I’ve just successfully got my Z-wave network up & running with the OpenZWave add-in with MQTT and ozwdaemon rolled in with the help in this thread… and now the network will not come back up. I’ve restarted HA server, restarted the add-on, but the integration simply will not connect. Here is the information from the logs following a restart of the add-on:
[20210125 12:19:47.131 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/requestnodestate/")
[20210125 12:19:47.131 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "sendnodeinformation"
[20210125 12:19:47.131 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/sendnodeinformation/")
[20210125 12:19:47.131 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "setpollinterval"
[20210125 12:19:47.131 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/setpollinterval/")
[20210125 12:19:47.135 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "setvalue"
[20210125 12:19:47.136 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/setvalue/")
[20210125 12:19:47.136 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "softresetcontroller"
[20210125 12:19:47.136 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/softresetcontroller/")
[20210125 12:19:47.136 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "syncronisenodeneighbors"
[20210125 12:19:47.136 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/syncronisenodeneighbors/")
[20210125 12:19:47.136 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "testnetwork"
[20210125 12:19:47.136 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/testnetwork/")
[20210125 12:19:47.136 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "testnetworknode"
[20210125 12:19:47.136 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/testnetworknode/")
[20210125 12:19:47.139 EST] [ozw.mqtt.publisher] [debug]: Topics: "OpenZWave/1/status/"
[20210125 12:19:47.461 EST] [ozw.library] [info]: Info - Node: 0 Lookup for mfs.db.openzwave.com returned 151
ozwadmin: Settings Path: "/root/.config/OpenZWave/ozw-admin.conf"
ozwadmin: Using Saved Network Cache Size: 1000
QT_MESSAGE_PATTERN: %{backtrace} is not supported by this Qt build
[20210125 12:19:47.710 EST] [ozwadmin] [info]: OZWCore Initilized QTOpenZwave(0x7f82224c20) QTOZWManager(0x55a39b4ac0)
[20210125 12:19:47.817 EST] [default] [warning]: QVncServer created on port 5900
[20210125 12:19:49.870 EST] [ozw.library] [info]: Info - Node: 0 Queuing download for http://download.db.openzwave.com/images/shenzen_neo/nas-sc03ze.jpg (Node 0)
[20210125 12:19:49.871 EST] [ozw.library] [info]: Info - Node: 0 Missing Picture /data/ozw/config/images/shenzen_neo/nas-sc03ze.jpg - Starting Download
[20210125 12:19:49.872 EST] [ozw.library] [debug]: Debug - Node: 0 Download Starting for http://download.db.openzwave.com/images/shenzen_neo/nas-sc03ze.jpg (/data/ozw/config/images/shenzen_neo/nas-sc03ze.jpg)
[20210125 12:19:50.394 EST] [ozw.library] [info]: Info - Node: 0 Queuing download for http://download.db.openzwave.com/images/namron/4512714.jpg (Node 0)
[20210125 12:19:50.395 EST] [ozw.library] [info]: Info - Node: 0 Missing Picture /data/ozw/config/images/namron/4512714.jpg - Starting Download
[20210125 12:19:50.395 EST] [ozw.library] [debug]: Debug - Node: 0 Download Starting for http://download.db.openzwave.com/images/namron/4512714.jpg (/data/ozw/config/images/namron/4512714.jpg)
[20210125 12:19:50.453 EST] [ozw.library] [debug]: Debug - Node: 0 Downloads Remaining: 2
[20210125 12:19:50.454 EST] [ozw.library] [warning]: Warning - Node: 0 Download of http://download.db.openzwave.com/images/shenzen_neo/nas-sc03ze.jpg Failed (Node: 0)
[20210125 12:19:50.454 EST] [ozw.library] [debug]: Debug - Node: 0 Downloads Remaining: 1
