HI I have read all your posts. My intended setup would be a little different. I have one main living room that shoul allways remain working. No matter the state of my HA instance. (i can be away for long times).
But: The bathroom, twoo studies, and maybe another room i want to control separate. I want to use Zigbee TRV’s in those rooms. If HA is not working everything should work the old fashioned way. Just based on the living room temeperature. So when the HA setup is working properly the boiler should turn on and supply heat to at least one room that is requesting heat. If the Living Room is not requesting heat, the floor heating system should be closed. In ALL other situations the floor heating valve must be open.
Is this setup possible?
Just wanted to chime in and say thanks and add a bit more for other people finding this in 2024 and beyond…
this set up so far looks super useful but could probably be updated a bit. So i took & adapted @dujith 's excellent posts above, and slightly updated it for the newer (referred to as “modern” style) template syntax…
for example, what we have above in this thread uses parameters of “friendly_name” and “value_template”, which are now considered “legacy-format”, only found in that part of the docs-section, and is no longer recommended. Instead value_template is referred to just as “state” and “friendly_name” becomes (i believe) just the “name:” parameter (and what was the name can now be referred to as “unique_id”).
Here’s how i imagine it could be updated for the current template-format “style” - put the following in your templates.yaml:
- name: "Central Heating Temperature"
unique_id: ch_virtual_temperature
unit_of_measurement: "°C"
state: >
{% if states('climate.trv_bedroom1') == "heat" %}
{% set tempdiff_bedroom1 = state_attr('climate.trv_bedroom1','temperature')
- states('sensor.temperature_bedroom1_temperature') | float %}
{% else %}
{% set tempdiff_bedroom1 = '-99' | float %}
{% endif %}
{% if states('climate.trv_bedroom2') == "heat" %}
{% set tempdiff_bedroom2 = state_attr('climate.trv_bedroom2','temperature')
- states('sensor.temperature_bedroom2_temperature') | float %}
{% else %}
{% set tempdiff_bedroom2 = '-99' | float %}
{% endif %}
{% if states('climate.trv_officegym') == "heat" %}
{% set tempdiff_officegym = state_attr('climate.trv_officegym','temperature')
- states('sensor.temperature_officegym_temperature') | float %}
{% else %}
{% set tempdiff_officegym = '-99' | float %}
{% endif %}
{% if states('climate.trv_hallway') == "heat" %}
{% set tempdiff_hallway = state_attr('climate.trv_hallway','temperature')
- states('sensor.temperature_hallway_lower_temperature') | float %}
{% else %}
{% set tempdiff_hallway = '-99' | float %}
{% endif %}
{% if states('climate.trv_bathroom_lower') == "heat" %}
{% set tempdiff_bathroom_lower = state_attr('climate.trv_bathroom_lower','temperature')
- states('sensor.temperature_bathroom_lower_temperature') | float %}
{% else %}
{% set tempdiff_bathroom_lower = '-99' | float %}
{% endif %}
{% if states('climate.trv_kitchen') == "heat" %}
{% set tempdiff_kitchen = state_attr('climate.trv_kitchen','temperature')
- states('sensor.temperature_livingroom_temperature') | float %}
{% else %}
{% set tempdiff_kitchen = '-99' | float %}
{% endif %}
{% if states('climate.trv_livingroom_center') == "heat" %}
{% set tempdiff_livingroom_center = state_attr('climate.trv_livingroom_center','temperature')
{% else %}
{% set tempdiff_livingroom_center = '-99' | float %}
{% endif %}
{% if states('climate.trv_livingroom_wall') == "heat" %}
{% set tempdiff_livingroom_wall = state_attr('climate.trv_livingroom_wall','temperature')
{% else %}
{% set tempdiff_livingroom_wall = '-99' | float %}
{% endif %}
{% set room_list_tempdiffs = [tempdiff_bedroom1,tempdiff_bedroom2,tempdiff_officegym,tempdiff_hallway,tempdiff_bathroom_lower,tempdiff_kitchen,tempdiff_livingroom_center,tempdiff_livingroom_wall] %}
{% set max_tempdiff = (room_list_tempdiffs | max) %}
{% set index_tempdiff = room_list_tempdiffs.index(max_tempdiff) %}
{% if index_tempdiff == 0 %}
{{ (states('sensor.temperature_bedroom1_temperature') | float(18)) }}
{% elif index_tempdiff == 1 %}
{{ (states('sensor.temperature_bedroom2_temperature') | float(18)) }}
{% elif index_tempdiff == 2 %}
{{ (states('sensor.temperature_officegym_temperature') | float(18)) }}
{% elif index_tempdiff == 3 %}
{{ (states('sensor.temperature_hallway_lower_temperature') | float(18)) }}
{% elif index_tempdiff == 4 %}
{{ (states('sensor.temperature_bathroom_lower_temperature') | float(18)) }}
{% else %}
{{ (states('sensor.temperature_livingroom_temperature') | float(18)) }}
{% endif %}
