Thanks @Ernst, will do!
Nadav
@Ernst I have some time finally to work on getting you information needed for adding Inkbird IBS-P01R Wireless Pool Thermometer but not finding in FAQ info on how to gather the info you need?
Editā¦ Found instructions in FAQ will see if i can do this
@Ernst Submitted Log info to github issues page If it is totally wrong info let me know and will try again
I went to Amazon to buy the Switchbot THS1 and saw they have a new one with a larger and higher contrast display for only a few dollars more. Iād be happy to buy a W2301500 in the interest of science and contribute logs to get it added to the supported device list.
Yes, sure. If you provide the logs, I will add it, if possible
Just want to say what a fantastic addition to HA this is - personally most of my home automation would be significantly worse and more difficult to do without it. Thanks to @Ernst for his commitment and engagement when there are issues and Iād encourage anyone who uses this component to sponsor him on Github. Sponsor @Ernst79 on GitHub Sponsors Ā· GitHub
@baz123 Thanks for the kind words!
Today, I have released 8.1.0, with some big changes for the DIY-ers, who want to make their own BLE sensors. But also some other improvements and new supported sensors of course.
New improved HA BLE format
This release brings a totally new HA BLE format. We have created a BLE advertisement format that you can use for your DIY sensors. The main advantages of the new format:
More info about the format can be found here
Thanks for @pvvx for his suggestions on how to improve the HA BLE format. ATC firmware 3.7(b) has added support for HA BLE format in the sensors that support ATC firmware.
New sensors
Bug fixes
weight
as an attribute to the weight removed
binary sensorimpedance
attribute of non-stabilized weight sensor to unavailable if not in dataTo add, the scale used to report the stabilized weight before the impedance. Now it will only report both once the full cycle has completed (white lines stop flashing) and the impedance and weight sensors update almost simultaneously.
Thanks for adding support for the Switchbot TH Plus. Unfortunately, the device doesnāt show up in HA. I removed the device I had manually added for debug using its MAC address and am wondering if that is the source of the problem.
First of all, thank you @Ernst for all your hard work and dedication! Passive BLE monitor is definitely one of my favorite add-ons in HA!
I noticed that it is missing a key feature, which would be very beneficial to users - an **expire_after**
timer! This way you can tell if a sensor is offline, or hasnāt been updated in a long time.
Hereās my use case:
Over the past few days, Iāve been adding a few Govee temperature sensors to the mix. I was able to add them fine, but a few days later the batteries died due to old age. I didnāt realize the issue, however, as Passive BLE monitor kept showing the last value.
In my MQTT devices, i get around this by using the expire_after
field, which sets the sensor to āUnavailableā after a set period of time.
It would be great to be able to do this for devices using BLE monitor as well. Iām not sure if this is an easy fix, or something more complex. But IMO, this would be a very valuable addition - especially to identify faulty or dead devices (in my case, a Thermometer).
If there is already a way to set an expiration / timeout for sensors, Iād appreciate it if anybody could point me to the right direction.
Cheers!
There is a similar request on github. Iāll try to add this in the future, but will take some time.
Thanks for the heads up. Looking forward to getting this new feature integrated!
With the H5183 does it support the two probe unit?
Could the H5184 be supported if the data from it was provided?
The H5183 currently only supports the probe temperature and the alarm temperature. But if you send me some BLE advertisements I can check if a second probe is also included in the data.
The H5184 is not supported yet, but if someone sends me the BLE advertisements, Iām sure it can be added.
BLE advertisements can be collected in Home Assistant, see for instructions the page below.
Thank you for your quick reply. The single probe H5183 is on sale for $10 right now so just went with that one as a test. If it works for what I need, Iāll try the dual probe or the H5184 and send that data.
anyone know if it would work with inkbirdās IBS-P01B ?
Only the IBS-P01R is supported, but it is likely that we can add support for the IBS-P01B as well, if you send me the BLE advertisements. See the link two post above how you can get these.
I bought an Inkbird IBS-P01R based on the Passive BLE Monitor supported devices list, but just found out that itās a 433 MHz device, not Bluetooth. Could someone point me to a document or FAQ that describes how to get the IBS-P01R working with Passive BLE Monitor?
In this issue this device is discussed. It was using the same format as the IBS-TH2. I saw you also asked the same question on github, lets see if @randrcomputers can shine a light on this.
Edit: In the next release, I will rename the Inkbird IBS-P01R to IBS-P01B