[20210125 12:19:50.454 EST] [ozw.library] [debug]: Detail - Node: 0 Notification: A Config File Failed to download
[20210125 12:19:50.455 EST] [ozw.notifications] [debug]: Notification pvt_ozwUserAlert NotificationTypes::Notification_User_ConfigFileDownloadFailed Thread: 0x7fae2dfe38
[20210125 12:19:50.455 EST] [ozw.mqtt.publisher] [debug]: Publishing Event ozwUserAlert
[20210125 12:19:50.468 EST] [ozw.library] [warning]: Warning - Node: 0 Download of http://download.db.openzwave.com/images/namron/4512714.jpg Failed (Node: 0)
[20210125 12:19:50.468 EST] [ozw.library] [debug]: Debug - Node: 0 Downloads Remaining: 0
[20210125 12:19:50.468 EST] [ozw.library] [info]: Info - Node: 0 ManufacturerSpecificDB Initialized
[20210125 12:19:50.469 EST] [ozw.library] [debug]: Detail - Node: 0 Notification: A Config File Failed to download
[20210125 12:19:50.469 EST] [ozw.library] [debug]: Detail - Node: 0 Notification: ManufacturerSpecificDB Ready
[20210125 12:19:50.469 EST] [ozw.notifications] [debug]: Notification pvt_ozwUserAlert NotificationTypes::Notification_User_ConfigFileDownloadFailed Thread: 0x7fae2dfe38
[20210125 12:19:50.469 EST] [ozw.library] [info]: Info - Node: 255 Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
[20210125 12:19:50.470 EST] [ozw.library] [info]: Info - Node: 255 Encrypted Flag is 0
[20210125 12:19:50.470 EST] [ozw.mqtt.publisher] [debug]: Publishing Event ozwUserAlert
[20210125 12:19:50.470 EST] [ozw.notifications] [debug]: Notification pvt_manufacturerSpecificDBReady Thread: 0x7fae2dfe38
[20210125 12:19:50.470 EST] [ozw.mqtt.publisher] [debug]: Publishing Event manufacturerSpecificDBReady
1611595190: New connection from 172.30.32.1 on port 1883.
1611595190: New client connected from 172.30.32.1 as 3tp5gYZqX6e97OAle9uWhE (p2, c1, k60, u'homeassistant').
WebSocket server settings:
- Listen on :8099
- Web server. Web root: /usr/share/novnc
- No SSL/TLS support (no cert file)
- proxying from :8099 to 127.0.0.1:5900
[20210125 12:20:00.468 EST] [ozw.library] [info]: Info - Node: 0 HttpThread Exiting. No Transfers in timeout period
[20210125 12:20:00.471 EST] [ozw.library] [critical]: Error - Node: 255 ERROR: Dropping command, expected response not received after 1 attempt(s). Command: "FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9"
[20210125 12:20:00.471 EST] [ozw.library] [debug]: Detail - Node: 255 Removing current message
[20210125 12:20:00.471 EST] [ozw.library] [debug]: Detail - Node: 255 Notification: Notification - TimeOut
[20210125 12:20:00.472 EST] [ozw.notifications] [debug]: Notification pvt_ozwNotification NotificationTypes::Notification_Code_MsgTimeout Thread: 0x7fae2dfe38
[20210125 12:20:00.473 EST] [ozw.mqtt.publisher] [debug]: Publishing Event ozwNotification
[20210125 12:20:47.404 EST] [ozw.mqtt.publisher] [debug]: "Mon Jan 25 12:20:47 2021 PingResponse\n"
[20210125 12:21:47.287 EST] [ozw.mqtt.publisher] [debug]: "Mon Jan 25 12:21:47 2021 PingResponse\n"
[20210125 12:22:47.252 EST] [ozw.mqtt.publisher] [debug]: "Mon Jan 25 12:22:47 2021 PingResponse\n"
[20210125 12:23:47.294 EST] [ozw.mqtt.publisher] [debug]: "Mon Jan 25 12:23:47 2021 PingResponse\n"
[20210125 12:24:47.295 EST] [ozw.mqtt.publisher] [debug]: "Mon Jan 25 12:24:47 2021 PingResponse\n"
[20210125 12:25:47.242 EST] [ozw.mqtt.publisher] [debug]: "Mon Jan 25 12:25:47 2021 PingResponse\n"
[20210125 12:26:47.295 EST] [ozw.mqtt.publisher] [debug]: "Mon Jan 25 12:26:47 2021 PingResponse\n"
[20210125 12:27:47.253 EST] [ozw.mqtt.publisher] [debug]: "Mon Jan 25 12:27:47 2021 PingResponse\n"
In exit
[20210125 12:28:36.454 EST] [ozw.daemon] [info]: Recieved SIGTERM: Shutting down ozwdaemon
1611595716: mosquitto version 1.6.8 terminating
1611595716: Saving in-memory database to /data/mosquitto.db.
