Persisent notifications and critical notifications
So I figured I may as well crosspost this while it is fresh. I hope it helps someone.
I haven’t seen much on persistent_notification.create and notify.persistent_notification recently
Persistent notitifcations and Critical Notifications
What are I am talking about?
The service `persistent_notification.create’
3count
How is it different from The service 'notify.persistent_notification'
`notification_id` cannot be used with 'notify.persistent_notification'
notid
So you can send multiple messages that stack up on your notification panel.
This is true for either service.
Only persistent_notification.create accepts an ID
20count
Using notication_id ONLY the new message will arrive under that ID
Regardless of how many times it is sent.
Old messages with matching ID will be overwritten
So that’s details out of the way. Now some examples.
Example Message
service: persistent_notification.create
  message: There is an update in Os-Agent!
  title: Update message
basic
Add some Markdown
Bold	<b>My bold text</b> or in the UI **My bold text**
Cursive	<i>My cursive text</i>
Link	[Link](https://home-assistant.io/)
  message: <b>There is</b> <i>an update in</i> [Os-Agent!](https://github.com/home-assistant/os-agent)
with Spacing
  message: >-
    **There is** <i> an update in </i>
    *My cursive text*
    **My bold text**
compact using line breaks
  message: >-
    **There is** <i> an update in </i> [Os-Agent!](https://github.com/home-assistant/os-agent) </br>
    *My cursive text* <br></br>
    **My bold text**
This is the output of spacing or compact
masMD
complex example with variables and sensors.
The sensor
with quote marks
  notification_id: os-agent
  message: >-
    OS_Agent {{ states('sensor.os_agent_version_github') }} is
    available
    [Latest](https://github.com/home-assistant/os-agent/releases/latest)
    " wget https://github.com/home-assistant/os-agent/releases/download/{{
    states('sensor.os_agent_version_github') }}/os-agent_{{
    states('sensor.os_agent_version_github') }}_linux_aarch64.deb "
    " sudo dpkg -i os-agent_{{ states('sensor.os_agent_version_github')
  title: OS_Agent New Version
quoted
Plain and spaced
  message: >-
    OS_Agent is
    available
    wget https://github.com/home-assistant/os-agent/releases/download/1.4.0/os-agent_1.4.0_linux_aarch64.deb
    sudo dpkg -i os-agent_1.4.0_linux_aarch64.deb
Spaced with sensor as variable
  message: >-
    available
compact with sensor variables
  message: >-
    available<br></br>
    [Latest](https://github.com/home-assistant/os-agent/releases/latest)<br></br>
    states('sensor.os_agent_version_github') }}_linux_aarch64.deb<br></br> sudo
the result of Plain, Spaced with vars, or compact with variables
complex
Related automations
One Shot notification
This will disappear once you click on it. It will not return until the sensor attribute updates again.
The sensor via github integration
The Automation with variable version number message
alias: Os-Agent Update
description: OS Agent upgrade available
  - platform: state
    entity_id:
      - sensor.home_assistant_os_agent_latest_release
    attribute: tag                    ## <<<<<<<<< the attribute
condition:
  - condition: template
    value_template: >-
      {{ trigger.from_state.attributes.tag != "unavailable" and
      trigger.from_state.attributes.tag != "unknown"  }}
  - condition: not
    conditions:
      - condition: state
        entity_id: sensor.home_assistant_os_agent_latest_release
        state: unavailable
      - condition: state
        state: unknown
  - service: persistent_notification.create
      title: "There is an update in Os-Agent! "
      message: >-
        OS_Agent {{ states('sensor.home_assistant_os_agent_latest_tag') }} is
        available<br></br> [os-agent
        latest](https://github.com/home-assistant/os-agent) <br></br> wget
        }}/os-agent_1.4.0_linux_x86_64.deb<br></br> sudo dpkg -i os-agent_{{
        }}_linux_x86_64.deb<br></br>
mode: single
Critical notification
A notification that comes back and bugs you until you complete the task. Mine checks every morning. If the github version is higher the result will be “True” and then a message will be sent.
The else can be removed, I just had it in there for testing. One day I may set it up to be a clickable action or something. I just cut and past it onto my host console. After reading the changes from the link of course…
The top two are rest sensors.
