if anyone is concerned about cooking a RPi outside in their Supervisor box, I can say that the 109F outdoor we had today in my part of the world, my RPi 3b never got above 61C, which is well inside the operating temp range of my device… my unit is running in my Supervisor case, within its own plastic case, heatsinks & a small running fan…
Found a way where you do not need a raspberry pi or another computer.
First you need a RJ45 splitter and bring a cat5 or cat6. (Cat5 is more than enough). Plug a patch cable to the splitter and to the customer lan port and another to the installer port.
Disable port in your router that you will use to connect to the installer port. And also remove port from your lan bridge
Inside your house plug in the customer lan port to a port that is part of your lan bridge that has your lan dhcp. (Used for connecting your Sunpower monitor to internet and to get data to Sunpower). Connect the side of the splitter with a patch cable for the installer port to your disable port in your router.
In your router create a new IP address I used 172.27.153.2/24 with network configured as 172.27.153.0 and set the interface as the port I will have the installer port connected to on my router. Then enable port again.
Now on a computer in your local network use the below url.
Well, it took more than a week, but it’s installed, and it’s Wi-Fi with an IP address of my subnet, so dhcp issues might be a thing of the past for new installations.
Just confirming: you’re doing this on the second Ethernet port, right, not the first one? The first one is for the uplink from the PVS to Sunpower, and the API endpoints are not available there.
Thanks so much for posting this info! My PVS6 bit the dust and was just replaced with one of these new “W” ones. It threw me when I opened it back up to pop my Raspberry Pi in it. Just ordered one of the approved dongles since my existing one doesn’t work.
I tried a pluggable USB dongle in LAN1 and WAN ports in the newer PVS6 box and no matter what I don’t get DHCP leases and when I set a static IP on the same 172.27.153.0 subset, I cant ping 172.27.153.1…
Which dongle (model number) did you try? Can you post a diagram showing how you have connected everything (including the PVS6-W, the dongle, your router/DHCP server, etc.)?
Anyone kind enough to help me understand the advantages/disadvantages of going with an integration like this vs an energy monitoring system? There are many on the market, here is an example: Amazon.com
An energy monitoring system isn’t going to give you per-inverter (panel) details.
An energy monitoring system will involve additional hardware of some kind.
If that particular monitoring system is available for you (it claims to be limited to only customers of a specific utility), then it may be useful but for the rest of us it is not
I just had my SunPower system installed with the new PVS6 w/o any RJ45 ethernet ports. I followed the instructions to configure a Pi Zero W and purchased the USB-Ethernet dongle that is suggested for the PVS6.
The issue I am having is that the IP address that the PVS6 is issuing to the PI eth0 on the PVS6 LAN port is 169.254.218.110. I do se link lights on both the dongle and PI but the IP address is not looking right.
