count": 38,
"UDMA_CRC_Error_Count": 0,
"sdc": {
"devicename": "sdc",
"canonicaldevicefile": "/dev/sdc",
"vendor": "ATA",
"description": "TOSHIBA HDWD130 [/dev/sdc, 2.72 TiB]",
"serialnumber": "89JEUA3CS",
"israid": false,
"isroot": false,
"temperature": 51,
"Spin_Up_Time": "420",
"Start_Stop_Count": 1697,
"Load_Cycle_Count": 5437,
"sdd": {
"devicename": "sdd",
"canonicaldevicefile": "/dev/sdd",
"vendor": "ATA",
"model": "TOSHIBA DT01ACA300",
"description": "TOSHIBA DT01ACA300 [/dev/sdd, 2.72 TiB]",
"serialnumber": "Y5PN63PGS",
"israid": false,
"isroot": false,
"temperature": 49,
"Spin_Up_Time": "417",
"Start_Stop_Count": 2242,
"Load_Cycle_Count": 2734,
"UDMA_CRC_Error_Count": 249,
"sde": {
"devicename": "sde",
"canonicaldevicefile": "/dev/sde",
"size": "4000787030016",
"vendor": "ATA",
"model": "TOSHIBA HDWG440",
"description": "TOSHIBA HDWG440 [/dev/sde, 3.63 TiB]",
"serialnumber": "23G0A01DFZ0G",
"israid": false,
"isroot": false,
"temperature": 39,
"Spin_Up_Time": 8522,
"Start_Stop_Count": 5,
"Load_Cycle_Count": 29,
"fs": {
"c72c6da8-beed-4bab-8010-a4d311e86bb8": {
"uuid": "c72c6da8-beed-4bab-8010-a4d311e86bb8",
"parentdevicefile": "/dev/nvme0n1",
"label": "",
"type": "ext4",
"mounted": true,
"devicename": "nvme0n1p2",
"available": 100.0,
"size": 115.4,
"percentage": 9,
"_readonly": true,
"_used": true,
"propreadonly": false
"e713d3cf-b34b-4336-aa6b-f67112b9562a": {
"uuid": "e713d3cf-b34b-4336-aa6b-f67112b9562a",
"parentdevicefile": "/dev/sdd",
"label": "",
"type": "ext4",
"mounted": true,
"devicename": "sdd1",
"available": 1818.5,
"size": 2749.6,
"percentage": 34,
"_readonly": false,
"_used": true,
"7fa3a94a-4f3c-4484-8df6-d4bacc7bcbfc": {
"uuid": "7fa3a94a-4f3c-4484-8df6-d4bacc7bcbfc",
"parentdevicefile": "/dev/sdc",
"label": "",
"type": "ext4",
"mounted": true,
"devicename": "sdc1",
"available": 2165.4,
"size": 2749.6,
"percentage": 22,
"_readonly": false,
"_used": true,
"6f4e26d1-bb13-46c4-96f7-83e0152228a8": {
"uuid": "6f4e26d1-bb13-46c4-96f7-83e0152228a8",
"parentdevicefile": "/dev/sde",
"label": "",
"type": "ext4",
"mounted": true,
"devicename": "sde1",
"available": 2125.2,
"size": 3666.4,
"percentage": 43,
"_readonly": false,
"_used": true,
"6decf95e-88aa-4135-b55d-b9bb7fe04592": {
"uuid": "6decf95e-88aa-4135-b55d-b9bb7fe04592",
"parentdevicefile": "/dev/sdb",
"label": "",
"type": "ext4",
"mounted": true,
"devicename": "sdb1",
"available": 3697.1,
"size": 7392.2,
"percentage": 50,
"_readonly": false,
"_used": true,
"302c9b6d-9bbd-470a-aca0-5fcbcd94bbb6": {
"uuid": "302c9b6d-9bbd-470a-aca0-5fcbcd94bbb6",
"parentdevicefile": "/dev/sda",
"label": "",
"type": "ext4",
"mounted": true,
"devicename": "sda1",
"available": 2229.5,
"size": 2749.6,
"percentage": 19,
"_readonly": false,
"_used": true,
"6D51-98DC": {
"uuid": "6D51-98DC",
"label": "",
"type": "vfat",
"mounted": true,
"devicename": "nvme0n1p1",
"available": 0.5,
"size": 0.5,
"percentage": 1,
"_readonly": false,
"_used": false,
"service": {
"Docker": {
"name": "Docker",
"title": "Docker",
"enabled": true,
"running": true
"nfs": {
