I need to perform operations on collections (lists?) in YAML to get some values that I need from OpenWeatherMap.
The things I need to expose are:
- Does the condition become ‘foggy’, ‘misty’ or ‘smoky’ in the next 24 hours
- The maximum humidity figure in the next 24 hours
- The maximum hourly precipitation in the next 24 hours
- The total precipitation for the next 24 hours
- The maximum wind speed in the next 24 hours
- The maximum and minimum temperatures in the next 24 hours
In the Template editor in Development Tools, I can see the values that I need and do basic tests on them, but I’m new to this and am hoping that there is a nicer way to do things than what I have currently. The following is the code for checking if it becomes ‘foggy’, ‘misty’ or ‘smoky’ in the next 24 hours. Is there a better way of doings this? Would generating maximums, minimums or totals be done in much the same way, or are there shorter/faster ways of doing things?
{%- set data = namespace(res=false) -%}
{% set attrs = states.weather.openweathermap.attributes %}
{% for i in range(0, 23) %}
{% if attrs['forecast'][i].condition in ["foggy", "misty", "smoky"] %}
{%- set data.res = true -%}
{% if not loop.last %}
{% break %}
{% endif %}
{% endif %}
{% endfor %}
{{data.res}}
