The amcrest is not availible in the netherlands or high shipping costs.
Anyone has a good one with same specs ?
Gr, marco.
Gr, marco.
I ended picking the Amcrest IP5M-D1188EW-28MM and I’m super happy with it. I prefer the dome style cameras and it’s pretty easy to be found on EU. Also it has all features one will need for most cam servers out there. I would buy another if I required.
What’s the current state on using reolink cameras? FW upgrade required and then reduced resolution for h264 for them to work with frigate?
For the RLC-520A it should be plug and play since the camera is H264?
I see the Amcrest IP8M-T2599EW have “Dual H.265/H.264 compression”, so presumably they would work for frigate using H264, but would it then be in 4K or reduced resolution? Is the Amcrest IP8M-T2599EW otherwise simple to set up in frigate?
