Philips Android TV Ambilights (Light) component
I think my issue may have been unrelated to this component specifically. I had to reboot my VM host earlier (on which Hassos is hosted), and since coming back online, the component is once again functioning.
Weirdly, I had restarted both HA and the VM earlier today but it didn’t make a difference.
I’ve been using the ambilight light component for some time now and it’s been absolutely brilliant. I’ve recently started trying to play with the ambilight+yeelight component and have had mixed results. I’ve got 2 yeelights and have added 2 switches to toggle them following the TV’s ambilight. It seems though that only 1 will ever work. I restart HA, toggle 1 of the switches and it works as expected, but the second switch does nothing. Any ideas?
Cheers,
Dean
struggling to make this work on a philips 55oled854, cant seem to query the nodeid
Hello! Amazing component! Everything is working for me, but with the last Philips firmware update (TPM191E _ 101.001.079.005) I can’t pick colors and the Manual mode isn’t working anymore :confused:
Huge thank you in advance for your help :grin:
I also just started having API errors out of nowhere and it can’t control my ambilight anymore.
I was able to get the username and password by using the method mentioned here:
But the light will just show it is unavailable sadly. Anyone any idea how to fix that?
Update : Problem solved - always check if you remove ‘s’ from ‘https’ everywhere :slight_smile:
Did anyone from you manage to connect more than one yeelight source with yeelight switch? I created two switches, but only one is able to work properly, when the first one will fail or will shut down then the the second one starts working.
I have a 2020 Saphi Philips tv.
I installed this component from HACS, because i’m able to pull ambilight values from JointSpace API without authorization, i made adjustments to configuration.yaml and python code like BlodKolle mentioned few post before.
But i have one problem, i can’t manage this component from home assistant because entity is marked as “unavailable” the reason pointed there is :
22222
https://i.imgur.com/q5oR5TA.jpg
11111
https://imgur.com/xbkZ6kr
Do you know how to resolve this problem, and do you know source of this entity_id issue?
I did all configuration like in description above.
I’ve updated a 55pus7504 firmware and the ambilight+hue plugin doesn’t work, then I’ve tested from id 2131230770 to 2131230789 and with ¨ id 2131230783 ¨ it works
switch:
  • platform: philips_ambilight+hue
    host: 192.168.1.XXX
    username: !secret philips_username
    password: !secret philips_password
    id: 2131230783 # ambilight_hue_off node id. Default is 2131230774, but some newer TVs use 2131230778 or 2131230783 instead.
    scan_interval: 5
I’m having the same problem, did you get any further with this?
Same problem for me.
I find the new id by installing pylips. After installing the requirement you need to use this command :
sudo python3 pylips.py --host !philips_tv_ip --user !philips_tv_username --pass !philips_tv_password --command get --path 'menuitems/settings/structure' --verbose True > settings_dump.txt
Open settings_dump.txt and search the key ambilight_hue_off. Use the node_id related to it.
For my 50PUS7354 it was 2131230783.
Good luck,
Lou_juicy
Is this integration still in development or it was deprecated?
hi, thank you for this wonderful integration!
i noticed that since i installed the integration, the ambilight is no longer in sync with the tv switch on/off. does anyone else experience the same?
anyone figured out how to fix the issues of the custom components ambihue & ambilights till ha update 2021.4.6???
Newer Ambilight+Hue ON/OFF switch:
I’ve made fork with updated manifest for newer HA and some other changes (no need to setup node id - it uses native Phlips Ambilight+Hue API)
Thanks for this Mr_Groch.
I’m trying it out now, and so far it works like a charm.