"name": "nfs",
"title": "NFS",
"enabled": false,
"running": false
"rsyncd": {
"name": "rsyncd",
"title": "RSync server",
"enabled": false,
"running": false
"samba": {
"name": "samba",
"title": "SMB/CIFS",
"enabled": true,
"running": true
"ssh": {
"name": "ssh",
"title": "SSH",
"enabled": true,
"running": true
"network": {
"7bdf0b11-af3d-4327-a205-f56695e6ff90": {
"uuid": "7bdf0b11-af3d-4327-a205-f56695e6ff90",
"devicename": "enp3s0",
"type": "ethernet",
"method": "dhcp",
"address": "192.168.188.65",
"netmask": "255.255.255.0",
"gateway": "192.168.188.1",
"mtu": 1500,
"link": true,
"wol": false,
"rx-current": 349600717717.0,
"tx-current": 11583583391201.0,
"rx-previous": 349600717717.0,
"tx-previous": 11583583391201.0,
"rx": 441524.8,
"tx": 32638387.6
"fa4b1c66-ef79-11e5-87a0-0002b3a176b4": {
"uuid": "fa4b1c66-ef79-11e5-87a0-0002b3a176b4",
"devicename": "vethfbcac50",
"type": "virtual",
"method": "unknown",
"address": "",
"netmask": "",
"gateway": "",
"mtu": 1500,
"link": true,
"wol": false,
"rx-current": 2431721.0,
"tx-current": 40669.0,
"rx-previous": 2431721.0,
"tx-previous": 40669.0,
"rx": 0.0,
"tx": 0.0
"kvm": {},
"compose": {
"jellyfin": {
"name": "jellyfin",
"image": "lscr.io/linuxserver/jellyfin:latest",
"project": "unknown",
"service": "unknown",
"created": "2023-07-17 08:57:08 +0200 CEST",
"state": "running"
"qbittorrent": {
"name": "qbittorrent",
"image": "lscr.io/linuxserver/qbittorrent:latest",
"created": "2023-07-17 08:56:21 +0200 CEST",
"state": "running"
"portainer": {
"name": "portainer",
"image": "portainer/portainer-ce:latest",
"created": "2023-07-17 08:54:53 +0200 CEST",
"state": "running"
"transmission": {
"name": "transmission",
"image": "lscr.io/linuxserver/transmission:latest",
"created": "2023-06-04 22:13:11 +0200 CEST",
"state": "running"
The only real difference i can see is that u do ssl.
Will have to try that out, did u have to do something special to accept ssl like import/create a cert of some kind?
None of that, it’s just a standard OMV install…
Does your nas have a usb drive option?could you ug in a usb stick ir drive and see if the smart stays working?
When smart is disabled, the downloaded diagnostic file iss all smart info empty but i have all the other vues of the plugin, when i turn smart on, the normal drives do have data like temperature and spin time etc, allgood but the usb and flash drive on the mainbaord have nothing and the hole plugin shows unavailable.
It seems that the parser reading the datafile is tripping over an entry that is not expected and throws error.
So if you could try with an usb drive attached would be great.
That would narrow it down
Could be related: [Bug] Error 500 on SMART attributes · Issue #139 · tomaae/homeassistant-openmediavault · GitHub
Hello, just read through that issue and it seems to be very related.
For me it is that i have a usb drive that does not say a word about being a usb port one and a mainboard mounted flash drive saying it is usb disk in model.
All the other 6 drives show all values as expected.
So it seems related.
