Here’s my zwave config (which is the right path)
zwave:
usb_path: /dev/ttyACM0
polling_interval: 30000
config_path: /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/libopenzwave-0.3.2-py3.4-linux-armv7l.egg/config
customize:
switch.ge_12722_onoff_relay_switch_switch_2_0:
polling_intensity: 1
refresh_value: true
light.ge_12724_3way_dimmer_switch_level_4_0:
refresh_value: true
delay: 3
When I shutdown HA and try to open the ozwcp panel I get this:
pi@homeassistant:/srv/homeassistant/src/open-zwave-control-panel $ sudo ./ozwcp -p 8888
2017-02-11 13:32:45.875 Error, Cannot find a path to the configuration files at ./config/. Exiting…
2017-02-11 13:32:45.875 Error, Exception: Options.cpp:91 - 1 - Cannot Find Configuration Files
I know it has something to do with a symlink but I can’t figure it out.
