Just wanted to share a new custom component (integration) that I have been working on for PetKit devices (smart pet feeders, litter boxes, water fountain).
The currently supported devices include:
Feeders:
- Fresh Element Infinity
- Fresh Element Solo
- Fresh Element Mini Pro
- Fresh Element Gemini
- Fresh Element
Water Fountain:
- Eversweet 3 Pro
- Eversweet 5 Mini
- Eversweet Solo 2
Litter Boxes:
- Pura X
- Pura MAX with/without Pura Air deodorizer
Purifiers:
- Air Magicube
Some notable features:
- Setup is done through the UI
- Monitor your feeders along with control of administering extra manual feedings (allowed feeding amounts are customized based on the feeder that you have)
- Monitor and control your bluetooth-only PetKit water fountain**
- All the monitoring and control you’d ever want for your litter boxes and some details that are not even presented in the PetKit app.
- Entities created for pets on your account - for cats, if you own a PetKit litter box, an extra entity is created that shows the most recent weight as measured by the litter box (works even if you have multiple PetKit litter boxes!)
** Getting up-to-date info and controlling PetKit water fountains requires having the BLE relay enabled in the PetKit app (requires a compatible PetKit device that can connect to the bluetooth-only water fountain).
If you do decide to use this integration, please be sure to read all of the documentation on the GitHub repo!
