Home Assistant Paperless-ng Add-on
About
I have created an Add-on for Paperless-ng.
Paperless is an application that manages your personal documents. With the help of a document scanner (see Scanner recommendations), paperless transforms your wieldy physical document binders into a searchable archive and provides many utilities for finding and managing your documents.
Installation
The installation of this add-on is pretty straightforward and not different in comparison to installing any other Home Assistant add-on.
- Add Add this URL to your Home Assistant addons repos (Supervisor -> Add-on store -> three dots upper right):
https://github.com/TheBestMoshe/home-assistant-addons
- Install this add-on.
- Set the configuration.
- Click the
Save
button to store your configuration. - Start the add-on.
- Check the logs of the add-on to see if everything went well.
Post here and Iâll get back to you, or you can file an issue in GitHub
