Please refer to this thread and everywhere it says a Enerwave Z-Wave Plus ZWN-RSM1 substitute a Vision ZL7432. I was confused and thought this was one of my Enerwave devices, when it is the one and only Vision device I have.
When I turn the light or fan on/off, a second device with the same name is created.
here is the log for everything related to half_bath.
(homeassistant_venv) homeassistant@hass2:~/.homeassistant$ cat home-assistant.log | grep half_bath
2017-06-03 15:36:26 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state group.room_half_toilet=unknown; entity_id=(‘switch.half_bath_fan’, ‘switch.half_bath_light’), order=40, friendly_name=room_half_toilet @ 2017-06-03T15:36:26.505682-05:00>, entity_id=group.room_half_toilet, old_state=None>
2017-06-03 15:36:26 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state group.view_half_bath=unknown; view=True, hidden=True, entity_id=(‘group.view_header’, ‘group.room_half_toilet’), order=48, friendly_name=Half Bath @ 2017-06-03T15:36:26.541034-05:00>, entity_id=group.view_half_bath, old_state=None>
2017-06-03 15:45:29 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state zwave.half_bath_64=unknown; node_id=64, manufacturer_name=Vision, product_name=ZL7432 In-Wall Switch, Dual Relay, friendly_name=half_bath @ 2017-06-03T15:45:29.572121-05:00>, entity_id=zwave.half_bath_64, old_state=None>
2017-06-03 15:45:29 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state switch.half_bath_switch_64_0=off; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:45:29.739535-05:00>, entity_id=switch.half_bath_switch_64_0, old_state=None>
2017-06-03 15:45:29 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state zwave.half_bath_64=CacheLoad; max_baud_rate=40000, sentFailed=0, node_id=64, query_stage=CacheLoad, receivedCnt=0, averageRequestRTT=0, is_ready=False, sentTS=2017-06-03 15:44:22:014 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=0, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=0, receivedDups=0, receivedUnsolicited=0, friendly_name=half_bath, is_failed=False, lastResponseRTT=0, retries=0, lastRequestRTT=0, manufacturer_name=Vision, receivedTS=2017-06-03 15:44:22:014 @ 2017-06-03T15:45:29.755648-05:00>, entity_id=zwave.half_bath_64, old_state=<state zwave.half_bath_64=unknown; node_id=64, manufacturer_name=Vision, product_name=ZL7432 In-Wall Switch, Dual Relay, friendly_name=half_bath @ 2017-06-03T15:45:29.572121-05:00>>
2017-06-03 15:45:29 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state switch.half_bath_switch_64_0_2=off; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:45:29.986761-05:00>, entity_id=switch.half_bath_switch_64_0_2, old_state=None>
2017-06-03 15:45:30 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state switch.half_bath_switch_64_0_3=off; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:45:30.116495-05:00>, entity_id=switch.half_bath_switch_64_0_3, old_state=None>
2017-06-03 15:45:45 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=entity_id=switch.half_bath_switch_64_0_3, service=turn_on, service_call_id=1978475792-38, domain=homeassistant>
2017-06-03 15:45:45 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=entity_id=[‘switch.half_bath_switch_64_0_3’], service=turn_on, service_call_id=1978475792-39, domain=switch>
2017-06-03 15:45:52 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=entity_id=switch.half_bath_switch_64_0_2, service=turn_on, service_call_id=1978475792-40, domain=homeassistant>
2017-06-03 15:45:52 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=entity_id=[‘switch.half_bath_switch_64_0_2’], service=turn_on, service_call_id=1978475792-41, domain=switch>
2017-06-03 15:45:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=entity_id=switch.half_bath_switch_64_0, service=turn_on, service_call_id=1978475792-42, domain=homeassistant>
2017-06-03 15:45:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=entity_id=[‘switch.half_bath_switch_64_0’], service=turn_on, service_call_id=1978475792-43, domain=switch>
