sure, np.
now, given the fact you use the same code for all buttons, you could drop all of that generic yaml in a template and only use the entity in the main button config.
O and btw, you are still. using those colors in the custom fields html code, which seems no longer required. Why not just set most of those options directly in the styles section and only use specifics inside the html for the custom fields
battery: |
if (states['sensor.oneplus_battery_state'].state =='charging') {
return `<ha-icon
icon="mdi:battery-charging"
style="width: 20px; height: 20px; color: var(--text-color-sensor);">
</ha-icon> <span><span style="color: var(--text-color-sensor);">${states['sensor.oneplus_battery_level'].state}% battery</span></span>`;
} else {
return `<ha-icon
icon="mdi:battery"
the only thing depending on the state of that particular entity is the icon…so add most of that to the
battery:
- padding: 0.5em 0px
- align-self: middle
- justify-self: start
and only change the icon based on the template
etc
etc
I didnt test it, but I believe you could at least do this:
Yaml
- type: custom:button-card
entity: person.XxX
aspect_ratio: 1/1
show_entity_picture: true
show_name: true
hold_action:
action: none
state:
- value: home
styles:
custom_fields:
icon:
- border-color: '#77c66e'
- icon-color: green
- value: not_home
styles:
card: null
custom_fields:
icon:
- border-color: '#EF4F1A'
- value: work
styles:
custom_fields:
icon:
- border-color: orange
- value: lyon
styles:
custom_fields:
icon:
- border-color: blue
- value: lamures
styles:
custom_fields:
icon:
styles:
card:
- border-radius: 5%
- padding: 5%
- color: gray
- font-size: 9px
- text-shadow: 0px 0px 0px black
- text-transform: capitalize
- justify-self: end
- color: |
if (entity.state == 'not_home') return "#EF4F1A";
if (entity.state == 'home') return "#77c66e";
if (entity.state == 'work') return "orange";
return "blue";
grid:
- grid-template-areas: '"icon status" "n n" "battery proximity" "wifi alarm" "sd sd"'
- grid-template-columns: 2fr
- grid-template-rows: 2fr min-content min-content min-content min-content
name:
- font-size: 15px
- padding-bottom: 10px
custom_fields:
icon:
- clip-path: circle()
- width: 80%
- pointer-events: none
- display: grid
- border: 5px solid
- border-color: gray
- border-radius: 500px
- margin: 0 +10% 0 0
- justify-self: end
- opacity: 1
status:
- align-self: start
- justify-self: end
- width: 20px
- height: 20px
proximity:
- justify-self: end
- numeric_precision: 2
- width: 20px
- height: 20px
wifi:
- width: 20px
- height: 20px
battery:
- width: 20px
- height: 20px
alarm:
- justify-self: end
- width: 20px
- height: 20px
calendar:
- justify-self: end
custom_fields:
icon: >
[[[ return entity === undefined ? null : `<img
src="${states[entity.entity_id].attributes.entity_picture}"
width="100%">`; ]]]
status: |
if (entity.state =='not_home') {
return `<ha-icon icon="mdi:home-export-outline" style="color: '#EF4F1A';">
</ha-icon><span> Away</span>`;
if (entity.state =='home') {
return `<ha-icon icon="mdi:home" style="color: #77c66e;">
</ha-icon><span> ${entity.state} </span>`;
if (entity.state =='work') {
return `<ha-icon
icon="mdi:briefcase" style="color: orange;">
</ha-icon><span> ${entity.state}</span>`;
else {
return `<ha-icon
icon="mdi:map-marker-radius" style="color: blue;">
proximity: |
return `<ha-icon icon="mdi:map-marker-distance"
</ha-icon> <span>\<span>${states['proximity.XxX'].state} Kms</span></span>`
battery: |
return `<ha-icon icon="mdi:battery-charging">
</ha-icon> <span><span>${states['sensor.oneplus_battery_level'].state}% battery</span></span>`;
} else {
return `<ha-icon icon="mdi:battery" >
</ha-icon> <span><span >${states['sensor.oneplus_battery_level'].state}% battery</span></span>`;
wifi: |
if (states['sensor.oneplus_wifi_connection'].state =='<not connected>') {
return `<ha-icon icon="mdi:wifi" >
</ha-icon> <span><span >Disconnected</span></span>`;
} else {
</ha-icon> <span><span >${states['sensor.oneplus_wifi_connection'].state}</span></span>`;
alarm: |
return `<ha-icon icon="mdi:alarm">
</ha-icon> <span>\<span >${states['sensor.oneplus_next_alarm'].state}</span></span>`
nope… that was wrong, its been some time I made those larger buttons with all custom fields in html… sorry. We need the dimension in the custom fields, because there’s more than only then icon…
This should work
entity: person.marijn
aspect_ratio: 1/1
show_name: true
hold_action:
action: none
styles:
card:
- border-radius: 5%
- padding: 5%
- color: gray
- font-size: 9px
- justify-self: end
- color: |
return "blue";
grid:
- grid-template-areas: '"icon status" "n n" "battery proximity" "wifi alarm"'
name:
- font-size: 15px
custom_fields:
icon:
- width: 80%
- display: grid
- border: 5px solid
- border-color: |
return "blue";
- justify-self: end
- opacity: 1
status:
- align-self: start
- justify-self: end
proximity:
- justify-self: end
wifi:
battery:
alarm:
- justify-self: end
calendar:
- justify-self: end
custom_fields:
icon: >
width="100%">`; ]]]
status: |