[20210125 12:28:36.646 EST] [ozw.library] [debug]: Detail - Node: 0 Notification: DriverRemoved
[20210125 12:28:36.713 EST] [ozw.notifications] [debug]: Notification pvt_driverRemoved 0 Thread: 0x7fae2dfe38
[20210125 12:28:36.798 EST] [ozw.mqtt.publisher] [debug]: Publishing Event stopped
[20210125 12:28:36.817 EST] [ozw.mqtt.publisher] [debug]: Publishing Event driverRemoved: 0
[20210125 12:28:36.857 EST] [ozw.mqtt.publisher] [debug]: MQTT State Change "Disconnected"
[20210125 12:28:36.857 EST] [ozw.mqtt.publisher] [warning]: Exiting on Failure
[20210125 12:28:36.857 EST] [ozw.mqtt.publisher] [warning]: MQTT Client Disconnnected
[20210125 12:28:36.857 EST] [ozw.mqtt.publisher] [warning]: MQTT Client Error "Transport Invalid"
[20210125 12:28:36.858 EST] [ozw.library] [debug]: Always - Node: 0 ***************************************************************************
[20210125 12:28:36.858 EST] [ozw.library] [debug]: Always - Node: 0 ********************* Cumulative Network Statistics *********************
[20210125 12:28:36.858 EST] [ozw.library] [debug]: Always - Node: 0 *** General
[20210125 12:28:36.858 EST] [ozw.library] [debug]: Always - Node: 0 Driver run time: . . . 0 days, 0 hours, 8 minutes
[20210125 12:28:36.858 EST] [ozw.library] [debug]: Always - Node: 0 Frames processed: . . . . . . . . . . . . . . . . . . . . 0
[20210125 12:28:36.858 EST] [ozw.library] [debug]: Always - Node: 0 Total messages successfully received: . . . . . . . . . . 0
[20210125 12:28:36.858 EST] [ozw.library] [debug]: Always - Node: 0 Total Messages successfully sent: . . . . . . . . . . . . 1
[20210125 12:28:36.858 EST] [ozw.library] [debug]: Always - Node: 0 ACKs received from controller: . . . . . . . . . . . . . 1
[20210125 12:28:36.858 EST] [ozw.library] [debug]: Always - Node: 0 *** Errors
[20210125 12:28:36.858 EST] [ozw.library] [debug]: Always - Node: 0 Unsolicited messages received while waiting for ACK: . . 0
[20210125 12:28:36.859 EST] [ozw.library] [debug]: Always - Node: 0 Reads aborted due to timeouts: . . . . . . . . . . . . . 0
[20210125 12:28:36.859 EST] [ozw.library] [debug]: Always - Node: 0 Bad checksum errors: . . . . . . . . . . . . . . . . . . 0
[20210125 12:28:36.859 EST] [ozw.library] [debug]: Always - Node: 0 CANs received from controller: . . . . . . . . . . . . . 0
[20210125 12:28:36.859 EST] [ozw.library] [debug]: Always - Node: 0 NAKs received from controller: . . . . . . . . . . . . . 0
[20210125 12:28:36.859 EST] [ozw.library] [debug]: Always - Node: 0 Out of frame data flow errors: . . . . . . . . . . . . . 0
[20210125 12:28:36.859 EST] [ozw.library] [debug]: Always - Node: 0 Messages retransmitted: . . . . . . . . . . . . . . . . . 0
[20210125 12:28:36.859 EST] [ozw.library] [debug]: Always - Node: 0 Messages dropped and not delivered: . . . . . . . . . . . 1
[20210125 12:28:36.859 EST] [ozw.library] [debug]: Always - Node: 0 ***************************************************************************
[20210125 12:28:36.864 EST] [ozw.library] [warning]: Warning - Node: 0 WARNING: Tried to write driver config with no home ID set
[20210125 12:28:36.896 EST] [ozw.library] [info]: Info - Node: 0 Stopping DNSThread
[cont-finish.d] executing container finish scripts...
[cont-finish.d] mqtt.sh: executing...
[12:28:56] INFO: Connected to internal MQTT service
[cont-init.d] mqtt.sh: exited 0.
[cont-init.d] network_key.sh: executing...
[cont-init.d] network_key.sh: exited 0.
[cont-init.d] novnc.sh: executing...
[cont-init.d] novnc.sh: exited 0.
[cont-init.d] structure.sh: executing...
[cont-init.d] structure.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[12:28:58] INFO: Starting internal MQTT broker...
1611595738: mosquitto version 1.6.8 starting
1611595738: Config loaded from /etc/mosquitto.conf.
1611595738: Opening ipv4 listen socket on port 1883.
1611595738: Opening ipv6 listen socket on port 1883.