2017-06-03 15:46:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state zwave.half_bath_64=CacheLoad; max_baud_rate=40000, sentFailed=0, node_id=64, query_stage=CacheLoad, receivedCnt=0, averageRequestRTT=26, is_ready=False, sentTS=2017-06-03 15:46:14:766 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=0, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=1, receivedDups=0, receivedUnsolicited=0, friendly_name=half_bath, is_failed=False, lastResponseRTT=0, retries=0, lastRequestRTT=26, manufacturer_name=Vision, receivedTS=2017-06-03 15:44:22:014 @ 2017-06-03T15:45:29.755648-05:00>, entity_id=zwave.half_bath_64, old_state=<state zwave.half_bath_64=CacheLoad; max_baud_rate=40000, sentFailed=0, node_id=64, query_stage=CacheLoad, receivedCnt=0, averageRequestRTT=0, is_ready=False, sentTS=2017-06-03 15:44:22:014 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=0, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=0, receivedDups=0, receivedUnsolicited=0, friendly_name=half_bath, is_failed=False, lastResponseRTT=0, retries=0, lastRequestRTT=0, manufacturer_name=Vision, receivedTS=2017-06-03 15:44:22:014 @ 2017-06-03T15:45:29.755648-05:00>>
2017-06-03 15:46:24 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state zwave.half_bath_64=CacheLoad; max_baud_rate=40000, sentFailed=0, node_id=64, query_stage=CacheLoad, receivedCnt=2, averageRequestRTT=29, is_ready=False, sentTS=2017-06-03 15:46:24:521 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=37, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=5, receivedDups=0, receivedUnsolicited=0, friendly_name=half_bath, is_failed=False, lastResponseRTT=37, retries=0, lastRequestRTT=26, manufacturer_name=Vision, receivedTS=2017-06-03 15:46:24:558 @ 2017-06-03T15:45:29.755648-05:00>, entity_id=zwave.half_bath_64, old_state=<state zwave.half_bath_64=CacheLoad; max_baud_rate=40000, sentFailed=0, node_id=64, query_stage=CacheLoad, receivedCnt=0, averageRequestRTT=26, is_ready=False, sentTS=2017-06-03 15:46:14:766 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=0, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=1, receivedDups=0, receivedUnsolicited=0, friendly_name=half_bath, is_failed=False, lastResponseRTT=0, retries=0, lastRequestRTT=26, manufacturer_name=Vision, receivedTS=2017-06-03 15:44:22:014 @ 2017-06-03T15:45:29.755648-05:00>>
2017-06-03 15:46:24 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state switch.half_bath_switch_64_0_3=on; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:46:24.604508-05:00>, entity_id=switch.half_bath_switch_64_0_3, old_state=<state switch.half_bath_switch_64_0_3=off; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:45:30.116495-05:00>>
2017-06-03 15:46:24 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state switch.half_bath_switch_64_0_2=on; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:46:24.677621-05:00>, entity_id=switch.half_bath_switch_64_0_2, old_state=<state switch.half_bath_switch_64_0_2=off; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:45:29.986761-05:00>>
2017-06-03 15:46:24 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state zwave.half_bath_64=CacheLoad; max_baud_rate=40000, sentFailed=0, node_id=64, query_stage=CacheLoad, receivedCnt=3, averageRequestRTT=25, is_ready=False, sentTS=2017-06-03 15:46:24:612 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=36, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=7, receivedDups=0, receivedUnsolicited=0, friendly_name=half_bath, is_failed=False, lastResponseRTT=35, retries=0, lastRequestRTT=24, manufacturer_name=Vision, receivedTS=2017-06-03 15:46:24:647 @ 2017-06-03T15:45:29.755648-05:00>, entity_id=zwave.half_bath_64, old_state=<state zwave.half_bath_64=CacheLoad; max_baud_rate=40000, sentFailed=0, node_id=64, query_stage=CacheLoad, receivedCnt=2, averageRequestRTT=29, is_ready=False, sentTS=2017-06-03 15:46:24:521 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=37, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=5, receivedDups=0, receivedUnsolicited=0, friendly_name=half_bath, is_failed=False, lastResponseRTT=37, retries=0, lastRequestRTT=26, manufacturer_name=Vision, receivedTS=2017-06-03 15:46:24:558 @ 2017-06-03T15:45:29.755648-05:00>>
