Since Telldus want payment for the earlier free use of the api, I bought some LillyGo-433Mhz.
Uploaded OMG (OpenMqttGateway). and have contact with with HA.
All temperature sensors appeared in HA.
When I “pressed”, actually using Telldus live for my Tellstick Z-Net V2, only the RSSI appears.
Reading the log I got this plug (and one for the ON):
2023-08-10 08:19:21.075 DEBUG (MainThread) [homeassistant.components.mqtt.client] Received message on home/omg_lilygo_1/RTL_433toMQTT/Nexa-Security/3/38428816 (qos=0): b’ {“model”:“Nexa-Security”,“id”:38428816,“channel”:3,“state”:“OFF”,“unit”:3,“group”:0,“protocol”:“Nexa”,“rssi”:-97,“duration”:213000}
But I have never worked directly with MQTT.
It works since I’m running z2m, and that works!
How do I configure Mqtt to send on/off to this?
And for my remotes how do I receive?
I think I have some proove and arctech devices aswell,
Thing is that first when I started the OMG and it connected all my temerature sensors showed up automagicly. So I thought that my plugs would do the same. Thats why I used the Tellstick via Telldus, to simulate sending command to the plug.
And then I tried to under stand what was happening. The strange thing is that the tempsensor has everything, temperature, humidity and RSSI. But the plug only has RSSI.
But looking in the logs everything is there. At the moment I don’t want to receive, but send…
It’s a combination of the link provided here and some other links!
Hopefully I can get more focused during the weekend!
State 433mhz sensor are not supported by auto-discovery (this is why they are not created automatically (unlike the temperature sensors), but you can still make a YAML definition to use them.
This is at my summer cottage. When I’m there, usually ther is loads of other work that has to be done.
Moving the lawn, cutting bushes, etc. I will try to dedicate a weekend, and just do HA stuff.
Now I have tried yaml config, if that means putting stuff in configuration.yaml, but it does not work.
I see the messages in the log, but no.
Is there an examples with RTL_433toMQTT and MQTTtoRTL_433 and switches?
The only example is about SRFBtoMQTT / MQTTtoSRFB. And there I don’t se where to put housecode device id, etc.
