Hi guys, i did the update of hass OS and after that no internet connection.
supervisor_internet = true
host_internet = false
I did nothing else, no config change or whatever, just updated both of my homeassistant OS to the last version.
Now i cant do any updates anymore, but the supervisor internet just works fine.
There has been changed nothing, just happened after that specific update.
I’m not a fan of restoring.
i will lose a lot of data.
as it only backups at 0:00
maybe there is a way to downgrade hass os ?
i did open a case on github homeassistant OS, maybe agners can help me out without using a backup.
as really everything works, except doing updates, but also new updates showing up too.
any particular reason why your ipv4 only shows -10 and your gateway 10. , you do know it’s local addresses so we all have them, and hardly noone can do anything knowing which one you Chooses , meaning no point in hiding them ( if tha’s what you did) it only cause a question/thoughts like this, because obviously it’s not suppose to look like that.
And another thing, your ipv4 name-server, i know some people, for some reason like google and cloudflare , im doing fine with my Router, for internal name-resolving, and rely on my IP-Provider for external resolving.
How does your HA dns settings look like ?, if “fallback: true”, try set “false” AND if locals is 1.1.1.1 maybe try to point it to your Routers lan IP
Again, i know many people for some reason using external nameservers for local addresse ( For some unknown reason, in my head) As one can set in the Routers which External NS one want to use, if not using the defaults the IP-provider serves you with ( Fore external traffic)
Why go “outside” for internal traffic/resolving ?, that’s just asking for problems/latency/etc
I use my local ip and not my external ip, i did hide it just because i want it.
I did do none with my router nor did i update anything, besides to 10.5
Im running pfsense and all dns is handled normal and when no dns is resolved it falls back to another one.
I did double check all dns servers are all online and working.
The dns servers i use are ssl, never had problems with it.
I also checked if my system was healthy and it is, i posted it here
My ha uses a static ip, but does not run over the dns i just mentioned, just the isp dns or 1.1.1.1 or 8.8.8.8 if it fails.
I could understand if i did work on my router or my isp did an update or my routers or whatever did a restart that it could fail, but none of that happened, it started after the update.
So when this all happened i did restarts pfsense, did restart the proxmox host and did restart the container, all nothing.
for now i did the above step to update home assistant, and it worked.
try “net reload” just to check if if change to host-internet true, othervice it sounds like you maybe have a “ban” in “Some” of your DNS’s (or maybe in Proxmox OS)