2017-06-03 15:46:24 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state switch.half_bath_switch_64_0=on; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:46:24.781213-05:00>, entity_id=switch.half_bath_switch_64_0, old_state=<state switch.half_bath_switch_64_0=off; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:45:29.739535-05:00>>
2017-06-03 15:46:30 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=entity_id=switch.half_bath_switch_64_0, service=turn_off, service_call_id=1978475792-44, domain=homeassistant>
2017-06-03 15:46:30 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=entity_id=[‘switch.half_bath_switch_64_0’], service=turn_off, service_call_id=1978475792-45, domain=switch>
2017-06-03 15:46:32 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=entity_id=switch.half_bath_switch_64_0_2, service=turn_off, service_call_id=1978475792-46, domain=homeassistant>
2017-06-03 15:46:32 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=entity_id=[‘switch.half_bath_switch_64_0_2’], service=turn_off, service_call_id=1978475792-47, domain=switch>
2017-06-03 15:46:34 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=entity_id=switch.half_bath_switch_64_0_3, service=turn_off, service_call_id=1978475792-48, domain=homeassistant>
2017-06-03 15:46:34 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=entity_id=[‘switch.half_bath_switch_64_0_3’], service=turn_off, service_call_id=1978475792-49, domain=switch>
2017-06-03 15:46:35 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state zwave.half_bath_64=CacheLoad; max_baud_rate=40000, sentFailed=0, node_id=64, query_stage=CacheLoad, receivedCnt=3, averageRequestRTT=25, is_ready=False, sentTS=2017-06-03 15:46:34:681 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=36, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=8, receivedDups=0, receivedUnsolicited=0, friendly_name=half_bath, is_failed=False, lastResponseRTT=35, retries=0, lastRequestRTT=24, manufacturer_name=Vision, receivedTS=2017-06-03 15:46:24:647 @ 2017-06-03T15:45:29.755648-05:00>, entity_id=zwave.half_bath_64, old_state=<state zwave.half_bath_64=CacheLoad; max_baud_rate=40000, sentFailed=0, node_id=64, query_stage=CacheLoad, receivedCnt=3, averageRequestRTT=25, is_ready=False, sentTS=2017-06-03 15:46:24:612 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=36, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=7, receivedDups=0, receivedUnsolicited=0, friendly_name=half_bath, is_failed=False, lastResponseRTT=35, retries=0, lastRequestRTT=24, manufacturer_name=Vision, receivedTS=2017-06-03 15:46:24:647 @ 2017-06-03T15:45:29.755648-05:00>>
2017-06-03 15:46:45 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state zwave.half_bath_64=CacheLoad; max_baud_rate=40000, sentFailed=1, node_id=64, query_stage=CacheLoad, receivedCnt=4, averageRequestRTT=1062, is_ready=False, sentTS=2017-06-03 15:46:45:731 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=36, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=12, receivedDups=0, receivedUnsolicited=0, friendly_name=half_bath, is_failed=False, lastResponseRTT=37, retries=1, lastRequestRTT=26, manufacturer_name=Vision, receivedTS=2017-06-03 15:46:45:769 @ 2017-06-03T15:45:29.755648-05:00>, entity_id=zwave.half_bath_64, old_state=<state zwave.half_bath_64=CacheLoad; max_baud_rate=40000, sentFailed=0, node_id=64, query_stage=CacheLoad, receivedCnt=3, averageRequestRTT=25, is_ready=False, sentTS=2017-06-03 15:46:34:681 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=36, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=8, receivedDups=0, receivedUnsolicited=0, friendly_name=half_bath, is_failed=False, lastResponseRTT=35, retries=0, lastRequestRTT=24, manufacturer_name=Vision, receivedTS=2017-06-03 15:46:24:647 @ 2017-06-03T15:45:29.755648-05:00>>
2017-06-03 15:46:45 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state switch.half_bath_switch_64_0_2=off; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:46:45.899398-05:00>, entity_id=switch.half_bath_switch_64_0_2, old_state=<state switch.half_bath_switch_64_0_2=on; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:46:24.677621-05:00>>
2017-06-03 15:46:46 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state zwave.half_bath_64=CacheLoad; max_baud_rate=40000, sentFailed=1, node_id=64, query_stage=CacheLoad, receivedCnt=5, averageRequestRTT=290, is_ready=False, sentTS=2017-06-03 15:46:45:838 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=37, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=14, receivedDups=0, receivedUnsolicited=0, friendly_name=half_bath, is_failed=False, lastResponseRTT=38, retries=1, lastRequestRTT=26, manufacturer_name=Vision, receivedTS=2017-06-03 15:46:45:877 @ 2017-06-03T15:45:29.755648-05:00>, entity_id=zwave.half_bath_64, old_state=<state zwave.half_bath_64=CacheLoad; max_baud_rate=40000, sentFailed=1, node_id=64, query_stage=CacheLoad, receivedCnt=4, averageRequestRTT=1062, is_ready=False, sentTS=2017-06-03 15:46:45:731 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=36, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=12, receivedDups=0, receivedUnsolicited=0, friendly_name=half_bath, is_failed=False, lastResponseRTT=37, retries=1, lastRequestRTT=26, manufacturer_name=Vision, receivedTS=2017-06-03 15:46:45:769 @ 2017-06-03T15:45:29.755648-05:00>>
2017-06-03 15:46:46 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state switch.half_bath_switch_64_0_3=off; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:46:46.060452-05:00>, entity_id=switch.half_bath_switch_64_0_3, old_state=<state switch.half_bath_switch_64_0_3=on; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:46:24.604508-05:00>>
2017-06-03 15:47:33 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state switch.half_bath_switch_64_0_4=off; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:47:33.880525-05:00>, entity_id=switch.half_bath_switch_64_0_4, old_state=None>
2017-06-03 15:47:34 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state zwave.half_bath_64=Neighbors; max_baud_rate=40000, sentFailed=1, node_id=64, query_stage=Neighbors, receivedCnt=8, averageRequestRTT=157, is_ready=False, sentTS=2017-06-03 15:47:25:739 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=36, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=16, receivedDups=0, receivedUnsolicited=2, friendly_name=half_bath, is_failed=False, lastResponseRTT=35, retries=1, lastRequestRTT=25, manufacturer_name=Vision, receivedTS=2017-06-03 15:47:33:881 @ 2017-06-03T15:47:34.037633-05:00>, entity_id=zwave.half_bath_64, old_state=<state zwave.half_bath_64=CacheLoad; max_baud_rate=40000, sentFailed=1, node_id=64, query_stage=CacheLoad, receivedCnt=5, averageRequestRTT=290, is_ready=False, sentTS=2017-06-03 15:46:45:838 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=37, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=14, receivedDups=0, receivedUnsolicited=0, friendly_name=half_bath, is_failed=False, lastResponseRTT=38, retries=1, lastRequestRTT=26, manufacturer_name=Vision, receivedTS=2017-06-03 15:46:45:877 @ 2017-06-03T15:45:29.755648-05:00>>
2017-06-03 15:47:40 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state switch.half_bath_switch_64_0_5=off; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:47:40.162741-05:00>, entity_id=switch.half_bath_switch_64_0_5, old_state=None>
2017-06-03 15:47:40 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state zwave.half_bath_64=Neighbors; max_baud_rate=40000, sentFailed=1, node_id=64, query_stage=Neighbors, receivedCnt=10, averageRequestRTT=157, is_ready=False, sentTS=2017-06-03 15:47:25:739 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=36, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=16, receivedDups=0, receivedUnsolicited=4, friendly_name=half_bath, is_failed=False, lastResponseRTT=35, retries=1, lastRequestRTT=25, manufacturer_name=Vision, receivedTS=2017-06-03 15:47:40:137 @ 2017-06-03T15:47:34.037633-05:00>, entity_id=zwave.half_bath_64, old_state=<state zwave.half_bath_64=Neighbors; max_baud_rate=40000, sentFailed=1, node_id=64, query_stage=Neighbors, receivedCnt=8, averageRequestRTT=157, is_ready=False, sentTS=2017-06-03 15:47:25:739 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=36, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=16, receivedDups=0, receivedUnsolicited=2, friendly_name=half_bath, is_failed=False, lastResponseRTT=35, retries=1, lastRequestRTT=25, manufacturer_name=Vision, receivedTS=2017-06-03 15:47:33:881 @ 2017-06-03T15:47:34.037633-05:00>>
2017-06-03 15:47:46 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state zwave.half_bath_64=Neighbors; max_baud_rate=40000, sentFailed=1, node_id=64, query_stage=Neighbors, receivedCnt=11, averageRequestRTT=157, is_ready=False, sentTS=2017-06-03 15:47:25:739 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=36, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=16, receivedDups=0, receivedUnsolicited=5, friendly_name=half_bath, is_failed=False, lastResponseRTT=35, retries=1, lastRequestRTT=25, manufacturer_name=Vision, receivedTS=2017-06-03 15:47:45:915 @ 2017-06-03T15:47:34.037633-05:00>, entity_id=zwave.half_bath_64, old_state=<state zwave.half_bath_64=Neighbors; max_baud_rate=40000, sentFailed=1, node_id=64, query_stage=Neighbors, receivedCnt=10, averageRequestRTT=157, is_ready=False, sentTS=2017-06-03 15:47:25:739 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=36, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=16, receivedDups=0, receivedUnsolicited=4, friendly_name=half_bath, is_failed=False, lastResponseRTT=35, retries=1, lastRequestRTT=25, manufacturer_name=Vision, receivedTS=2017-06-03 15:47:40:137 @ 2017-06-03T15:47:34.037633-05:00>>
2017-06-03 15:47:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state switch.half_bath_switch_64_0_6=off; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:47:49.753227-05:00>, entity_id=switch.half_bath_switch_64_0_6, old_state=None>
2017-06-03 15:47:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state zwave.half_bath_64=Neighbors; max_baud_rate=40000, sentFailed=1, node_id=64, query_stage=Neighbors, receivedCnt=13, averageRequestRTT=157, is_ready=False, sentTS=2017-06-03 15:47:25:739 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=36, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=16, receivedDups=0, receivedUnsolicited=7, friendly_name=half_bath, is_failed=False, lastResponseRTT=35, retries=1, lastRequestRTT=25, manufacturer_name=Vision, receivedTS=2017-06-03 15:47:49:740 @ 2017-06-03T15:47:34.037633-05:00>, entity_id=zwave.half_bath_64, old_state=<state zwave.half_bath_64=Neighbors; max_baud_rate=40000, sentFailed=1, node_id=64, query_stage=Neighbors, receivedCnt=11, averageRequestRTT=157, is_ready=False, sentTS=2017-06-03 15:47:25:739 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=36, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=16, receivedDups=0, receivedUnsolicited=5, friendly_name=half_bath, is_failed=False, lastResponseRTT=35, retries=1, lastRequestRTT=25, manufacturer_name=Vision, receivedTS=2017-06-03 15:47:45:915 @ 2017-06-03T15:47:34.037633-05:00>>
2017-06-03 15:47:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state switch.half_bath_switch_64_0=off; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:47:49.878649-05:00>, entity_id=switch.half_bath_switch_64_0, old_state=<state switch.half_bath_switch_64_0=on; node_id=64, friendly_name=half_bath Switch @ 2017-06-03T15:46:24.781213-05:00>>
