Hi! About the redirection issue, it happened to me also some times. As you said, if the URL you set and the url you see are the same, the issue come from the Somfy server sadly. For your 2nd issue, apparently, you have to wait for the sync between all the Somfy server afterwhile it will be ok.
I suggest you to switch to the cloud choice with this integration. There is no privacy concern, and it will work out of the box.
Itâs really nice to have both solution working at the same time. Once a KLF200 found at a good price, I will still be able to maintain my component! Thx for this information.
How can we get Somfy working for us? The Tahoma integration is EOS/EOL and this API should be the way but still doesnât support all Somfy devices. How can we get the development in action so that all possible Somfy devices can be controlled by the official API. I really hate those half solutions when I still need to use to old Somfy app to control my awning as example.
Is it in any way possible to utilize the âMy Positionâ command using the official Somfy API?
It works with the Tahoma integration, because the Tahoma cover.stop_cover command translates into a My position RTS in the somfy platform, when the blind is initially at standstil.
With the new Somfy API, the cover.stop_cover only translates into a stop/abort command, and therefore doesnât trigger the My Positon RTS function.
I can of course keep both integrations, but the official API would probably be the right way to go.
Did you get this working with adding a 2nd account? I tried creating a second account attached to my Somfy Connexoon (Australia) and it wouldnât allow me. âThis PIN code is correct and CONNEXOON has alreayd bene activated.â
This project seems really great. But there is two bad points: itâs only for RTS devices, no IO, and it requires some knowledge in electronics. Thatâs not for everyone.
The title can be translated to âTaHoma and HomeKit compatibility: Whatâs taking so long?â
To sum up, they thought their products with the cloud in mind, but Homekit required a local connection to the device. So they have a lot of improvement to do to receive the Homekit certification. So perhaps thank to Apple, in few months, we will see the deployment of a local API.
I am a new Home Assistant user and am learning a lot from reading on this forum and using your knowledge to slowly migrate my systems (Somfy, Velux, Zigbee and Z-wave) to H.A.
I am a bit stuck with my Connexoon box. I have 3 Velux io motorised windows with 3 blinds mounted in them. My Connexoon is connected to these, and I can control all 6 devices via the âConnexoon WINDOWâ App on my android phone.
I used the simply activation methode of the opening post and managed to include the Somfy integrations in H.A. but it only shows the 3 blinds, not the 3 Velux windows:
If I log in to my Somfy account, I see my Connexoon box is registered and linked to the WINDOWS App.
Question: how can I get my Velux windows into H.A.?
Thanks!
PS
With my Homey, I integrated the Somfy devices the same way as with H.A.: I had to save my credentials. After that, the 6 devices are available in Homey. So, it is possible
Hi, the Somfy official API returns only the Somfy devices. And even for this last one, itâs only a subset.
I suggest you to try the Tahoma component which use the unofficial API (the one used by the website).
Hi @C_Holm, thanks for asking. Iâm also looking for this.
BTW thank you so much @tetienne for the job. I can finally get rid of IFTTT to connect TaHoma to Domoticz.
Cheers.
Dea all, I am new in Home Assistant I have some issues to share with my Tahoma Box. I use the Tahoma integration with login and pass. I have several RTS and IO shutter (interior and exterior).
My problem is that I can only close the shutter, it is not possible to open and stop⌠I try the Somfy integration in Cloud mode also but is worth because I can do nothing on these devises.
Can someone help ?
Hi @tetienne,
I am running 0.109.0 and i have re authenticated Somfy component since i had some issues and now my blinds always show like this :
e.g the disabled up and down buttons, i clicked the Stop button in the middle and they react but i think thatâs âMyâ button from remote. Any ideas what might be the problem ?
Thatâs really weird, their was no modification recently on the Somfy component. What was your previous version? Do you see any error in the log? Your covers are RTS or IO?
I canât say since it didnât work for other reasons for some time and now i had the time to look at it again. I have RTS blinds, i havenât seen anything in the log that indicates problems. The Connexon app works fine with the blinds.
I can confirm that it is working with Tamoha integration.
So if you want to use Velux homecontrol IO windows (with Velux blinds) you need to use the Tahoma manual integration and not Somfy integration
hello,
they installed a sun screen today with somfy connexoon.
I installed the somfy home assistant cloud and i see it in home assistant but I canât find my sun screen.
Are the sunscreens supported with home assistant or are Iâm doing something wrong?
