A simple blueprint for the AEON/Aeotec WallMote Quad remote, for use with OZW.
This is nearly a copy/paste of Troy’s blueprint for NanoMote - All credits go to Troy -
blueprint:
name: Aeotec ZW130 WallMote Quad
description: Create automations for the Aeotec ZW130 WallMote Quad using the OZW
integration - Nearly a copy/paste of Troy's blueprint for NanoMote.
domain: automation
input:
aeotec_wallmote:
name: Aeotec WallMote Quad
description: List of available WallMote Quad remotes to configure. This list
is only a reference. At this time, it is not possible to obtain the node's
id using the device selector.
selector:
device:
integration: ozw
# manufacturer: AEON Labs
# model: ZW130 WallMote Quad
ozw_node_id:
description: Enter the node id for an available WallMote Quad you wish to configure.
For now, this field is required. At this time, it is not possible to obtain
the node's id when using the device selector.
button_1:
name: Press Button One
description: Action to run on button press.
default: []
selector:
action: {}
button_2:
name: Press Button Two
default: []
selector:
action: {}
button_3:
name: Press Button Three
default: []
selector:
action: {}
button_4:
name: Press Button Four
default: []
selector:
action: {}
source_url: https://community.home-assistant.io/t/ozw-aeon-labs-aeotec-zw130-wallmote-quad/256240X
mode: single
max_exceeded: silent
variables:
device_id: !input 'aeotec_wallmote'
ozw_node_id: !input 'ozw_node_id'
- platform: event
event_type: ozw.scene_activated
- variables:
node_id: '{{ trigger.event.data.node_id }}'
scene_id: '{{ trigger.event.data.scene_id }}'
scene_value_id: '{{ trigger.event.data.scene_value_id }}'
- choose:
- conditions:
- '{{ node_id == ( ozw_node_id | int ) }}'
- '{{ scene_id == 1 }}'
- '{{ scene_value_id == 1 }}'
sequence: !input 'button_1'
- conditions:
- '{{ scene_id == 2 }}'
sequence: !input 'button_2'
- conditions:
- '{{ scene_id == 3 }}'
sequence: !input 'button_3'
- conditions:
- '{{ scene_id == 4 }}'
# Thanks Severinius-MUC for fixing Button 4 ;-)
sequence: !input 'button_4'
Remember to enter the node ID.
