Ok it happened. I thought i turned it off yesterday but this morning the status was ignition starting on the stove.
The logging says a lot. At a certain moment it ran out of pellets but that status got reset every time so the loop started again.
2023-12-05 21:51:57.521 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Flame On, Ambient temp: 22.9, Fan speed: 1, Flu gas temp: 142, Exh fan speed: 1400, PelletSpeed: 1, Error code: All OK, Setpoint temp: 21
2023-12-05 21:52:20.325 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Set hvac mode to off
2023-12-05 21:52:20.387 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Flame On, Ambient temp: 23.0, Fan speed: 1, Flu gas temp: 141, Exh fan speed: 1400, PelletSpeed: 1, Error code: All OK, Setpoint temp: 21
2023-12-05 21:52:57.543 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 23.0, Fan speed: 3, Flu gas temp: 151, Exh fan speed: 2870, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 21:53:57.547 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 23.2, Fan speed: 3, Flu gas temp: 143, Exh fan speed: 2880, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 21:54:57.442 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.9, Fan speed: 3, Flu gas temp: 139, Exh fan speed: 2880, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 21:55:57.446 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 23.1, Fan speed: 3, Flu gas temp: 137, Exh fan speed: 2880, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 21:56:57.458 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 23.2, Fan speed: 3, Flu gas temp: 130, Exh fan speed: 2870, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 21:57:57.467 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 23.3, Fan speed: 3, Flu gas temp: 122, Exh fan speed: 2870, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 21:58:57.477 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 23.1, Fan speed: 3, Flu gas temp: 115, Exh fan speed: 2880, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 21:59:57.527 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 23.0, Fan speed: 3, Flu gas temp: 109, Exh fan speed: 2870, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 22:00:57.535 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 23.1, Fan speed: 3, Flu gas temp: 104, Exh fan speed: 2840, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 22:01:57.488 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 21.3, Fan speed: 3, Flu gas temp: 98, Exh fan speed: 2850, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 22:02:57.495 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.3, Fan speed: 3, Flu gas temp: 93, Exh fan speed: 2840, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 22:03:57.506 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.8, Fan speed: 3, Flu gas temp: 87, Exh fan speed: 2830, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 22:04:57.541 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 23.0, Fan speed: 3, Flu gas temp: 83, Exh fan speed: 2830, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 22:05:57.531 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.9, Fan speed: 3, Flu gas temp: 78, Exh fan speed: 2830, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 22:06:57.538 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.9, Fan speed: 3, Flu gas temp: 74, Exh fan speed: 2820, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 22:07:57.557 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.9, Fan speed: 3, Flu gas temp: 72, Exh fan speed: 2830, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 22:08:57.586 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.9, Fan speed: 3, Flu gas temp: 71, Exh fan speed: 2270, PelletSpeed: 6, Error code: All OK, Setpoint temp: 21
2023-12-05 22:09:57.552 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.9, Fan speed: 3, Flu gas temp: 70, Exh fan speed: 2260, PelletSpeed: 6, Error code: All OK, Setpoint temp: 21
2023-12-05 22:10:57.566 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.7, Fan speed: 3, Flu gas temp: 70, Exh fan speed: 2260, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 22:11:57.577 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.7, Fan speed: 3, Flu gas temp: 69, Exh fan speed: 2240, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 22:12:57.573 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.7, Fan speed: 3, Flu gas temp: 72, Exh fan speed: 2250, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 22:13:57.476 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.6, Fan speed: 3, Flu gas temp: 78, Exh fan speed: 2240, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-05 22:14:57.486 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.5, Fan speed: 3, Flu gas temp: 82, Exh fan speed: 2240, PelletSpeed: 1, Error code: All OK, Setpoint temp: 21
2023-12-05 22:15:57.494 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.5, Fan speed: 3, Flu gas temp: 87, Exh fan speed: 2260, PelletSpeed: 1, Error code: All OK, Setpoint temp: 21
2023-12-05 22:16:57.497 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.5, Fan speed: 3, Flu gas temp: 95, Exh fan speed: 2250, PelletSpeed: 1, Error code: All OK, Setpoint temp: 21
2023-12-05 22:17:57.507 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.6, Fan speed: 3, Flu gas temp: 101, Exh fan speed: 2260, PelletSpeed: 1, Error code: All OK, Setpoint temp: 21
2023-12-05 22:18:57.575 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.5, Fan speed: 3, Flu gas temp: 109, Exh fan speed: 2260, PelletSpeed: 1, Error code: All OK, Setpoint temp: 21
2023-12-05 22:19:57.525 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.6, Fan speed: 3, Flu gas temp: 107, Exh fan speed: 2250, PelletSpeed: 1, Error code: All OK, Setpoint temp: 21
2023-12-05 22:20:57.531 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Flame On, Ambient temp: 22.6, Fan speed: 3, Flu gas temp: 106, Exh fan speed: 1870, PelletSpeed: 3, Error code: All OK, Setpoint temp: 21
2023-12-05 22:21:57.535 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Flame On, Ambient temp: 22.5, Fan speed: 1, Flu gas temp: 107, Exh fan speed: 1420, PelletSpeed: 1, Error code: All OK, Setpoint temp: 21
2023-12-05 22:22:57.541 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Flame On, Ambient temp: 22.6, Fan speed: 1, Flu gas temp: 112, Exh fan speed: 1400, PelletSpeed: 1, Error code: All OK, Setpoint temp: 21
2023-12-05 22:23:57.552 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Flame On, Ambient temp: 22.6, Fan speed: 1, Flu gas temp: 114, Exh fan speed: 1400, PelletSpeed: 1, Error code: All OK, Setpoint temp: 21
cut
2023-12-06 01:46:57.802 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Flame On, Ambient temp: 22.4, Fan speed: 1, Flu gas temp: 56, Exh fan speed: 1390, PelletSpeed: 1, Error code: All OK, Setpoint temp: 21
2023-12-06 01:47:57.825 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Flame On, Ambient temp: 22.4, Fan speed: 1, Flu gas temp: 54, Exh fan speed: 1390, PelletSpeed: 1, Error code: All OK, Setpoint temp: 21
2023-12-06 01:48:57.811 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Cooling down, Ambient temp: 22.3, Fan speed: 1, Flu gas temp: 52, Exh fan speed: 2840, PelletSpeed: 0, Error code: Out of pellets, Setpoint temp: 21
2023-12-06 01:48:57.833 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Out of pellets was reset !