1611595738: Warning: Mosquitto should not be run as root/administrator.
1611595738: Connecting bridge main-mqtt (core-mosquitto:1883)
[20210125 12:29:07.839 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/close/")
[20210125 12:29:07.839 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "deleteallreturnroute"
[20210125 12:29:07.839 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/deleteallreturnroute/")
[20210125 12:29:07.839 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "disablepoll"
[20210125 12:29:07.840 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/disablepoll/")
[20210125 12:29:07.840 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "downloadlatestconfigfilerevision"
[20210125 12:29:07.840 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/downloadlatestconfigfilerevision/")
[20210125 12:29:07.840 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "downloadlatestmfsrevision"
[20210125 12:29:07.840 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/downloadlatestmfsrevision/")
[20210125 12:29:07.840 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "enablepoll"
[20210125 12:29:07.840 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/enablepoll/")
[20210125 12:29:07.840 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "getpollinterval"
[20210125 12:29:07.840 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/getpollinterval/")
[20210125 12:29:07.840 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "hardresetcontroller"
[20210125 12:29:07.840 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/hardresetcontroller/")
[20210125 12:29:07.841 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "hasnodefailed"
[20210125 12:29:07.841 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/hasnodefailed/")
[20210125 12:29:07.841 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "healnetwork"
[20210125 12:29:07.841 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/healnetwork/")
[20210125 12:29:07.841 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "healnetworknode"
[20210125 12:29:07.841 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/healnetworknode/")
[20210125 12:29:07.841 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "isnodefailed"
[20210125 12:29:07.841 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/isnodefailed/")
[20210125 12:29:07.841 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "open"
[20210125 12:29:07.841 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/open/")
[20210125 12:29:07.841 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "ping"
[20210125 12:29:07.842 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/ping/")
[20210125 12:29:07.842 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "refreshnodeinfo"
[20210125 12:29:07.842 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/refreshnodeinfo/")
[20210125 12:29:07.842 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "refreshvalue"
[20210125 12:29:07.842 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/refreshvalue/")
[20210125 12:29:07.842 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "removeassociation"
[20210125 12:29:07.842 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/removeassociation/")
[20210125 12:29:07.842 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "removefailednode"
[20210125 12:29:07.842 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/removefailednode/")
[20210125 12:29:07.842 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "removenode"
[20210125 12:29:07.842 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/removenode/")
[20210125 12:29:07.843 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "replacefailednode"
[20210125 12:29:07.843 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/replacefailednode/")
[20210125 12:29:07.843 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "requestallconfigparam"
[20210125 12:29:07.843 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/requestallconfigparam/")
[20210125 12:29:07.843 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "requestconfigparam"
[20210125 12:29:07.843 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/requestconfigparam/")
[20210125 12:29:07.843 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "requestnetworkupdate"
[20210125 12:29:07.843 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/requestnetworkupdate/")
[20210125 12:29:07.843 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "requestnodedynamic"
[20210125 12:29:07.843 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/requestnodedynamic/")
[20210125 12:29:07.843 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "requestnodeneighborupdate"
[20210125 12:29:07.843 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/requestnodeneighborupdate/")
[20210125 12:29:07.843 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "requestnodestate"
[20210125 12:29:07.844 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/requestnodestate/")
