I love my set up now, if you are looking at going away from an SBC, NUCs are a great option.
Does bluetooth_tracker works with your NUC?
I have a NUC8I3BEH and intsalled Hassio in a vm in VIrtualbox⌠loading a vid imageâŚ
Virtualbox detect intel bluetooth device⌠bat Hassio donât recognize it.
I canât answer that, I use the Unifi WiFi tracking component for around the house, and Zanzito via MQTT for GPS tracking.
bluetooth tracker is very very fast to detect people in and out of house, more fast tha any wifi device.
I use bluetooth in addiction to router wifi detection.
If you had Ubiquiti equipment and use Unifi tracking component, you wouldnât make this comment. But if you are happy using Bluetooth, then no problem.
Iâm using the Orange Pi 3. I donât know how useful my review will be, since this is my first Home Assistant install, so I donât really have a basis for comparison. I of course wasnât able to use hass.io or any of the other simpler installation methods, but using the Ubuntu Server image from the Orange Pi site, I was able to follow the venv instructions for installing Home Assistant, and itâs been working great. (one thing to note here: the gpio
group does not exist on the Orange Pi Ubuntu Server image, so I had to leave that out - not sure whether that will impact the ability to access the GPIO pins) The only issue Iâve run into so far is something Iâm pretty sure is a software/configuration issue: I sometimes am unable to get the frontend to load over the Tor Hidden Service Iâve set up.
In summary: this seems to be very capable hardware, and hasnât given me any trouble. It helps that Iâm rather familiar with Linux since I wasnât able to use one of the more ready-made installation methods, but itâs been pretty smooth sailing so far.
That link isnât working for me, do you have another?
Did you tried the Orange Pi Prime Hassio image on your Orange Pi 3?
The Hassio image wonât work for Orange Pi 3 until Hassio is released using at least the Linux 5.2 kernel, which probably wonât happen until Linux releases a new Long Term Support release for Linux 5.x, as it seems to me Hassio is using only LTS releases of Linux kernel. Maybe the OrangePi 3 board support will be backported to 4.14 (used by Hassio) or 4.19 (latest LTS), in which case it can be supported by Hassio.
Some info here:
https://linux-sunxi.org/Xunlong_Orange_Pi_3
I just installed hass.io on my Orange Pi 3 âUbuntu Bionic with Armbian Linux 5.3.9-sunxi64â
Havenât tried it very much, but it starts and I am able to create a user.
I used the orangepi-prime setting on the curl command line
Bluetooth and wifi works without problems with system on ssd USB 3.0 and with rflink/conbee II? I ask for it because that things doesnât work properly on raspberry pi 4.
@magpern , por favor, compartilha a imagem de seu home assistant orange pi. Obrigado
Hola eduardo - ÂżQuĂŠ Tal?
You can install armbian on your sbc and than install HA Container, Core or Supervised (the later officially unsupported for armbian)
