I trying to migrate from openhab, but I do have a showstopper.
My qubino devices are wired in a way that there are opening when closing command is sent and vice versa. Using the installed hardware switch it works up and down in the correct direction.
I don’t want to change the physical wiring for three roller shutters. Changing the direction in the devices itself is not possible (missing command set for this).
In openhab it is possible to change the control direction within the channel (=homeassistant entity) itself. I didn’t find anything equivalent in homeassistant.
Is there a chance to get this feature or a workaround?
