Person Cards - Show Off Yours
I’m new and I just started and thanks to your examples I’m learning. I have a problem with the configuration and I don’t know where the error is. can you please help me?
under the wifi entry the string appears and I have to leave any letter at the end to make the card appear otherwise I receive an error. it’s as if by not putting a final letter, the wifi part is not complete but at the same time it is not correct
many thanks
type: custom:button-card
entity: person.eugenio
variables:
  phone_battery_level_sensor: '[[[ return states["sensor.magic2_battery_level"].state]]]'
  phone_battery_state_sensor: '[[[ return states["sensor.magic2_battery_state"].state]]]'
  proximity_sensor: '[[[ return states["sensor.casa_eugenio_distanza"].state]]]'
  phone_wifi_sensor: '[[[ return states["sensor.magic2_wifi_bssid"].state]]]'
aspect_ratio: 2/1
show_entity_picture: true
show_name: false
hold_action:
  action: none
state:
  - value: home
    styles:
      card:
        - background-color: '#202124'
      custom_fields:
        icon:
          - border-color: '#77c66e'
  - value: not_home
    styles:
      card:
      custom_fields:
        icon:
          - border-color: deepskyblue
  - value: null
    styles:
      card:
      custom_fields:
        icon:
          - border-color: '#B83838'
styles:
  card:
    - border-radius: 5%
    - padding: 2% 5% 5% 5%
    - color: gray
    - font-size: 10px
    - text-shadow: 0px 0px 0px black
    - text-transform: capitalize
    - justify-self: center
    - align-content: center
  grid:
    - grid-template-areas: '"icon status" "icon battery" "icon wifi" "icon proximity"'
    - grid-template-columns: 1.5fr 1fr
    - grid-template-rows: 1fr 1fr 1fr 1fr
  name:
    - font-size: 15px
    - align-self: middle
    - justify-self: start
  custom_fields:
    icon:
      - clip-path: circle()
      - width: 60%
      - pointer-events: none
      - display: grid
      - border: 5px solid
      - border-color: '#808080'
      - border-radius: 500px
      - margin: 0 0 0 0
      - opacity: 1
      - align-self: center
    status:
      - color: white
    proximity:
      - color: white
    wifi:
      - color: white
      - '--text-wifi-color-sensor': >-
          [[[ if (variables.phone_wifi_sensor == '<not connected>') return
          "#aaaaaa"; ]]]
    battery:
      - color: white
      - '--text-color-sensor': >-
          [[[ if (variables.magic2_battery_level_sensor < 35) return "#EF4F1A";
custom_fields:
  icon: >
    [[[ return entity === undefined ? null : `<img
    src="${states[entity.entity_id].attributes.entity_picture}" width="100%">`;
  status: |
      if (entity.state =='not_home') {
      return `<ha-icon icon="mdi:home-export-outline"
        style="width: 20px; height: 20px; color: '#888888';">
        </ha-icon><span> On the way</span>`;
      if (entity.state =='home') {
      return `<ha-icon
        icon="mdi:home"
        style="width: 40px; height: 40px; color: 888888;">
        </ha-icon><span> ${entity.state}</span>`;
      } else {
        if (entity.state =='[YOUR OTHER LOCATION]') {
        return `<ha-icon icon="mdi:pizza"
          style="width: 40px; height: 40px; color: '#888888';">
        else{
        return `<ha-icon
          icon="mdi:map-marker-radius"
          style="width: 40px; height: 20px; color: 888888;">
  battery: |
      if (variables.magic2_battery_state_sensor =='charging') {
        return `<ha-icon
        icon="mdi:battery-charging-medium"
        style="width: 20px; height: 20px; color: #888888;">
        </ha-icon> <span><span style="color: var(--text-color-sensor);">${variables.magic2_battery_state_sensor}% Battery</span></span>`;
      } else {
        return `<ha-icon
        icon="mdi:battery-medium"
        style="width: 40px; height: 40px; color: #888888;">
        </ha-icon> <span><span style="color: var(--text-color-sensor);">${variables.phone_battery_level_sensor}% Battery</span></span>`;
  proximity: |
      return `<ha-icon
        icon="mdi:map-marker-distance"
        </ha-icon>  <span>\<span style="color: var(--text-color-sensor);">${variables.proximity_sensor} Km</span></span>`
  wifi: |
      if (variables.sensor.magic2_wifi_bssid =='not connected') {
         return `<ha-icon
         icon="mdi:wifi"
         style="width: 20px; height: 20px; color: var(--text-wifi-color-sensor);">
         </ha-icon> <span><span style="color: var(--text-wifi-color-sensor);">Disconnected</span></span>`;
       } else {
         return `<ha-icon
         icon="mdi:wifi"
         </ha-icon> <span><span style="color: var(--text-color-sensor);">${variables.phone_wifi_sensor}</span></span>`;
       t
by clicking on the link there is my card with the error
https://i.postimg.cc/zvcLh96K/person.png
Hi, I do not know if this could be the problem but you missed a ; at the end. It’s the only thing different I can see.
Hi d13g0m0nt3s, thank you for help.
