Sort of similar to this question but coming at it from a totally different angle, is anyone currently parsing a streaming URL and using it as a sensor? If so, would you mind sharing how?!
not sure exactly what you’re after. Are you trying to retrieve details from the mp3 track?
Not sure that’s easily possible.
The way I did retrieve the current track/artist from some of my fave radio streaming pages this is with a scrape sensor, but that’s far from easy to achieve and relies on the web page not changing its structure…
here’s a quick python script that I wrote to try and test the select parameter:
#!/usr/bin/python
# -*- coding: utf-8 -*-
from bs4 import BeautifulSoup
import urllib2
import sys
import subprocess
def bs_get_value():
content = urllib2.urlopen("https://www.smoothradio.com/chill/radio/playlist/").read()
try:
raw_data = BeautifulSoup(content,"html.parser")
except Exception as e:
print("%s - Unable to get BS from URL" % e)
print raw_data.select("span:nth-of-type(4)")[0].text
bs_get_value()
then I created a whole bunch of sensors based on artist, track, artwork for each station and got this nicely tied into a lovelace card:
I’m not gonna lie, that’s quite some complex/advanced setup which took me months to achieve and fine tune…
If you’re up for the task, feel free to check my config:
So I’ve made progress. I’ve got this python script which returns what’s on across the main BBC radio channels. I’m a bit stuck as to how to now get this into Home Assistant. I had a look at your config but I think the bit that would be relevant; the shell scripts, aren’t on GitHub? But you’ve already been a huge inspiration…!
“soupsieve.util.SelectorSyntaxError: Invalid character '@' position 62”
EDIT Hmm, no immediate panic, looks like I can do the lookup with Node-Red and send the result to HA via MQTT… would be cool to pull in the images as well…
EDIT2 OK, looks like I can get my BBC Radio sensors just fine at the moment using Node Red, a Python script and MQTT. Just hope that they work in the morning, or at the weekend. Not sure I’m directing the message payload in the most sensible way. Or if the way I’m doing it will continue to work throughout the week… we will see.
Hi again - sorry to bother you - I just wondered if you’d ever had any problems with the generic camera platform hanging/freezing? It’s causing me all sorts of problems despite the fact I’m limiting fetch to if the URL changes. But you seem to be using it (or am I mistaken - is there a key difference I’ve missed?) without issue? Do you use DuckDNS or SSL for example? That seems to possibly be the kicker.