They check the installed home assistant agent version and github agent version.
template:
    - sensor:
        - name: OS_agent Updater
          unique_id: os_agent_updater_version8123
          icon: mdi:memory
          state: >
             "{{ states('sensor.os_agent_version_github' ) > states('sensor.os_agent_version_installed' ) }}"
The Automation with variable HOST archtype and version number message
alias: os_agent version check
description: Check if the installed and released os_agent versions match
  - platform: sun
    event: sunrise
    offset: "0:59:00"
    enabled: true
  - platform: time
    at: "10:00:00"
    enabled: false
condition: []
  - service: homeassistant.update_entity
    data: {}
      entity_id: sensor.os_agent_version
    data: {}
      entity_id: sensor.os_agent_version_github
  - if:
      - condition: state
        state: "\"True\""
        for:
          hours: 0
          minutes: 0
          seconds: 0
        entity_id: sensor.os_agent_updater
    then:
          message: >-
            available<br></br>
            }}_linux_{{ states('sensor.host_arch')
          }}.deb<br></br> sudo dpkg -i os-agent_{{
            states('sensor.os_agent_version_github') }}_linux_{{ states('sensor.host_arch')
          }}.deb
      - service: notify.mobile_app_android_phone
          message: OS_Agent {{ states('sensor.os_agent_version_github') }} is available
            clickAction: https://github.com/home-assistant/os-agent/releases/latest
    else:
          title: OS_Agent was version checked
          message: "{{ now().timestamp() | timestamp_custom('%H:%M:%S %D') }}"
mode: single
Enjoy
falsetrue
edit added Host arch variable to last automation msg.
Thanks to @Tryfos yet-another-ignore-previous-unavailable-state
Thanks to @Friedrieck 2020 notify-to-persistent-notification
rest sensors…
You will need to make a long lived token via your profile button Capture in Home Assistant.
That will need to be saved to to your secrets.yaml
Don’t forget to add the Bearer addition!
rest_bearer: Bearer eyJ0eXAiOi......................
github OS-Agent version tag.
You can use the github integration if you can’t figure out the token for github. You need to :star: the repo.
sensor:                        ##  <<< sensor Only needed for top sensor entry
  - platform: rest
    name: OS Agent Version github
    unique_id: os_agent_rest_github8123
    resource: https://api.github.com/repos/home-assistant/os-agent/releases/latest
    username: !secret GITHUB_USERNAME
    password: !secret GITHUB_BEARER_TOKEN
    authentication: basic
    scan_interval: 604800     ## 1 week of seconds using Home Assistant Core Integration: Update entity
    value_template: "{{ value_json.tag_name | default(None)}}"
    headers:
      Accept: application/vnd.github.v3+json
      Content-Type: application/json
      User-Agent: Home Assistant REST sensor
OS-Agent Installed on Host
  - platform: rest
    unique_id: os_agent_rest_installed8123
    name: OS Agent Version Installed
    resource: http://localhost:8123/api/hassio/host/info
    value_template: "{{ value_json.data.agent_version }}"
    headers:
      Authorization: !secret rest_bearer
Host Architecture
  - platform: rest
    unique_id: host_arch8123
    resource: http://localhost:8123/api/hassio/supervisor/info
    value_template: "{{ value_json.data.arch }}"
    headers:
The template sensor
template:                  ##  <<< template Only needed for top template entry
 - sensor:
          icon: mdi:memory
          state: >
Other available HA endpoints
Regarding
as I don’t like to have that additional piece and also bind to my user account:
What about simply using the Supervisor token as e. g. @CentralCommand does (did) with
(first post, unfold Original Package for HA prior to 2022.4.0, unfold Update Notifications package):
command: 'curl http://supervisor/supervisor/info -H "Authorization: Bearer $(printenv SUPERVISOR_TOKEN)" | jq ''{"newest_version":.data.version_latest,"current_version":.data.version,"update_available":.data.update_available,"addons":[.data.addons[] | select(.update_available)]}'''
Looking at this part:
…which is pretty much following Authentication API | Home Assistant Developer Docs which is linked in the profile section at long lived tokens section at the bottom.
  • Can this be used together with a rest sensor?
  • Or is this specifically only for command_line sensors, as only there the SUPERVISOR_TOKEN is available in the environment the command is run?
Try it…
It’s still a long live token
Not necessary anymore for my use-case. Provided out of the box meanwhile.
