How much more powerful? I have been thinking of upgrading for a while, but I haven’t seen any figures comparing this with the Pi. If it is that big a jump it would be worth risking the incompatibility, but its hard to make that sort of judgement with some real data.
Yes, I read the specs, but that gives me no feel about how much faster it would be (1.5, 10 or 100). I’m just looking for some kind of real world comparison to see if it would be worth buying that instead of a Pi 3, or the Odroid HC1, which is another option I am considering.
I recall watching a video comparing the performance of several single-board computers. I think it was from the ExplainingComputers series (it may have been this one). Anyway, one SBC device had superior hardware specs compared to the others contestants. In pure number-crunching tests, it was the fastest. However, in real-world tests (execution of various software applications) the Raspberry Pi 3 proved to be either its equal or even faster. Why? Operating system optimizations.
That’s why just comparing SBC hardware specs isn’t always the best way to predict real-world performance.
Unlike the Raspberry Pi, the Orange Pi 3 also lists Android 7.0 as being officially supported on the board, alongside Ubuntu and Debian. That said, none of these OS images are available via the Orange Pi download page as yet, although there are early builds for operating systems designed to run on the Allwinner H6 system-on-a-chip used by the Orange Pi 3.
That throws up the bigger issue when buying rival boards to the Raspberry Pi, which is few competitors offer the same range of stable operating systems and software, and none have such a large online community who can help you if you run into issues.
So whether one uses an SBC or not, when it comes to comes to comparing them, specs alone are not necessarily accurate predictions of real-world performance.
Nevertheless, it’s nice to have choices and I Iook forward to seeing this device reviewed.
I recommend you consider switching to a platform that has an Intel-based CPU (Linux based on Intel architecture usually has a wider availability of drivers), allows you to expand RAM (handy if you plan to run much more than just Home Assistant) and can easily use an SSD for booting and general storage (expandable, fast, reliable).
There are many posts on this forum by people who have had success switching to the Intel NUC platform. However, it doesn’t have to be a NUC. It could even be an old netbook or mini desktop.
However, one of the problems with using computers not designed to operate like servers is that they cannot be configured to auto-start after a power failure. I’m using an old HP Stream Mini (not for Home Assistant but for another purpose; found one for CDN$100) and its BIOS permits auto-restart after power failure (as do many Single-Board Computers like the RPi as well as Intel NUC). I want to buy another used one but they’re very hard to find (they were discontinued over 3 years ago). Keep that in mind when shopping for a new computer.
EDIT
FWIW, I’m running Home Assistant on a ten year-old netbook (Intel Atom 270) running Lubuntu. It takes about 10 seconds to start Home Assistant … BUT it only uses MQTT-based entities and the Homekit component. There’s almost no time-consuming discovery process (of things like Zwave and Zigbee devices) so that helps to explain why it is speedy. I plan to move it to a mini desktop.
It depends on what you plan to run on it. There are owners of Intel NUCs who chose i7 processors because they also intend to run many others applications including using them as Network Video Recorders (NVRs). If all you want to do is run Home Assistant, an i7 is far more than is necessary.
Intel Atom N270 (my HP netbook running Home Assistant)
Intel Celeron 2957u (my HP Stream Mini)
You’ll notice the J3455 is well ahead of the N270. Yet, for the way I use Home Assistant, I can’t complain about its performance on the netbook (equipped with the N270).
I currently use an RPi 1 B+ to run HA, with 500MB, and 150MB free, so that isn’t a problem.
Its been running for about 4 years now (openhab first, then HA) without any SD Card issues, so that isn’t a problem.
I just need more processing power now because in the last few HA releases the sensor response time has become unacceptably slow for turning on lights, and so I’m looking for comparisons on that. As @123 points out, specs don’t always tell the whole story, and I was looking for some real world comparisons.
@123
from benchmark data seem J3455 have good performances, its price is about 120 eur (without ssd and ram)
could be interesting to find a used Intel NUC6CAYH
I have been playing with an ODroid HC1 ($40 - $60) for the last 2 days running the beta HassOS distribution for ODroid XU4. ODroid is a competitor to Orange Pi so this is somewhat off topic for this thread. I started a new thread with my experience using this SBC: HassOS on ODroid HC1 (compatible with XU4).