2023-12-06 01:49:57.816 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.4, Fan speed: 3, Flu gas temp: 51, Exh fan speed: 2830, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-06 01:50:57.834 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 22.5, Fan speed: 3, Flu gas temp: 51, Exh fan speed: 2830, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
cut
2023-12-06 02:52:57.970 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Flame On, Ambient temp: 21.7, Fan speed: 1, Flu gas temp: 56, Exh fan speed: 1410, PelletSpeed: 1, Error code: All OK, Setpoint temp: 21
2023-12-06 02:53:57.880 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Flame On, Ambient temp: 21.6, Fan speed: 1, Flu gas temp: 55, Exh fan speed: 1400, PelletSpeed: 1, Error code: All OK, Setpoint temp: 21
2023-12-06 02:54:57.881 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Cooling down, Ambient temp: 21.6, Fan speed: 1, Flu gas temp: 53, Exh fan speed: 2750, PelletSpeed: 0, Error code: Out of pellets, Setpoint temp: 21
2023-12-06 02:54:57.890 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Out of pellets was reset !
2023-12-06 02:55:57.883 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 21.6, Fan speed: 3, Flu gas temp: 52, Exh fan speed: 2840, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-06 02:56:57.893 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 21.6, Fan speed: 3, Flu gas temp: 51, Exh fan speed: 2830, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-06 02:57:57.897 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 21.6, Fan speed: 3, Flu gas temp: 52, Exh fan speed: 2400, PelletSpeed: 6, Error code: All OK, Setpoint temp: 21
2023-12-06 02:58:57.907 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 21.6, Fan speed: 3, Flu gas temp: 52, Exh fan speed: 2250, PelletSpeed: 6, Error code: All OK, Setpoint temp: 21
2023-12-06 02:59:57.954 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 21.5, Fan speed: 3, Flu gas temp: 55, Exh fan speed: 2260, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-06 03:00:57.922 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 21.5, Fan speed: 3, Flu gas temp: 60, Exh fan speed: 2240, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-06 03:01:57.929 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 21.5, Fan speed: 3, Flu gas temp: 60, Exh fan speed: 2250, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-06 03:02:57.933 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 21.4, Fan speed: 3, Flu gas temp: 60, Exh fan speed: 2250, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-06 03:03:57.940 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 21.5, Fan speed: 3, Flu gas temp: 60, Exh fan speed: 2250, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-06 03:04:57.950 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 21.5, Fan speed: 3, Flu gas temp: 60, Exh fan speed: 2240, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-06 03:05:57.956 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 21.5, Fan speed: 3, Flu gas temp: 59, Exh fan speed: 2250, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-06 03:06:57.975 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 21.4, Fan speed: 3, Flu gas temp: 58, Exh fan speed: 2240, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-06 03:07:57.982 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 21.4, Fan speed: 3, Flu gas temp: 58, Exh fan speed: 2240, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-06 03:08:57.983 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 21.5, Fan speed: 3, Flu gas temp: 57, Exh fan speed: 2250, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-06 03:09:58.010 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Cooling down, Ambient temp: 21.3, Fan speed: 3, Flu gas temp: 56, Exh fan speed: 2650, PelletSpeed: 0, Error code: Ignition failure, Setpoint temp: 21
2023-12-06 03:09:58.020 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Ignition failure was reset !
2023-12-06 03:10:57.998 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 21.4, Fan speed: 3, Flu gas temp: 54, Exh fan speed: 2830, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
2023-12-06 03:11:58.009 DEBUG (MainThread) [custom_components.duepi_evo.climate] Duroflame Rembrand: Received burner: Ignition starting, Ambient temp: 21.3, Fan speed: 3, Flu gas temp: 52, Exh fan speed: 2820, PelletSpeed: 0, Error code: All OK, Setpoint temp: 21
From here this repeats