- name: "Central Heating Setpoint"
unique_id: ch_virtual_setpoint
state: >
{% else %}
{% endif %}
{% else %}
{% endif %}
{% else %}
{% endif %}
{% else %}
{% endif %}
{% else %}
{% endif %}
{% else %}
{% endif %}
{% else %}
{% endif %}
{% else %}
{% endif %}
{{ state_attr('climate.trv_bedroom1','temperature') | float(18) }}
{{ state_attr('climate.trv_bedroom2','temperature') | float(18) }}
{{ state_attr('climate.trv_officegym','temperature') | float(18) }}
{{ state_attr('climate.trv_hallway','temperature') | float(18) }}
{{ state_attr('climate.trv_bathroom_lower','temperature') | float(18) }}
{% elif index_tempdiff == 5 %}
{{ state_attr('climate.trv_kitchen','temperature') | float(18) }}
{% elif index_tempdiff == 6 %}
{{ state_attr('climate.trv_livingroom_center','temperature') | float(18) }}
{% elif index_tempdiff == 7 %}
{{ state_attr('climate.trv_livingroom_wall','temperature') | float(18) }}
{% endif %}
I’ve also incorporated the idea from @Snelf in the above post, so that when a TRV is not set to heat, it will default to “skipping” it (setting its suggested temp-differential to -99, to effectively prevent it from the choosing (unless we’re in an ice-age perhaps)).
Additionally, things to be aware of about my setup:
- i have only one temperature-sensor (all mine are aqara ones) for the area in the house that includes both the kitchen/living room (as they’re connected, w/o a significant partition between them, so thermally i treat them the-same), but there are in-fact three radiators (and thus TRVs) there - so i check each of them for the temp-diff in both template-sensors, but for the temperature, it’s picked as a “fall-back” in the if-block, and for the setpoint if-block, i actually use the setpoint of the specific TRV).
At the moment, these two values look like this for the temperature:
And like this for the setpoint:
If anyone has any ideas/feedback on my approach, or ideas for improvement, i’im open to them. One thing i’m not sure about which was touched upon in the above thread was whether the boiler will function efficiently if its idea of what the current temperature and the setpoint changes regularly. It seems it wouldn’t be able to “calibrate” its internal PID parameters since each room is slightly different and it won’t be able to converge on the correct parameters if the values/behaviour of the heating keeps shifting between different rooms.
Finally, things that are missing still:
- i need to actually wire-up the thermostat to my boiler still
- come up with automations that take-into-account whether no one is home (i am using the advhanced-heating-control blueprint for that on the individual-TRV basis, but need to incorporate it also telling the boiler to not generate heat if all TRV’s are not needing heat - which at the moment i’m not sure if that can ever happen?).
I am not yet sure if floating zones are compatible with PID for a floor heating system, as I have only just started testing it.
By the way, this is the configuration I am currently using to avoid a lot of if/elif
- sensor:
- name: Heating deltas
unique_id: heating_deltas
state: >-
{% set ns = namespace(items=[]) %}
{% for clim in states.climate
| selectattr('entity_id', 'search', 'smarttherm_|dumbtherm_') # FIXME use propert stratsWith logic
| selectattr('state','eq','heat')
| map(attribute='attributes')%}
{% set clim_temp = clim.temperature | float(18) %}
{% set clim_curr_temp = clim.current_temperature | float(18) %}
{% set ns.items = ns.items + [{
"target": clim_temp,
"curr": clim_curr_temp,
"delta": clim_temp - clim_curr_temp | round(1, 'ceil'),
{%endfor%}
{% set valid_items = ns.items | selectattr('delta', 'gt', 0) | list %}
{{ ((valid_items | max(attribute='delta')) if valid_items else {'curr': float(18), 'target': float(18)}) | to_json}}
- sensor:
- name: Virtual Heating Setpoint
unique_id: heating_virtual_setpoint
state: "{{ (states.sensor.heating_deltas.state | from_json).target }}"
- sensor:
- name: Virtual Heating Temperature
unique_id: heating_virtual_temperature
state: "{{ (states.sensor.heating_deltas.state | from_json).curr }}"
where dumbtherm_ and smarttherm_ are the entity_id prefixes I put in place for respectively legacy on/off thermostats and their smart counterpart: in this phase I’m trying to keep both working through generic thermostats composed by temp sensors and switches.
Hi David,
Thanks, this is great coding! I further adjusted it, so I also know which area is requesting heating.
This is my sensor that is calculating the right heating delta.
I did set it up in the (old fashioned but reliable) configuration.yaml. If I use the UI, I received an error that the entity state is longer than 255 character.