For everyone who have issues with this Ambilight component, here is my modified code of the light.py that work like a charm for me :slightly_smiling_face:
### Home Assistant Platform to integrate Phillip TVs' Ambilight as a light entity using the JointSpace API ###
import json
import string
import requests
import homeassistant.helpers.config_validation as cv
import voluptuous as vol
from homeassistant.components.light import (ATTR_BRIGHTNESS, LightEntity, PLATFORM_SCHEMA, ATTR_HS_COLOR, ATTR_TRANSITION,
                                            SUPPORT_BRIGHTNESS, SUPPORT_COLOR, SUPPORT_TRANSITION, ATTR_EFFECT, SUPPORT_EFFECT)
from homeassistant.const import (CONF_HOST, CONF_NAME, CONF_USERNAME, CONF_PASSWORD)
from requests.auth import HTTPDigestAuth
from requests.adapters import HTTPAdapter
DEFAULT_DEVICE = 'default'
DEFAULT_HOST = '127.0.0.1'
DEFAULT_USER = 'user'
DEFAULT_PASS = 'pass'
DEFAULT_NAME = 'TV Ambilights'
BASE_URL = 'https://{0}:1926/6/{1}' # for older philps tv's, try changing this to 'http://{0}:1925/1/{1}'
DEFAULT_HUE = 360
DEFAULT_SATURATION = 0
DEFAULT_BRIGHTNESS = 255
TIMEOUT = 5.0
CONNFAILCOUNT = 5
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
	vol.Required(CONF_HOST, default=DEFAULT_HOST): cv.string,
	vol.Required(CONF_USERNAME, default=DEFAULT_USER): cv.string,
	vol.Required(CONF_PASSWORD, default=DEFAULT_PASS): cv.string,
	vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string
# these are the names of the effects, change the names in the quotes to change the name displayed on the front-end
EFFECT_MANUAL = "Manual"
EFFECT_STANDARD = "Standard"
EFFECT_NATURAL = "Natural"
EFFECT_IMMERSIVE = "Football"
EFFECT_VIVID = "Vivid"
EFFECT_GAME = "Game"
EFFECT_COMFORT = "Comfort"
EFFECT_RELAX = "Relax"
EFFECT_ADAP_BRIGHTNESS = "Lumina"
EFFECT_ADAP_COLOR = "Colora"
EFFECT_RETRO = "Retro"
EFFECT_SPECTRUM = "Spectrum"
EFFECT_SCANNER = "Scanner"
EFFECT_RHYTHM = "Rhythm"
EFFECT_RANDOM = "Party"
DEFAULT_EFFECT = EFFECT_MANUAL
# this is the list of effects, you can safely remove any effects from the list below to remove them from the front-end
AMBILIGHT_EFFECT_LIST = [EFFECT_MANUAL, EFFECT_STANDARD, EFFECT_NATURAL, EFFECT_IMMERSIVE, EFFECT_VIVID,
                        EFFECT_GAME, EFFECT_COMFORT, EFFECT_RELAX, EFFECT_ADAP_BRIGHTNESS, EFFECT_ADAP_COLOR,
                        EFFECT_RETRO, EFFECT_SPECTRUM, EFFECT_SCANNER, EFFECT_RHYTHM, EFFECT_RANDOM]
def setup_platform(hass, config, add_devices, discovery_info=None):
	name = config.get(CONF_NAME)
	host = config.get(CONF_HOST)
	user = config.get(CONF_USERNAME)
	password = config.get(CONF_PASSWORD)
	add_devices([Ambilight(name, host, user, password)])
OLD_STATE = [DEFAULT_HUE, DEFAULT_SATURATION, DEFAULT_BRIGHTNESS, DEFAULT_EFFECT]
class Ambilight(LightEntity):
    def __init__(self, name, host, user, password):
        self._name = name
        self._host = host
        self._user = user
        self._password = password
        self._state = None
        self._connfail = 0
        self._brightness = None
        self._hs = None
        self._available = False
        self._effect = None
        self._session = requests.Session()
        self._session.mount('https://', HTTPAdapter(pool_connections=1))
    @property
    def name(self):
        return self._name
    @property
    def is_on(self):
        return self._state
    @property
    def available(self):
        return self._available
    @property
    def supported_features(self):
        return SUPPORT_BRIGHTNESS | SUPPORT_COLOR | SUPPORT_EFFECT
    @property
    def effect_list(self):
        return AMBILIGHT_EFFECT_LIST
    @property
    def brightness(self):
        return self._brightness
    @property
    def hs_color(self):
        return self._hs
    @property
    def effect(self):
        return self._effect
    @property
    def should_poll(self):
        return True
    def turn_on(self, **kwargs):
        if ATTR_TRANSITION in kwargs:
            # Here we save current color and brightness
            convertedHue_old = int(self._hs[0]*(255/360))
            convertedBrightness_old = self._brightness
            if ATTR_BRIGHTNESS in kwargs:
                convertedBrightness = kwargs[ATTR_BRIGHTNESS]
            else:
                convertedBrightness = self._brightness
            self._hs = kwargs[ATTR_HS_COLOR] if (ATTR_HS_COLOR in kwargs) else self._hs
            convertedHue = int(self._hs[0]*(255/360))
            convertedSaturation = int(self._hs[1]*(255/100))