return `<ha-icon icon="mdi:home" style="width: 20px; height: 20px;color: #77c66e;">
return `<ha-icon
icon="mdi:briefcase" style="width: 20px; height: 20px color: orange;">
else {
return `<ha-icon
icon="mdi:map-marker-radius" style="width: 20px; height: 20px color: blue;">
proximity: |
return `<ha-icon icon="mdi:map-marker-distance" style="width: 20px; height: 20px">
</ha-icon> Distance <span><span>${states['sensor.thuis_marijn_distance'].state} Kms</span></span>`
battery: |
if (states['sensor.marijn_battery_state'].state =='charging') {
return `<ha-icon icon="mdi:battery-charging" style="width: 20px; height: 20px">
</ha-icon> <span><span>${states['sensor.marijn_battery_level'].state}% battery</span></span>`;
} else {
return `<ha-icon icon="mdi:battery" style="width: 20px; height: 20px">
</ha-icon> <span><span >${states['sensor.marijn_battery_level'].state}% battery</span></span>`;
wifi: |
if (states['sensor.marijn_connection_type'].state =='not connected') {
return `<ha-icon icon="mdi:wifi" style="width: 20px; height: 20px">
} else {
</ha-icon> <span><span >${states['sensor.marijn_connection_type'].state}</span></span>`;
alarm: |
return `<ha-icon icon="mdi:alarm" style="width: 20px; height: 20px">
</ha-icon> <span><span >${states['sensor.next_alarm'].state}</span></span>`
Note: if you still want to colorize the custom fields, you have to get those colors back in there, per custom field
I did ofc change several entity_id’s so watch out for those, and also, you apparently didn’t migrate your Proximity integration yet, as that entity you use there is legacy now… just remember to change it in the near future
I’d take out the words Distance and Battery from those fields, the icon says it all, and it brings more balance to the card
also, consider using the
battery: |
</ha-icon> <span><span>${helpers.localize(states['sensor.marijn_battery_level'])} </span></span>`;
} else {
</ha-icon> <span><span >${helpers.localize(states['sensor.marijn_battery_level'])}</span></span>`;
helpers.localize()
functionality, which takes care of the units for you, and localization of states to your language
or compact a bit more:
battery: |
[[[ var mdi = states['sensor.marijn_battery_state'].state =='Charging'
? "mdi:battery-charging" : "mdi:battery";
return `<ha-icon icon= ${mdi} style="width: 20px; height: 20px">
</ha-icon><span>${helpers.localize(states['sensor.marijn_battery_level'])}</span>`;
wifi: |
[[[ var id = states['sensor.marijn_connection_type'];
return `<ha-icon icon=${id.attributes.icon} style="width: 20px; height: 20px">
</ha-icon> <span >${helpers.localize(id)}</span>`;
you see the options are endless
have fun !
A bit more compressed
aspect_ratio: 1/1
show_name: true
hold_action:
action: none
styles:
card:
- border-radius: 5%
- padding: 5%
- font-size: 9px
- color: |
[[[ if (entity.state == 'not_home') return '#EF4F1A';
if (entity.state == 'home') return '#77c66e';
if (entity.state == 'work') return 'orange';
return 'blue'; ]]]
grid:
- grid-template-areas: '"picture status" "n n" "battery proximity" "wifi alarm"'
name:
- font-size: 15px
- font-weight: bold
custom_fields:
picture:
- width: 80%
- display: grid
- border: 5px solid
- border-color: |
return "blue";
- border-radius: 100%
- justify-self: end
- opacity: 1
status:
- align-self: start
- justify-self: end
proximity:
- justify-self: end
wifi:
battery:
alarm:
- justify-self: end
# not used?
# calendar:
# - padding: 0.5em 0px
# - align-self: middle
# - justify-self: end
custom_fields:
picture: >
[[[ return `<img src=${states[entity.entity_id].attributes.entity_picture}
width="100%">`; ]]]
status: |
[[[ if (entity.state =='not_home') {
return `<ha-icon icon=mdi:home-export-outline style="color:'#EF4F1A';"></ha-icon>
<span> ${helpers.localize(entity)}</span>`;
return `<ha-icon icon=mdi:home style="width:20px;color: #77c66e;"></ha-icon>
<span> ${helpers.localize(entity)} </span>`;
return `<ha-icon icon=mdi:briefcase style="width:20px;color:orange;"></ha-icon>
else {
return `<ha-icon icon=mdi:map-marker-radius style="width:20px;color:blue;"></ha-icon>
proximity: |
[[[ return `<ha-icon icon=mdi:map-marker-distance style="width:20px;"></ha-icon>
<span>${helpers.localize(states['sensor.thuis_marijn_distance'])}</span>`; ]]]
battery: |
? 'mdi:battery-charging' : 'mdi:battery';
return `<ha-icon icon= ${mdi} style="width:20px;"></ha-icon>
<span>${helpers.localize(states['sensor.marijn_battery_level'])}</span>`; ]]]
wifi: |
return `<ha-icon icon=${id.attributes.icon} style="width:20px;"></ha-icon>
<span >${helpers.localize(id)}</span>`; ]]]
alarm: |
[[[ return `<ha-icon icon=mdi:alarm style="width:20px;"></ha-icon>
<span >${states['sensor.next_alarm'].state}</span>`; ]]]
But honestly: if you ask me, there is too much info for 1 button card.
having 4 of these inside a grid makes the card go way out of proportion, and make all text undreadable.
I believe 2 really is the max for a stack/grid. And, then the text is too small still…
compare:
to
ofc all colors have a meaning, and certain states are only shown when relevant
