from hass cli i can ping all dns servers and even internal servers
In my opinion it would work best if āhass systemā use hass-dns ( .3 ), and supervisor Routers Lan Address. ( Tried with fallback: false ? )
Im absolute no fan of Google, and have no experience of CloudFlare
hmm ok, yes im not using google at all, that was just for testing, but it aint working.
i found out when using cli hs ping 172.30.32.0 the docker ip it does not ping 100% fail
i pinged the ip from the above screenshot when typing ha network info
however 172.30.32.1 and 172.30.32.3 does ping
on my second system i did what u said, using the supervisor lan address
still no luck
i believe .0 is a network, not a device
ā¦ beside you still have āfallback trueā
how can i change it to false ?
dns options
Dug up a reddit thread where the OP had the same problem and figured it was content filtering on their router. Maybe will help.
many thanks for tht link.
Ive seen it, but that guy had a virusscanner active on his router.
and he had this on his first install, while i had it after upgrading.
but he had a workarround,
Spinning up a VM Supervised so I can have control over the OS, I can edit `/etc/NetworkManager/NetworkManager.conf`
& change it to https , reboot, and everything works. While I could go that route, just bothers me that it does not work if I use HAOS without changing that.
However if i go into that file there is nothing in it besides this
Very very strangeā¦
what i did not try yet is to disconnect my ISP router and let it reconnect again.
also not working
also checked this, donāt think its normal
I did buy an other pc, different hardware etc.
so i did re-install HASS OS on a new Proxmox server, and still that issue.
its driving me nuts lol.
How did you install HA? Did you use tteckās helper scripts? https://tteck.github.io/Proxmox/ This is the easiest way to do it. I used it and worked instantly.
yep i used that one.
even on my new system its stuck on the (getting ready page)
Sorry, Iām stuck.
Same issue as you.
yep and i did try his workarround, see my post
the same guy posted on reddit, using that method, but doesnt work for me.
So if it let me update updates with this command
ha jobs options --ignore-conditions internet_host
what is the issue that home assistant blocks it ?
this lets me only update something not look for new updates or hacs updates
well just borrowed an laptop to install HASSOS on that laptop with Virtualbox and same issueā¦
so there must be something else,
what i try to do is run the 10.4 on that one and see if that works.
i did now go to m ypf sense and delete all dns entries and let it just use the dns from my isp, still not working.
i borrowed a laptop and tried 10.5 on virtualbox windows 11 no luck
i did try 10.4 and not working also.
right now im out of options, did isp block me ??
