OPNsense API & Home Assistant no longer working for me
I upgraded OPNsense from 20.7.8 to 21.1.1 last night. Ever since, my Home Assistant instance is no longer able to communicate with OPNsense via the API. The error I see in Home Assistant is shown below.
For good measure, after first seeing the issue this morning, I generated a new key/secret pair in OPNsense and changed the HA configuration accordingly, just to verify that the old key/secret weren’t the issue, but the problem persists. As an FYI, as you can see from below errors, my OPNsense WebUI is running on port 4444, as I am running the OPNsense Nginx plugin on port 443.
I posted the same in the OPNsense forum here, as to me it looks to be more an issue with the new version. But I wanted to leave this here as well, in case other HA users are experiencing the same.
Log Details (ERROR)
Logger: homeassistant.setup
Source: components/opnsense/__init__.py:53
First occurred: 8:13:42 AM (1 occurrences)
Last logged: 8:13:42 AM
Error during setup of component opnsense
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 445, in _make_request
    six.raise_from(e, None)
  File "<string>", line 3, in raise_from
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 440, in _make_request
    httplib_response = conn.getresponse()
  File "/usr/local/lib/python3.8/http/client.py", line 1347, in getresponse
    response.begin()
  File "/usr/local/lib/python3.8/http/client.py", line 307, in begin
    version, status, reason = self._read_status()
  File "/usr/local/lib/python3.8/http/client.py", line 268, in _read_status
    line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
  File "/usr/local/lib/python3.8/socket.py", line 669, in readinto
    return self._sock.recv_into(b)
  File "/usr/local/lib/python3.8/ssl.py", line 1241, in recv_into
    return self.read(nbytes, buffer)
  File "/usr/local/lib/python3.8/ssl.py", line 1099, in read
    return self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
  File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
    resp = conn.urlopen(
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 755, in urlopen
    retries = retries.increment(
  File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 531, in increment
    raise six.reraise(type(error), error, _stacktrace)
  File "/usr/local/lib/python3.8/site-packages/urllib3/packages/six.py", line 735, in reraise
    raise value
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 699, in urlopen
    httplib_response = self._make_request(
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 447, in _make_request
    self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 336, in _raise_timeout
    raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='192.168.5.1', port=4444): Read timed out. (read timeout=5)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 213, in _async_setup_component
    result = await task
  File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/usr/src/homeassistant/homeassistant/components/opnsense/__init__.py", line 53, in setup
    interfaces_client.get_arp()
  File "/usr/local/lib/python3.8/site-packages/pyopnsense/diagnostics.py", line 52, in get_arp
    return self._get('diagnostics/interface/getArp')
  File "/usr/local/lib/python3.8/site-packages/pyopnsense/client.py", line 51, in _get
    response = requests.get(req_url, verify=self.verify_cert,
  File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 76, in get
    return request('get', url, params=params, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 61, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 542, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 655, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 529, in send
    raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='192.168.5.1', port=4444): Read timed out. (read timeout=5)
same here,
OPNsense 21.1.1
Homeassistant 2021.2.0
for everyone facing this issue:
You can find an OPNsense custom integration made by @travisghansen with all the bells and whistles here: OPNsense Integration - Third party integrations - Home Assistant Community (home-assistant.io)
