mase
1
Hey guys,
i used the cloudAPI all the time to control my Somfy Connexoon.
i just learned about the localAPI and wanted to switch, however i always get a “failed to connect” error.
i turned dev-mode on at the somfy webpage, added the pin to the gateway url and used the correct account to log in.
cloudapi works without any problems.
am i missing something?
EDIT: was able to connect it using the IP and turning SSL off
Nevs88
(Sven Jachalke)
2
@mase … I have the same problem
Also local IP (without SSL is not working for me) ![:confused: :confused:](https://community.home-assistant.io/images/emoji/twitter/confused.png?v=12)
I will post it in the main thread for the Overkiz local API:
reiner_k
(Reiner)
3
Still the same problem here.
Connection failed drives me crazy.
How did you turn off SSL?
CiNcH83
(Daniel Bechter)
4
Hi everybody
I am new to Home Assistant. Just wanted to let you know that I got Overkiz working via local API.
In order to connect to the Somfy Switch, I had to use its IP instead of the gateway-PIN address. I also had to disable SSL verification.
giova
(Giova)
5
Thank you @CiNcH83 this is a great solution, probably more stable with faster response from the gateway.