Let me know if i can do something to assist…
Blockquote
“home_assistant”: {
“installation_type”: “Home Assistant OS”,
“version”: “2023.11.3”,
“dev”: false,
“hassio”: true,
“virtualenv”: false,
“python_version”: “3.11.6”,
“docker”: true,
“arch”: “x86_64”,
“timezone”: “America/New_York”,
“os_name”: “Linux”,
“os_version”: “6.1.59”,
“supervisor”: “2023.11.6”,
“host_os”: “Home Assistant OS 11.1”,
“docker_version”: “24.0.6”,
“chassis”: “embedded”,
“run_as_root”: true
“custom_components”: {
“volkswagencarnet”: {
“version”: “v4.4.65”,
“requirements”: [
“pytz”,
“volkswagencarnet==4.4.62”
“openmediavault”: {
“version”: “0.0.0”,
“requirements”:
“emporia_vue”: {
“version”: “0.8.3”,
“requirements”: [
“pyemvue==0.17.1”
“better_thermostat”: {
“version”: “1.4.0”,
“requirements”:
“localtuya”: {
“version”: “5.2.1”,
“requirements”:
“composite”: {
“version”: “2.8.4”,
“requirements”:
“fontawesome”: {
“version”: “2.2.1”,
“requirements”:
“ble_monitor”: {
“version”: “12.6.1”,
“requirements”: [
“pycryptodomex>=3.18.0”,
“janus>=1.0.0”,
“aioblescan>=0.2.14”,
“btsocket>=0.2.0”,
“pyric>=0.1.6.3”
“webrtc”: {
“version”: “v3.5.0”,
“requirements”:
“sonoff”: {
“version”: “3.5.3”,
“requirements”: [
“pycryptodome>=3.6.6”
“hacs”: {
“version”: “1.33.0”,
“requirements”: [
“aiogithubapi>=22.10.1”
“frigate”: {
“version”: “4.0.0”,
“requirements”: [
“pytz==2022.7”
“integration_manifest”: {
“domain”: “openmediavault”,
“name”: “OpenMediaVault”,
“codeowners”: [
“@tomaae”
“config_flow”: true,
“dependencies”: ,
“documentation”: “GitHub - tomaae/homeassistant-openmediavault: OpenMediaVault integration for Home Assistant”,
“iot_class”: “local_polling”,
“issue_tracker”: “Issues · tomaae/homeassistant-openmediavault · GitHub”,
“requirements”: ,
“version”: “0.0.0”,
“is_built_in”: false
“data”: {
“entry”: {
“data”: {
“name”: “OMV6”,
“host”: “192.168.178.60”,
“username”: “REDACTED”,
“password”: “REDACTED”,
“ssl”: true,
“verify_ssl”: false
“options”: {
“scan_interval”: 60,
“smart_disable”: true
“data”: {
“hwinfo”: {
“hostname”: “pro6.workgroup”,
“version”: “6.9.8-1 (Shaitan)”,
“cpuUsage”: 0.0,
“memTotal”: 4104282112,
“memUsed”: 775393280,
“loadAverage_1”: 0.65,
“loadAverage_5”: 0.68,
“loadAverage_15”: 0.84,
“uptime”: “724241.8”,
“configDirty”: false,
“rebootRequired”: false,
“availablePkgUpdates”: 2,
“memUsage”: 18.9,
“pkgUpdatesAvailable”: true,
“uptimeEpoch”: “2023-11-22T10:39:37+00:00”
“plugin”: {
“openmediavault-anacron”: {
“name”: “openmediavault-anacron”,
“installed”: false
“openmediavault-apttool”: {
“name”: “openmediavault-apttool”,
“installed”: false
“openmediavault-autoshutdown”: {
“name”: “openmediavault-autoshutdown”,
“installed”: false
“openmediavault-backup”: {
“name”: “openmediavault-backup”,
“installed”: true
“openmediavault-borgbackup”: {
“name”: “openmediavault-borgbackup”,
“installed”: false
“openmediavault-clamav”: {
“name”: “openmediavault-clamav”,
“installed”: false
“openmediavault-compose”: {
“name”: “openmediavault-compose”,
“installed”: true
“openmediavault-cputemp”: {
“name”: “openmediavault-cputemp”,
“installed”: true
