I’ve just started with OpenRGB, so I have the latest everything. I’ve even tried the experimental.
Found this in the logs.
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 148, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 181, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 72, in wrapper
result = await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 296, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 392, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/config/custom_components/openrgb/config_flow.py", line 76, in async_step_user
await asyncio.wait_for(
File "/usr/local/lib/python3.11/asyncio/tasks.py", line 479, in wait_for
return fut.result()
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/config/custom_components/openrgb/config_flow.py", line 24, in _try_connect
conn = OpenRGBClient(_host, _port, name=_client_id)
File "/usr/local/lib/python3.11/site-packages/openrgb/orgb.py", line 287, in __init__
self.comms.requestDeviceNum()
File "/usr/local/lib/python3.11/site-packages/openrgb/network.py", line 188, in requestDeviceNum
self.read()
File "/usr/local/lib/python3.11/site-packages/openrgb/network.py", line 116, in read
self.callback(device_id, packet_type, buff[0])
File "/usr/local/lib/python3.11/site-packages/openrgb/orgb.py", line 302, in _callback
self.comms.requestDeviceData(x)
File "/usr/local/lib/python3.11/site-packages/openrgb/network.py", line 181, in requestDeviceData
self.read()
File "/usr/local/lib/python3.11/site-packages/openrgb/network.py", line 137, in read
self.callback(device_id, packet_type, utils.ControllerData.unpack(data, self._protocol_version))
File "/usr/local/lib/python3.11/site-packages/openrgb/utils.py", line 552, in unpack
mode = ModeData.unpack(data, version, x)
File "/usr/local/lib/python3.11/site-packages/openrgb/utils.py", line 327, in unpack
color_mode = ModeColors(parse_var('I', data))
File "/usr/local/lib/python3.11/enum.py", line 711, in __call__
return cls.__new__(cls, value)
File "/usr/local/lib/python3.11/enum.py", line 1128, in __new__
raise ve_exc
ValueError: 64 is not a valid ModeColors
