Passing attribute and call service - Fingerprint R503
Hi everyone
I configured my GROW R503 sensor with esphome:
uart:
  rx_pin: GPIO13
  tx_pin: GPIO14
  baud_rate: 57600
fingerprint_grow:
  sensing_pin: GPIO12
  on_finger_scan_matched:
    - text_sensor.template.publish:
        state: "Impronta autorizzata"
    - delay: 3000ms
    - lambda: |-
        if (finger_id == 0) {
          id(fingerprint_username).publish_state("Fred");
        } else if (finger_id == 1) {
          id(fingerprint_username).publish_state("Gianni");
        } else {
          id(fingerprint_username).publish_state("Unknown");
        state: "Attesa"
    - fingerprint_grow.aura_led_control:
        state: BREATHING
        speed: 200
        color: BLUE
        count: 1
  on_finger_scan_unmatched:
        state: "Impronta non autorizzata"
        state: FLASHING
        speed: 25
        color: RED
        count: 2
  on_enrollment_scan:
        state: "Impronta acquisita"
        state: FLASHING
        speed: 25
        color: BLUE
        count: 2
        state: ALWAYS_ON
        speed: 0
        color: PURPLE
        count: 0
  on_enrollment_failed:
        state: "Acquisizione impronta fallita"
        state: FLASHING
        speed: 25
        color: RED
        count: 4
api:
  services:
  - service: enroll
    variables:
      finger_id: int
      num_scans: int
    then:
      - fingerprint_grow.enroll:
          finger_id: !lambda 'return finger_id;'
          num_scans: !lambda 'return num_scans;'
  - service: cancel_enroll
    then:
      - fingerprint_grow.cancel_enroll:
  - service: delete
    variables:
      finger_id: int
    then:
      - fingerprint_grow.delete:
  - service: delete_all
    then:
      - fingerprint_grow.delete_all:
# Optional template text sensor for visual feedback
text_sensor:
    name: "Stato impronta"
    name:     "Ultima scansione"
    update_interval: 30s
# Optional sensors
binary_sensor:
  - platform: fingerprint_grow
    name: "Acquisendo impronta"
    fingerprint_count:
      name: "Conta impronte"
    last_finger_id:
      name: "Ultimo ID impronta"
    last_confidence:
      name: "AffidabilitĂ  ultima impronta"
    status:
    capacity:
      name: "CapacitĂ  impronta"
    security_level:
      name: "Livello di sicurezza"
i want pass to service call esphome.esphome_fingerprint_ingresso_enroll, finger_id the value of input_number_id_impronta for adding a new fingerprint.
I write the value
this is lovelace card
show_name: true
show_icon: true
type: button
tap_action:
  action: call-service
  service: esphome.esphome_fingerprint_ingresso_enroll
  target: {}
    finger_id: '{{ states(''input_number.id_impronta'') }}'
    num_scans: 2
icon: mdi:fingerprint
icon_height: 50px
help please…
Thank you :slight_smile:
This thread has the best info on the R503.
There is a simple solution in the code to enroll another fingerprint mentioned by nickrout. Just add this to the services in the api section:
  - service: enroll_next # Idea by Ralf KlĂĽber (thanks!)
    variables:
      num_scans: int
      count_plus: int
    then:
          finger_id: !lambda 'return count_plus + id(fingerprint_count).state;'
I just made some progress on adding your original question, but will post this seperately, once I am done.
Your approach seems fine,.e.g. the same i am summarizing below.
But i think you have to format the input as integer.
finger_id: "{{states('input_number.fingerprint_modification_id') | int}}"
At least thats the only notable difference i see. For me it is working.
The problem can be solved as follows.
  1. Create a number Helper in devices, helper. Call
    This you add to the frontend as part of a dashboard card to enter the number.
  2. Create a script for every button you want
alias: Fingerprint Learning 30s
sequence:
  - action: esphome.fingergarage_enroll
    metadata: {}
      num_scans: 2
  - delay:
      hours: 0
      minutes: 1
      seconds: 0
      milliseconds: 0
  - action: esphome.fingergarage_cancel_enroll
    metadata: {}
    data: {}
description: ""
Certainly you skip the timer and the cancellation if not wanted.
  1. Now add the button to your card as well.