“openmediavault-diskstats”: {
“name”: “openmediavault-diskstats”,
“installed”: true
“openmediavault-downloader”: {
“name”: “openmediavault-downloader”,
“installed”: true
“openmediavault-fail2ban”: {
“name”: “openmediavault-fail2ban”,
“installed”: true
“openmediavault-filebrowser”: {
“name”: “openmediavault-filebrowser”,
“installed”: true
“openmediavault-flashmemory”: {
“name”: “openmediavault-flashmemory”,
“installed”: false
“openmediavault-forkeddaapd”: {
“name”: “openmediavault-forkeddaapd”,
“installed”: false
“openmediavault-ftp”: {
“name”: “openmediavault-ftp”,
“installed”: true
“openmediavault-kernel”: {
“name”: “openmediavault-kernel”,
“installed”: true
“openmediavault-kvm”: {
“name”: “openmediavault-kvm”,
“installed”: false
“openmediavault-locate”: {
“name”: “openmediavault-locate”,
“installed”: false
“openmediavault-luksencryption”: {
“name”: “openmediavault-luksencryption”,
“installed”: false
“openmediavault-lvm2”: {
“name”: “openmediavault-lvm2”,
“installed”: false
“openmediavault-mergerfs”: {
“name”: “openmediavault-mergerfs”,
“installed”: false
“openmediavault-minidlna”: {
“name”: “openmediavault-minidlna”,
“installed”: true
“openmediavault-nut”: {
“name”: “openmediavault-nut”,
“installed”: true
“openmediavault-omvextrasorg”: {
“name”: “openmediavault-omvextrasorg”,
“installed”: true
“openmediavault-onedrive”: {
“name”: “openmediavault-onedrive”,
“installed”: false
“openmediavault-owntone”: {
“name”: “openmediavault-owntone”,
“installed”: false
“openmediavault-photoprism”: {
“name”: “openmediavault-photoprism”,
“installed”: false
“openmediavault-podman”: {
“name”: “openmediavault-podman”,
“installed”: false
“openmediavault-remotemount”: {
“name”: “openmediavault-remotemount”,
“installed”: true
“openmediavault-resetperms”: {
“name”: “openmediavault-resetperms”,
“installed”: true
“openmediavault-rsnapshot”: {
“name”: “openmediavault-rsnapshot”,
“installed”: false
“openmediavault-s3”: {
“name”: “openmediavault-s3”,
“installed”: false
“openmediavault-sftp”: {
“name”: “openmediavault-sftp”,
“installed”: false
“openmediavault-shairport”: {
“name”: “openmediavault-shairport”,
“installed”: false
“openmediavault-sharerootfs”: {
“name”: “openmediavault-sharerootfs”,
“installed”: true
“openmediavault-snapraid”: {
“name”: “openmediavault-snapraid”,
“installed”: false
“openmediavault-snmp”: {
“name”: “openmediavault-snmp”,
“installed”: true
“openmediavault-symlinks”: {
“name”: “openmediavault-symlinks”,
“installed”: false
“openmediavault-tftp”: {
“name”: “openmediavault-tftp”,
“installed”: false
“openmediavault-tgt”: {
“name”: “openmediavault-tgt”,
“installed”: false
“openmediavault-usbbackup”: {
“name”: “openmediavault-usbbackup”,
“installed”: false
“openmediavault-wakealarm”: {
“name”: “openmediavault-wakealarm”,
“installed”: false
“openmediavault-wetty”: {
“name”: “openmediavault-wetty”,
“installed”: true
“openmediavault-wireguard”: {
“name”: “openmediavault-wireguard”,
“installed”: false
“openmediavault-wol”: {
“name”: “openmediavault-wol”,
“installed”: false
“openmediavault-zfs”: {
