Hey guys,
I have the following problem with the local API to control my Tahoma Switch.
I used the cloud API for a while and wanted to switch to the (now a core feature) local API.
I got the PIN-Code, Tahome Switch is in Dev Mode, credentials are correct (tested on somfy webpage). But is neither working for the .local nor the IP (with SSL off) way?!
For each scenario a get a “Connection failed” message without any further information.
What am I missing? I really appreciate your work and help here!!!