[20210125 12:29:07.844 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "sendnodeinformation"
[20210125 12:29:07.844 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/sendnodeinformation/")
[20210125 12:29:07.844 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "setpollinterval"
[20210125 12:29:07.844 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/setpollinterval/")
[20210125 12:29:07.844 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "setvalue"
[20210125 12:29:07.844 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/setvalue/")
[20210125 12:29:07.844 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "softresetcontroller"
[20210125 12:29:07.844 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/softresetcontroller/")
[20210125 12:29:07.844 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "syncronisenodeneighbors"
[20210125 12:29:07.845 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/syncronisenodeneighbors/")
[20210125 12:29:07.845 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "testnetwork"
[20210125 12:29:07.845 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/testnetwork/")
[20210125 12:29:07.845 EST] [ozw.mqtt.commands] [debug]: Creating Subscription for "testnetworknode"
[20210125 12:29:07.845 EST] [ozw.mqtt.commands] [debug]: Subscription Setup for QMqttTopicFilter("OpenZWave/1/command/testnetworknode/")
[20210125 12:29:07.846 EST] [ozw.mqtt.publisher] [debug]: Topics: "OpenZWave/1/status/"
[20210125 12:29:07.900 EST] [ozw.library] [info]: Info - Node: 0 Lookup for mfs.db.openzwave.com returned 151
[20210125 12:29:08.209 EST] [ozwadmin] [info]: OZWCore Initilized QTOpenZwave(0x7fad84ec20) QTOZWManager(0x55c3182b40)
[20210125 12:29:08.319 EST] [default] [warning]: QVncServer created on port 5900
[20210125 12:29:10.966 EST] [ozw.library] [info]: Info - Node: 0 Queuing download for http://download.db.openzwave.com/images/shenzen_neo/nas-sc03ze.jpg (Node 0)
[20210125 12:29:10.968 EST] [ozw.library] [info]: Info - Node: 0 Missing Picture /data/ozw/config/images/shenzen_neo/nas-sc03ze.jpg - Starting Download
[20210125 12:29:10.969 EST] [ozw.library] [debug]: Debug - Node: 0 Download Starting for http://download.db.openzwave.com/images/shenzen_neo/nas-sc03ze.jpg (/data/ozw/config/images/shenzen_neo/nas-sc03ze.jpg)
- Listen on :8099
[20210125 12:29:11.504 EST] [ozw.library] [info]: Info - Node: 0 Queuing download for http://download.db.openzwave.com/images/namron/4512714.jpg (Node 0)
[20210125 12:29:11.505 EST] [ozw.library] [info]: Info - Node: 0 Missing Picture /data/ozw/config/images/namron/4512714.jpg - Starting Download
[20210125 12:29:11.505 EST] [ozw.library] [debug]: Debug - Node: 0 Download Starting for http://download.db.openzwave.com/images/namron/4512714.jpg (/data/ozw/config/images/namron/4512714.jpg)
[20210125 12:29:11.658 EST] [ozw.library] [debug]: Debug - Node: 0 Downloads Remaining: 2
[20210125 12:29:11.659 EST] [ozw.library] [warning]: Warning - Node: 0 Download of http://download.db.openzwave.com/images/shenzen_neo/nas-sc03ze.jpg Failed (Node: 0)
[20210125 12:29:11.659 EST] [ozw.library] [debug]: Debug - Node: 0 Downloads Remaining: 1
[20210125 12:29:11.685 EST] [ozw.library] [debug]: Detail - Node: 0 Notification: A Config File Failed to download
[20210125 12:29:11.735 EST] [ozw.library] [warning]: Warning - Node: 0 Download of http://download.db.openzwave.com/images/namron/4512714.jpg Failed (Node: 0)
[20210125 12:29:11.735 EST] [ozw.library] [debug]: Debug - Node: 0 Downloads Remaining: 0
[20210125 12:29:11.736 EST] [ozw.library] [info]: Info - Node: 0 ManufacturerSpecificDB Initialized
[20210125 12:29:11.736 EST] [ozw.library] [debug]: Detail - Node: 0 Notification: A Config File Failed to download
[20210125 12:29:11.736 EST] [ozw.library] [debug]: Detail - Node: 0 Notification: ManufacturerSpecificDB Ready
[20210125 12:29:11.737 EST] [ozw.library] [info]: Info - Node: 255 Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
[20210125 12:29:11.737 EST] [ozw.library] [info]: Info - Node: 255 Encrypted Flag is 0
[20210125 12:29:11.763 EST] [ozw.notifications] [debug]: Notification pvt_ozwUserAlert NotificationTypes::Notification_User_ConfigFileDownloadFailed Thread: 0x7fb8fa1e38
[20210125 12:29:11.830 EST] [ozw.mqtt.publisher] [debug]: Publishing Event ozwUserAlert
[20210125 12:29:11.831 EST] [ozw.notifications] [debug]: Notification pvt_ozwUserAlert NotificationTypes::Notification_User_ConfigFileDownloadFailed Thread: 0x7fb8fa1e38
[20210125 12:29:11.832 EST] [ozw.mqtt.publisher] [debug]: Publishing Event ozwUserAlert
[20210125 12:29:11.832 EST] [ozw.notifications] [debug]: Notification pvt_manufacturerSpecificDBReady Thread: 0x7fb8fa1e38
[20210125 12:29:11.832 EST] [ozw.mqtt.publisher] [debug]: Publishing Event manufacturerSpecificDBReady
[20210125 12:30:08.258 EST] [ozw.mqtt.publisher] [debug]: "Mon Jan 25 12:30:08 2021 PingResponse\n"
What’s gone wrong now? Thanks for looking.