“name”: “openmediavault-zfs”,
“installed”: false
“disk”: {
“sda”: {
“devicename”: “sda”,
“canonicaldevicefile”: “/dev/sda”,
“size”: “1000204886016”,
“vendor”: “ATA”,
“model”: “WDC WD10EZEX-60M2NA0”,
“description”: “WDC WD10EZEX-60M2NA0 [/dev/sda, 931.51 GiB]”,
“serialnumber”: “WD-WCC3F4JUXTE9”,
“israid”: false,
“isroot”: false,
“isreadonly”: false,
“temperature”: 0,
“Raw_Read_Error_Rate”: “unknown”,
“Spin_Up_Time”: “unknown”,
“Start_Stop_Count”: “unknown”,
“Reallocated_Sector_Ct”: “unknown”,
“Seek_Error_Rate”: “unknown”,
“Load_Cycle_Count”: “unknown”,
“UDMA_CRC_Error_Count”: “unknown”,
“Multi_Zone_Error_Rate”: “unknown”
“sdb”: {
“devicename”: “sdb”,
“canonicaldevicefile”: “/dev/sdb”,
“size”: “1000204992512”,
“vendor”: “ATA”,
“model”: “ST1000DM003-1SB102”,
“description”: “ST1000DM003-1SB102 [/dev/sdb, 931.51 GiB]”,
“serialnumber”: “Z9A8T510”,
“israid”: false,
“isroot”: false,
“temperature”: 0,
“sdc”: {
“devicename”: “sdc”,
“canonicaldevicefile”: “/dev/sdc”,
“size”: “640135028224”,
“vendor”: “Seagate”,
“model”: “BUP Slim”,
“description”: “BUP Slim [/dev/sdc, 596.17 GiB]”,
“serialnumber”: “2HC015KJ”,
“israid”: false,
“isroot”: true,
“temperature”: 0,
“sdd”: {
“devicename”: “sdd”,
“canonicaldevicefile”: “/dev/sdd”,
“vendor”: “ATA”,
“description”: “ST1000DM003-1SB102 [/dev/sdd, 931.51 GiB]”,
“serialnumber”: “Z9AA8GLV”,
“israid”: false,
“isroot”: false,
“temperature”: 0,
“sde”: {
“devicename”: “sde”,
“canonicaldevicefile”: “/dev/sde”,
“vendor”: “ATA”,
“model”: “WDC WD1003FBYX-01Y7B2”,
“description”: “WDC WD1003FBYX-01Y7B2 [/dev/sde, 931.51 GiB]”,
“serialnumber”: “WD-WCAW35438903”,
“israid”: false,
“isroot”: false,
“temperature”: 0,
“sdf”: {
“devicename”: “sdf”,
“canonicaldevicefile”: “/dev/sdf”,
“size”: “128450560”,
“vendor”: “SMI”,
“model”: “USB DISK”,
“description”: “USB DISK [/dev/sdf, 122.50 MiB]”,
“serialnumber”: “AA04012700007517”,
“israid”: false,
“isroot”: false,
“temperature”: 0,
“sdg”: {
“devicename”: “sdg”,
“canonicaldevicefile”: “/dev/sdg”,
“vendor”: “ATA”,
“model”: “ST1000NM0033-9ZM173”,
“description”: “ST1000NM0033-9ZM173 [/dev/sdg, 931.51 GiB]”,
“serialnumber”: “Z1W3MH21”,
“israid”: false,
“isroot”: false,
“temperature”: 0,
“sdh”: {
“devicename”: “sdh”,
“canonicaldevicefile”: “/dev/sdh”,
“vendor”: “ATA”,
“model”: “WDC WD10EZEX-08WN4A0”,
“description”: “WDC WD10EZEX-08WN4A0 [/dev/sdh, 931.51 GiB]”,
“serialnumber”: “WD-WCC6Y0CJTVHJ”,
“israid”: false,
“isroot”: false,
“temperature”: 0,
“fs”: {
“34be3b14-f65a-4352-adef-091f5a6edb15”: {
“uuid”: “34be3b14-f65a-4352-adef-091f5a6edb15”,
“parentdevicefile”: “/dev/sdc”,
“label”: “”,
“type”: “ext4”,
“mounted”: true,
“devicename”: “sdc1”,
“available”: 467.1,
“size”: 501.0,
“percentage”: 3,
“_readonly”: true,
“_used”: true,
“propreadonly”: false
“f8e87c48-3e5e-4b1f-a7b5-24f84bd691ba”: {
“uuid”: “f8e87c48-3e5e-4b1f-a7b5-24f84bd691ba”,
“parentdevicefile”: “/dev/md127”,
“label”: “Raid6”,
“type”: “ext4”,
“mounted”: true,
“devicename”: “md127”,
“available”: 543.2,
“size”: 3666.0,
“percentage”: 86,
“_readonly”: false,
“_used”: true,
