mase
1
Hey guys,
i used the cloudAPI all the time to control my Somfy Connexoon.
i just learned about the localAPI and wanted to switch, however i always get a “failed to connect” error.
i turned dev-mode on at the somfy webpage, added the pin to the gateway url and used the correct account to log in.
cloudapi works without any problems.
am i missing something?
EDIT: was able to connect it using the IP and turning SSL off
Nevs88
(Sven Jachalke)
2
@mase … I have the same problem Also local IP (without SSL is not working for me)
I will post it in the main thread for the Overkiz local API:
