[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] mosquitto.sh: executing…
[14:19:48] INFO: SSL is not enabled
[cont-init.d] mosquitto.sh: exited 0.
[cont-init.d] nginx.sh: executing…
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[14:19:48] INFO: Starting NGINX for authentication handling…
[14:19:48] INFO: Starting mosquitto MQTT broker…
1648975788: mosquitto version 1.6.12 starting
1648975788: |-- *** auth-plug: startup
[14:19:49] INFO: Successfully send discovery information to Home Assistant.
[14:19:49] INFO: Successfully send service information to the Supervisor.
1648975788: Config loaded from /etc/mosquitto/mosquitto.conf.
1648975788: Loading plugin: /usr/share/mosquitto/auth-plug.so
1648975788: ├── Username/password checking enabled.
1648975788: ├── TLS-PSK checking enabled.
1648975788: └── Extended authentication not enabled.
1648975788: Opening ipv4 listen socket on port 1883.
1648975788: Opening ipv6 listen socket on port 1883.
1648975788: Opening websockets listen socket on port 1884.
1648975788: Warning: Mosquitto should not be run as root/administrator.
1648975788: mosquitto version 1.6.12 running
1648975788: New connection from 127.0.0.1 on port 1883.
1648975788: Socket error on client , disconnecting.
1648975789: New connection from 172.30.32.1 on port 1883.
1648975789: New client connected from 172.30.32.1 as node-red-ha-miraie-ac-node (p2, c1, k60).
1648975790: New connection from 172.30.32.1 on port 1883.
{“result”: “ok”, “data”: {}}1648975790: New client connected from 172.30.32.1 as 6PliD2am6FoT70yG5iRj0R (p2, c1, k60, u’mqtt-user’).
1648975801: New connection from 172.30.32.2 on port 1883.
1648975801: Socket error on client , disconnecting.
1648975844: Client node-red-ha-miraie-ac-node disconnected.
1648975844: New connection from 172.30.32.1 on port 1883.
1648975844: New client connected from 172.30.32.1 as node-red-ha-miraie-ac-node (p2, c1, k60).
1648975921: New connection from 172.30.32.2 on port 1883.
1648975921: Socket error on client , disconnecting.
1648975970: Client node-red-ha-miraie-ac-node disconnected.
1648975970: New connection from 172.30.32.1 on port 1883.
1648975970: New client connected from 172.30.32.1 as node-red-ha-miraie-ac-node (p2, c1, k60).
1648976041: New connection from 172.30.32.2 on port 1883.
1648976041: Socket error on client , disconnecting.
1648976053: Socket error on client 6PliD2am6FoT70yG5iRj0R, disconnecting.
1648976065: New connection from 172.30.32.1 on port 1883.
1648976065: New client connected from 172.30.32.1 as 11NpJv8UYExgCIbVJyaYLa (p2, c1, k60, u’mqtt-user’)
hey @charutak, v1.1.1 has an input port that lets you fetch and update the device status. This with some kind of automation may help if you see a definite pattern around when this happens.
hi @milothomas i have hosted HA on windows 10 VM. presently i have esphome, mqtt broker and node-red as addons. installed mqtt broker and node red after seeing your post. so no other node making connection to broker. firewall turned off. initially it got connected but throwing this error after HA restart.
Hey, @milothomas I looked through the Node_RED code. Would you like to collaborate on building a HomeBridge plugin, and a native HA plugin based on your Node-RED implementation?
You don’t need to setup Mosquitto Broker and node-red plugin anymore.
Copy the miraie folder from custom components and paste it into /config/custom_components of your HA installation, after that restart the system and also clear your browser cache.
Then you can add miraie integration from Integrations page, you need mobile number (with country code) and password for the log in.
It will automatically detect all the devices and add it to your home assistant.
This integration is in very early stage and I also a very beginner python developer. For feedback and suggestions please open the issues on Gthub page.
can you share node flow diagram i am new to node red and just want to use this node to get my ac on home assistant , what i did till now i got the mirai node in the flow and configured the login it shows the green light and shows one device connected but i am not sure how to connect this with mqtt add on
Hi All,
I’m new to home assistant. I have Panasonic Miraie enabled Aircon. I have installed node-red install for miraie and provided all details for authentication and mqqt. It seems to login correctly but unable to fetch device details as per log (attached below)