“4B21-5904”: {
“uuid”: “4B21-5904”,
“parentdevicefile”: “/dev/sdf”,
“label”: “”,
“type”: “vfat”,
“mounted”: false,
“devicename”: “sdf1”,
“available”: -0.0,
“size”: -0.0,
“percentage”: -1,
“_readonly”: false,
“_used”: false,
“service”: {
“Docker”: {
“name”: “Docker”,
“title”: “Docker”,
“enabled”: true,
“running”: true
“fail2ban”: {
“name”: “fail2ban”,
“title”: “fail2ban”,
“enabled”: false,
“running”: false
“filebrowser”: {
“name”: “filebrowser”,
“title”: “File Browser”,
“enabled”: false,
“running”: false
“proftpd”: {
“name”: “proftpd”,
“title”: “FTP”,
“enabled”: true,
“running”: true
“minidlna”: {
“name”: “minidlna”,
“title”: “MiniDLNA”,
“enabled”: true,
“running”: true
“nfs”: {
“name”: “nfs”,
“title”: “NFS”,
“enabled”: true,
“running”: true
“nut”: {
“name”: “nut”,
“title”: “UPS”,
“enabled”: true,
“running”: true
“rsyncd”: {
“name”: “rsyncd”,
“title”: “RSync server”,
“enabled”: false,
“running”: false
“samba”: {
“name”: “samba”,
“title”: “SMB/CIFS”,
“enabled”: true,
“running”: true
“snmpd”: {
“name”: “snmpd”,
“title”: “SNMP”,
“enabled”: true,
“running”: true
“ssh”: {
“name”: “ssh”,
“title”: “SSH”,
“enabled”: true,
“running”: true
“wetty”: {
“name”: “wetty”,
“title”: “WeTTY”,
“enabled”: true,
“running”: true
“network”: {
“09f4467e-d480-43d5-8b9c-8191a48cfb01”: {
“uuid”: “09f4467e-d480-43d5-8b9c-8191a48cfb01”,
“devicename”: “enp1s0”,
“type”: “ethernet”,
“method”: “static”,
“address”: “192.168.178.60”,
“netmask”: “255.255.255.0”,
“gateway”: “192.168.178.1”,
“mtu”: 1500,
“link”: true,
“wol”: false,
“rx-current”: 142493105365.0,
“tx-current”: 129451208751.0,
“rx-previous”: 142493105365.0,
“tx-previous”: 129451208751.0,
“rx”: 39968.27,
“tx”: 68566.53
“fa4b1c66-ef79-11e5-87a0-0002b3a176b4”: {
“uuid”: “fa4b1c66-ef79-11e5-87a0-0002b3a176b4”,
“devicename”: “enp2s0”,
“type”: “ethernet”,
“method”: “unknown”,
“address”: “”,
“netmask”: “”,
“gateway”: “”,
“mtu”: 1500,
“link”: false,
“wol”: false,
“rx-current”: 0.0,
“tx-current”: 0.0,
“rx-previous”: 0.0,
“tx-previous”: 0.0,
“rx”: 0.0,
“tx”: 0.0
“kvm”: {},
“compose”: {}
Blockquote
Try to install master using HACS as it say in the issue, it shoudl get fixed.
Hello…Just tried…
It says its version 1.4.2 and with smart enabled i am still unavailable…
Where do you do the parsing of those smart info in your code?
I tried to go through it while at work, but a phone screen only shows so much
not 1.4.2, you have to choose “master” from the list in HACS.
if it still does not work, open an issue on github. this is not somethign that can be debugged on forums.
Ok, that did the trick…so i should ignore future updates to 1.4.2?
Thx alot…
No, this will be part of next update. Its just not released yet.
Oh perfect, thx for your time and effort.
Good amount of code went into it, several weeks i assume.
When I try to set up the connection I always get an error message.
Username and password is correct. Any ideas?
CU Jo
PS: OMV 6.9.9-1
HASS-OS: 11.1 (runs under omv->
kvm as a vm)
Hello…u made sure ip i correct and no firewall in the way?
can u ping is from homeassist?
