Override Group Action
Hi All!
Is it possible to override the group action within the configuration?
I mean I want to override the control switch on/off (in assumed state) to call other action than the default action from the switches, which is default called…
regards
raimund
hmmm, nobody?
am I missing something?
do you have a real life example?
Yes I have. I am using livolo switches and they have a special turn off command, not for each, just for all.
The problem with the livolo switches is, that they only can understand 1 command: switch. - when its on, then off and vise versa. There is no command for one switch with id to turn off. (this is what I figured out)
So for this case I need an override to send the global off command for all
have a look at: Livolo RF433 Switches
Cheers
is it possibele to override group action?
