Hi all. I have transplanted an esp 12e into a Bunnings “Orion garage door controller”. I thought I would share my journey.
https://www.bunnings.com.au/orion-grid-connect-smart-garage-door-controller-with-sensor_p0261686
I transplanted an esp 12e in its place. Complete with the infamous GPIO 15 to ground solder blob😂
Not sure if I damaged the little transistor or what was going on with the 10,000,000 ohm resistor so I tied it all backwards on the magnetic reed pin(GPIO 12). The bridge over the left hand resistor is highly not needed I just wanted 3.3v back to the pin.
Here’s my esphome yaml
esphome:
platform: ESP8266
board: esp12e
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: !secret ota_password
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Garage-Door Fallback Hotspot"
password: !secret fallback_password
captive_portal:
web_server:
port: 80
#binary function for button
binary_sensor:
- platform: gpio
pin:
number: GPIO4
inverted: True
name: Garage Door Button Status
on_press:
- switch.toggle: relay_template
internal: true
#binary function for reed switch
- platform: gpio
device_class: garage_door
pin:
number: GPIO12
inverted: true
mode:
input: true
pullup: true
# LED setup
light:
- platform: monochromatic
output: LED_output
internal: true
output:
- platform: esp8266_pwm
pin:
number: GPIO5
inverted: true
#switch fuction for button
switch:
- platform: gpio
pin: GPIO4
inverted: True
# manual control of the relay
- platform: gpio
pin: GPIO13
internal: true
# Tie relay, LED and button together
internal: true
turn_on_action:
- light.turn_on: LED
- switch.turn_on: relay
- switch.turn_on: button_switch
- delay: 1s
- light.turn_off: LED
- switch.turn_off: relay
- switch.turn_off: button_switch
I hope this helps out someone looking at the same thing. And would also be happy to hear how others did it too.
Enjoy,