I added ; at the end, but nothing changed…
Hi again I think I found the error. You are no using the variable
The if should be:
Not
If (variables.sensor.magic2_wifi_bssid
nothing…
I think the error is the syntax. I forgot something that doesn’t close the circle
I recreate the card and worked for me replacing the variable. Also noticed a loose t letter at the end of your code. Change the variable and remove the t
changed the variable and removed the “t”, but nothing…
this is the last version
variables:
aspect_ratio: 2/1
show_name: false
hold_action:
  action: none
state:
  - value: home
    styles:
      card:
      custom_fields:
        icon:
  - value: not_home
    styles:
      card:
      custom_fields:
        icon:
  - value: null
    styles:
      card:
      custom_fields:
        icon:
styles:
  card:
    - border-radius: 5%
    - color: gray
    - font-size: 10px
  grid:
  name:
    - font-size: 15px
  custom_fields:
    icon:
      - width: 60%
      - display: grid
      - border: 5px solid
      - margin: 0 0 0 0
      - opacity: 1
    status:
      - color: white
    proximity:
      - color: white
    wifi:
      - color: white
          "#aaaaaa"; ]]]
    battery:
      - color: white
custom_fields:
  icon: >
  status: |
      return `<ha-icon
        icon="mdi:home"
      } else {
        else{
        return `<ha-icon
  battery: |
        return `<ha-icon
      } else {
        return `<ha-icon
  proximity: |
      return `<ha-icon
  wifi: |
      if (states['variables.phone_wifi_sensor'].state =='<not connected>') {
        return `<ha-icon
        icon="mdi:wifi"
      } else {
        return `<ha-icon
        icon="mdi:wifi"
        </ha-icon> <span><span style="color: var(--text-color-sensor);">${states['sensor.magic2_wifi_bssid'].state}</span></span>`;
Now you missed two ]] at the end and remove the last ;
You are fixing mistakes and creating another :sweat_smile:
wifi: |
        return `<ha-icon
        icon="mdi:wifi"
      } else {
        return `<ha-icon
        icon="mdi:wifi"
Should be
wifi: |
        return `<ha-icon
        icon="mdi:wifi"
      } else {
        return `<ha-icon
        icon="mdi:wifi"
if after the last parenthesis I don’t put any sign and leave it blank, the card disappears and I get this message:
ButtonCardJSTemplateError: TypeError: Cannot read properties of undefined (reading ‘state’) in ‘if (states[‘variables.phone_wifi_sensor’].state ==’‘) { return `<ha-icon i…’
You are making more changes to your code that do not need to be changed
${states[‘sensor.magic2_wifi_bssid’].state}
Your are using a states like if was a variable
Should be like your initial code
And the if is wrong too
Please take your initial code, change the variable in the if ( and remove the t, it should work
wifi: |
      if (variables.phone_wifi_sensor =='not connected') {
         return `<ha-icon
         icon="mdi:wifi"
       } else {
         return `<ha-icon
         icon="mdi:wifi"
I did as you said and the problem disappeared but I don’t have the wifi connection. I have an empty space (which is better than my initial situation)
You have the wrong sensor in top of the code
‘[[[ return states[“sensor.magic2_wifi_bssid”].state]]]’
Try another wifi sensor from your mobile, somthing like “your_mobile_wifi_connection”
Post the actual wifi: part only, please.
I notice that you have duplicate tags in all the custom fields. That do not produce any error but is unnecessary. You have <span><span style…</span></span> you can remove the first and last in all your custom fields.
Try what Braakie said too. With my own sensor worked as you can see in my previous screenshot
d13g0m0nt3s and Braakie thank you! It works!
Hi, sorry for the late response, but i was busy with other things.
i don’t know if this line really works. Can you porvide me with a screenshot, so i can understand what’s really happening?
Used a mushroom template card with info from life360 - now that it is working again!
Badge is a representation of the battery charge with the colour dependant on the level or blue if it is charging.
multiline secondary true looks nicer but this is part of a large dashboard and it starts to overflow other cards
type: custom:mushroom-template-card
primary: My Name
secondary: |-
  {%- set person = "my_name" %}
    {% if is_state("device_tracker.life360_" + person, "home") -%}
      Home
      {%- elif state_attr("device_tracker.life360_" + person, "place",) is none -%}
        {{state_attr("device_tracker.life360_" + person, "address") }}
      {%- else -%}
        {{ state_attr("device_tracker.life360_" + person, "place") }}
    {%- endif %}
icon: ''
entity: device_tracker.life360_my_name
picture: >-
  {%- set pic = state_attr("device_tracker.life360_" + person, "entity_picture")  %}
  {{ pic }}
fill_container: true
multiline_secondary: false
badge_icon: >-
  {%- set battery = state_attr("device_tracker.life360_" + person,
  "battery_level") %}
    {% if state_attr("device_tracker.life360_" + person, "battery_charging") is true -%}
      {%- set batterychg = "charging-" %}
    {% else %}
      {%- set batterychg = "" %}
    {%- endif %}
  {% if battery < 40 -%}
        mdi:battery-{{ batterychg }}30
      {%- elif battery < 70 -%}
        mdi:battery-{{ batterychg }}60
      {% else %}
        mdi:battery-{{ batterychg }}90
    {%- endif %}
badge_color: >-
  "battery_level") %}
      blue
    {% else %}
            red
            yellow
          {% else %}
            green
      {%- endif %}
  {%- endif %}
Off topic question, what you have done with Life360 integration to make it work again? I try to log in again, and no success. It’s said wrong credentials.
