Can I make the owntrack zone’s “enter” and “leave” events override normal latitude/longitude?
I would like to turn on my fountain when I’m at home and in my garden. I have set up an ibeacon in owntrack named “-mybeacon” (with lat = 0 and lon = 0) that I can see sends the “enter” and “leave” MQTT messages.
zone 1:
latitude: X.xxxx
longitude: Y.yyyy
radius: 50
icon: mdi:castle
zone 2:
latitude: 0
longitude: 0
radius: 10
icon: mdi:barcode
With this setup, the owntrack sends the enter event but I’m still placed in the Home zone.
owntracks/ownTrack/device/event {"_type":"transition","acc":0.0,"desc":"-mybeacon","event":"enter","lat":0.0,"lon":0.0...
When approaching the zones, I would first like to be placed in zone 1 based on latitude/longitude, and when HA receives a “-mybeacon” “enter” I would like to be registered in zone 2, until a “-mybeacon” “leave” event arrives.
I’m still fairly new to Home Assistant and think I probably missed something…
(Running Home Assistant 0.25.2 on raspberryPI 3 (Jessie Lite) with Razberry and Tellstick Duo.)
Update: I have now realized that an ibeacon zone in Home Assistant should a) not include the ‘-’ in the name, and b) It should be configured as passive: true. I have now reduced my configuration to a single zone, but I will still never be assigned to it:
zone 2:
latitude: X.xxxx
longitude: Y.yyyy
radius: 10
passive: true
icon: mdi:barcode
I have since also added coordinates to the owntrack zone, removed the ‘-’ from the name, and Home Assistant claims it gets the event, but still no update to the status…
INFO:homeassistant.core:Bus:Handling <Event mqtt_message_received[L]: topic=owntracks/ownTrack/device/event, qos=1, payload={"_type":"transition","acc":0.0,"desc":"mybeacon","event":"enter","lat":X.xxxx,"lon":Y.yyyy,"tid":"e4","trigger":"b","tst":1471124021,"wtst":1470860353}>