2017-06-03 15:48:38 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state zwave.half_bath_64=Dynamic; max_baud_rate=40000, sentFailed=1, node_id=64, query_stage=Dynamic, receivedCnt=18, averageRequestRTT=39, is_ready=False, sentTS=2017-06-03 15:48:38:764 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=41, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=21, receivedDups=0, receivedUnsolicited=7, neighbors={1, 16, 17, 18, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 33, 34, 35, 36, 37, 38, 39, 40, 43, 44, 45, 46, 47, 49, 51, 52, 53, 57, 58, 59}, is_failed=False, lastResponseRTT=46, retries=1, lastRequestRTT=44, manufacturer_name=Vision, receivedTS=2017-06-03 15:48:38:810 , friendly_name=half_bath @ 2017-06-03T15:48:38.849414-05:00>, entity_id=zwave.half_bath_64, old_state=<state zwave.half_bath_64=Neighbors; max_baud_rate=40000, sentFailed=1, node_id=64, query_stage=Neighbors, receivedCnt=13, averageRequestRTT=157, is_ready=False, sentTS=2017-06-03 15:47:25:739 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=36, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=16, receivedDups=0, receivedUnsolicited=7, friendly_name=half_bath, is_failed=False, lastResponseRTT=35, retries=1, lastRequestRTT=25, manufacturer_name=Vision, receivedTS=2017-06-03 15:47:49:740 @ 2017-06-03T15:47:34.037633-05:00>>
2017-06-03 15:48:38 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state zwave.half_bath_64=Dynamic; max_baud_rate=40000, sentFailed=1, node_id=64, query_stage=Dynamic, receivedCnt=20, averageRequestRTT=37, is_ready=False, sentTS=2017-06-03 15:48:38:911 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=40, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=23, receivedDups=0, receivedUnsolicited=7, neighbors={1, 16, 17, 18, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 33, 34, 35, 36, 37, 38, 39, 40, 43, 44, 45, 46, 47, 49, 51, 52, 53, 57, 58, 59}, is_failed=False, lastResponseRTT=37, retries=1, lastRequestRTT=32, manufacturer_name=Vision, receivedTS=2017-06-03 15:48:38:948 , friendly_name=half_bath @ 2017-06-03T15:48:38.849414-05:00>, entity_id=zwave.half_bath_64, old_state=<state zwave.half_bath_64=Dynamic; max_baud_rate=40000, sentFailed=1, node_id=64, query_stage=Dynamic, receivedCnt=18, averageRequestRTT=39, is_ready=False, sentTS=2017-06-03 15:48:38:764 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=41, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=21, receivedDups=0, receivedUnsolicited=7, neighbors={1, 16, 17, 18, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 33, 34, 35, 36, 37, 38, 39, 40, 43, 44, 45, 46, 47, 49, 51, 52, 53, 57, 58, 59}, is_failed=False, lastResponseRTT=46, retries=1, lastRequestRTT=44, manufacturer_name=Vision, receivedTS=2017-06-03 15:48:38:810 , friendly_name=half_bath @ 2017-06-03T15:48:38.849414-05:00>>
2017-06-03 15:48:49 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state zwave.half_bath_64=Ready; max_baud_rate=40000, sentFailed=1, node_id=64, query_stage=Complete, receivedCnt=20, averageRequestRTT=37, is_ready=True, sentTS=2017-06-03 15:48:38:911 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=40, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=23, receivedDups=0, receivedUnsolicited=7, neighbors={1, 16, 17, 18, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 33, 34, 35, 36, 37, 38, 39, 40, 43, 44, 45, 46, 47, 49, 51, 52, 53, 57, 58, 59}, is_failed=False, lastResponseRTT=37, retries=1, lastRequestRTT=32, manufacturer_name=Vision, receivedTS=2017-06-03 15:48:38:948 , friendly_name=half_bath @ 2017-06-03T15:48:49.203152-05:00>, entity_id=zwave.half_bath_64, old_state=<state zwave.half_bath_64=Dynamic; max_baud_rate=40000, sentFailed=1, node_id=64, query_stage=Dynamic, receivedCnt=20, averageRequestRTT=37, is_ready=False, sentTS=2017-06-03 15:48:38:911 , is_info_received=True, product_name=ZL7432 In-Wall Switch, Dual Relay, averageResponseRTT=40, is_zwave_plus=False, capabilities={‘listening’, ‘beaming’, ‘routing’}, is_awake=True, sentCnt=23, receivedDups=0, receivedUnsolicited=7, neighbors={1, 16, 17, 18, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 33, 34, 35, 36, 37, 38, 39, 40, 43, 44, 45, 46, 47, 49, 51, 52, 53, 57, 58, 59}, is_failed=False, lastResponseRTT=37, retries=1, lastRequestRTT=32, manufacturer_name=Vision, receivedTS=2017-06-03 15:48:38:948 , friendly_name=half_bath @ 2017-06-03T15:48:38.849414-05:00>>