Thank you
Here is mine:
type: custom:stack-in-card
mode: vertical
card_mod:
  style: |
    ha-card {
      border: none !important;
     # background: none !important;
      --vertical-stack-card-gap: 10px;
      background: url('/local/MyPictures/rock wall.jpg');
      background-size: 200%;
cards:
  - type: custom:stack-in-card
    mode: horizontal
    card_mod:
      style: |
        ha-card {
    cards:
      - type: custom:mushroom-person-card
        entity: person.yevgeniy
        layout: vertical
        icon_type: entity-picture
        primary_info: state
        secondary_info: false
        card_mod:
          style:
            mushroom-shape-avatar$: |
              .picture {
               display: flex;
               border-radius: 50%;
               {% if states(config.entity) == 'home' %}
                 animation: pinggreen 6s infinite;
               {% else %}
                 animation: pingred 6s infinite;
               {% endif %}
              @keyframes pinggreen {
               0% {box-shadow: 0 0 5px 3px rgba(var(--rgb-green), 0.9);}
               100% {box-shadow: 0 0 5px 15px transparent;}
              @keyframes pingred {
               0% {box-shadow: 0 0 5px 3px rgba(var(--rgb-red), 0.9);}
              ha-card {
              margin-left: -50px !important;
        mode: vertical
        card_mod:
          style: |
            ha-card {
              margin-left: -55px !important;
        cards:
            primary: >-
              {%- if is_state('sensor.sm_s918u_battery_state', 'charging') %}
              Charging 🔌
              {%- elif is_state('sensor.sm_s918u_battery_state', 'discharging')
              Discharging 🙃
              {% else %}
              Full 💯
              {% endif %}
            secondary: Battery {{ states('sensor.sm_s918u_battery_level') }}%
            entity: sensor.sm_s918u_battery_state
            icon: |2
                    {% set bl = states('sensor.sm_s918u_battery_level') | int %}
                    {% if bl < 10 %} mdi:battery-outline
                    {% elif bl < 20 %} mdi:battery-10
                    {% elif bl < 30 %} mdi:battery-20
                    {% elif bl < 40 %} mdi:battery-30
                    {% elif bl < 50 %} mdi:battery-40
                    {% elif bl < 60 %} mdi:battery-50
                    {% elif bl < 70 %} mdi:battery-60
                    {% elif bl < 80 %} mdi:battery-70
                    {% elif bl < 90 %} mdi:battery-80
                    {% elif bl < 100 %} mdi:battery-90
                    {% elif bl == 100 %} mdi:battery
                    {% else %} mdi:battery-unknown
                    {% endif %}
            icon_color: |2-
                    {% if bl < 10 %} red
                    {% elif bl < 20 %} red
                    {% elif bl < 30 %} red
                    {% elif bl < 40 %} orange
                    {% elif bl < 50 %} orange
                    {% elif bl < 60 %} green
                    {% elif bl < 70 %} green
                    {% elif bl < 80 %} green
                    {% elif bl < 90 %} green
                    {% elif bl < 100 %} green
                    {% elif bl == 100 %} green
                    {% else %} grey
                    {% endif %}
            card_mod:
              style: |
                ha-card {
                  justify-content: center;
                  --chip-icon-size: 24px;
                  --chip-height: 54px;
                  --chip-with:
                  width: var(--chip-height) !important;
                  border-radius: 50% !important;
              alignment: center
  - type: custom:mushroom-chips-card
    chips:
      - type: entity
        card_mod:
          style: |
            ha-card {
              font-size: 30px !important;
        entity: sensor.sm_s918u_geocoded_location
        icon: mdi:google-maps
        use_entity_picture: false
    card_mod:
      style: |
        ha-card {
          margin-left: -23px !important;
    alignment: center
Mine is pretty simple. I have a 15.6" uPerfect vertical monitor connected to a pi400.
  • I have a large HOME and AWAY status so you can see it across the room 15m.
  • Mushroom Person Card display status of each person.
When up close you can click on a card to show a map of were the person is
AWAY status, turns OFF heat pumps and other items in the house.
HOME & AWAY Status can be set manually by hitting the sticky floating navigation menu button at the bottom of the page.
HOME & AWAY Status is also set automatically using device tracker and proximity intergrations.
Creating Avatars I tried a fair few applications. Microsoft Teams Avatar App gave some good results with realistic results.
Setup instructions for Microsoft Teams Avatars is [HERE]. It is FREE and you can create 3 different Avatars at a time and just use the snip tool or print screen to copy the image in the app. (Set up avatars for Microsoft Teams - Microsoft Teams | Microsoft Learn)