- sensor:
- name: Verwarming - ruimte met grootste delta
state: >-
if clim.entity_id.startswith('climate.vtherm') and clim.state == 'heat' %}
{% set clim_temp = clim.attributes.temperature | float(18) %}
{% set clim_curr_temp = clim.attributes.current_temperature | float(18) %}
{% set delta = (clim_temp - clim_curr_temp) | round(1, 'ceil') %}
{% if delta > 0 %}
{% set area = area_name(clim.entity_id) %}
"area": area,
"entity_id": clim.entity_id,
"delta": delta
{% endif %}
{% endfor %}
{% set valid_items = ns.items %}
valid_items
if valid_items
else {
"area": "",
"entity_id": "",
"target": 18.0,
"curr": 18.0,
"delta": 0
| to_json
The code above assumes that all climate entities involved should start with “vtherm” and are heating.
I created three additional sensors to retrieve the current and target temperature (this is exactly as you did) and the area of the thermostat that triggers my heating:
- sensor:
state: "{{ (states('sensor.heating_deltas') | from_json).target }}"
- sensor:
state: "{{ (states('sensor.heating_deltas') | from_json).curr }}"
- sensor:
- name: Virtual Heating Area
unique_id: heating_virtual_area
state: "{{ (states('sensor.heating_deltas') | from_json).area }}"
I also created an automation that would control my OpenTherm (DIYLESS) thermostat with the correct current and target temperature. It not only sends any change to above sensors directly to the thermostat, but will also do it every 20 seconds (so the thermostat does not go in error when no updates are received).
alias: Send current and target temperature to DIYLESS Thermostat
description: ""
triggers:
- trigger: time_pattern
seconds: /20
- trigger: state
entity_id:
- sensor.heating_virtual_setpoint
- sensor.heating_virtual_temperature
actions:
- alias: Publish current temperature to OpenTherm
action: mqtt.publish
metadata: {}
evaluate_payload: false
qos: "0"
retain: false
topic: diyless_thermostat/cmnd/things/thermostat/properties/temperature
payload: |
states('sensor.heating_virtual_temperature') | float
enabled: true
- alias: Publish target temperature to OpenTherm
action: climate.set_temperature
metadata: {}
temperature: "{{ states('sensor.heating_virtual_setpoint') | float }}"
hvac_mode: heat
entity_id: climate.diyless_thermostat_1_central_heating
This is great stuff. Copied and adjusted a bit, thanks!
I am guessing you use TRVs to open/close the radiators in the rooms heating. In this thread, they use Sonoff TRVs, but their approach is interesting.
It may seem straightforward to set the temperature on the TRV thermostat to match the room’s temperature. But then you have hysteresis on the TRV, while the boiler (Diyless) may do the same (as it has a PID). That may conflict… or am I overthinking?
I use some Sonoff 4CH Pro devices that turn on/off dumb thermo-electric valves.
The logic is handled by “Versatile Thermostat”, I just make sure the actual and target temperature is defined.
I created an updated version of the Delta Temperature template:
- It always sets the current temperature in the json, even when no heating takes place. This is just to sent the current temp to the ESPHome (DIYLess) thermostat. Not sure if that is required. But nice to have
- When no heating is required, area is set to NA
- Biggest improvement: deltaT can be a negative value. This is to take overshoots into account. With the previous version, the default output was returned when Delta T was smaller (or equal) to 0.
Thanks to ChatGPT, as this is far beyond my programming skills (but not beyond my reasoning ![]()
- triggers:
seconds: "/10"
- name: "Delta Temperature"
unique_id: ce2b9e44-0146-4783-9f8c-3f6c0280d3f8
state: >
{% set fallback_curr = states('sensor.temperature_living_room_temperature') | float(18) %}
{% set best = namespace(
delta = -999,
deviation = 0,
area = 'NA',
entity_id = '',
target = 10,
curr = fallback_curr
if clim.entity_id.startswith('climate.virtual_thermostat_')
{% set target = clim.attributes.temperature | float(18) %}
{% set curr = clim.attributes.current_temperature | float(18) %}
{% set delta = (target - curr) | round(1) %}
{% set deviation = delta | abs %}
{# Rule 1+2: prefer positive deltas #}
{% if delta > 0 and delta > best.delta %}
{% set best.delta = delta %}
{% set best.deviation = deviation %}
{% set best.area = area_name(clim.entity_id) or 'NA' %}
{% set best.entity_id = clim.entity_id %}
{% set best.target = target %}
{% set best.curr = curr %}
{# Rule 3: fallback to overshoot only if no positive delta exists #}
{% elif best.delta <= 0 and deviation > best.deviation %}
{% endif %}
{% endfor %}
"area": best.area,
"entity_id": best.entity_id,
"target": best.target,
"curr": best.curr,
"delta": best.delta
| to_json