            hue_addorsubst = 1 if (convertedHue_old < convertedHue) else -1
            bright_addorsubst = 1 if (convertedBrightness_old < convertedBrightness) else -1
            # Now we start transition from old color/brightness to new color and brightness. Loop until match.
            while convertedHue_old != convertedHue or convertedBrightness_old != convertedBrightness:
                convertedHue_old = (convertedHue_old + hue_addorsubst) if convertedHue_old != convertedHue else convertedHue
                convertedBrightness_old = (convertedBrightness_old + bright_addorsubst) if convertedBrightness_old != convertedBrightness else convertedBrightness
                self._postReq('ambilight/currentconfiguration',{"styleName":"Lounge light","isExpert":True,"algorithm":"MANUAL_HUE",
                "colorSettings":{"color":{"hue":convertedHue_old,"saturation":convertedSaturation,"brightness":convertedBrightness_old},
                "colorDelta":{"hue":0,"saturation":0,"brightness":0},"speed":255}} )
            self.getState()
        elif ATTR_HS_COLOR in kwargs:
            else:
            "colorSettings":{"color":{"hue":convertedHue,"saturation":convertedSaturation,"brightness":convertedBrightness},
        elif ATTR_BRIGHTNESS in kwargs:
            # use this section instead if you cannot change the brightness without the bulb changing colour
            # (brightness commands are limited to integer values 1:10)
            #convertedBrightness = int(10*(kwargs[ATTR_BRIGHTNESS])/255)
            #self._postReq('menuitems/settings/update', "values": [{"value": {"Nodeid": 2131230769, "Controllable": "true", "Available": "true", "string_id": "Brightness", "data": {"value": convertedBrightness}}}]} )
            # and comment out all of the following
            "colorSettings":{"color":{"hue":int(self._hs[0]*(255/360)),"saturation":int(self._hs[1]*(255/100)),
            "brightness":convertedBrightness},"colorDelta":{"hue":0,"saturation":0,"brightness":0},"speed":255}} )
        elif ATTR_EFFECT in kwargs:
            effect = kwargs[ATTR_EFFECT]
            self.set_effect(effect)
        else:
            if OLD_STATE[3] == EFFECT_MANUAL:
                "colorSettings":{"color":{"hue":int(OLD_STATE[0]*(255/360)),"saturation":int(OLD_STATE[1]*(255/100)),
                "brightness":OLD_STATE[2]},"colorDelta":{"hue":0,"saturation":0,"brightness":0},"speed":255}} )
            else:
                effect = self._effect
    def turn_off(self, **kwargs):
        global OLD_STATE
        OLD_STATE = [self._hs[0], self._hs[1], self._brightness, self._effect]
        self._postReq('ambilight/power', {'power':'Off'})
        self._state = False
    def getState(self):
        fullstate = self._getReq('ambilight/currentconfiguration')
        if fullstate:
            self._available = True
            styleName = fullstate['styleName']
            if styleName:
                if styleName == 'Lounge light':
                    isExpert = fullstate['isExpert']
                    if isExpert == True:
                        self._state = True
                        colorSettings = fullstate['colorSettings']
                        color = colorSettings['color']
                        hue = color['hue']
                        saturation = color['saturation']
                        bright = color['brightness']
                        self._hs = (hue*(360/255),saturation*(100/255))
                        self._brightness = bright
                        self._effect = EFFECT_MANUAL
                    else:
                        self._hs = (DEFAULT_HUE, DEFAULT_SATURATION)
                        self._brightness = DEFAULT_BRIGHTNESS
                elif styleName == 'FOLLOW_VIDEO':
                    self._state = True
                    effect = fullstate['menuSetting']
                    if effect == "STANDARD":
                        self._effect = EFFECT_STANDARD
                    elif effect == "NATURAL":
                        self._effect = EFFECT_NATURAL
                    elif effect == "IMMERSIVE":
                        self._effect = EFFECT_IMMERSIVE
                    elif effect == "VIVID":
                        self._effect = EFFECT_VIVID
                    elif effect == "GAME":
                        self._effect = EFFECT_GAME
                    elif effect == "COMFORT":
                        self._effect = EFFECT_COMFORT
                    elif effect == "RELAX":
                        self._effect = EFFECT_RELAX
                elif styleName == 'FOLLOW_AUDIO':
                    self._state = True
                    if effect == "VU_METER":
                        self._effect = EFFECT_RETRO
                    elif effect == "ENERGY_ADAPTIVE_BRIGHTNESS":
                        self._effect = EFFECT_ADAP_BRIGHTNESS
                    elif effect == "ENERGY_ADAPTIVE_COLORS":
                        self._effect = EFFECT_ADAP_COLOR
                    elif effect == "SPECTUM_ANALYSER":
                        self._effect = EFFECT_SPECTRUM
                    elif effect == "KNIGHT_RIDER_ALTERNATING":
                        self._effect = EFFECT_SCANNER
                    elif effect == "RANDOM_PIXEL_FLASH":
                        self._effect = EFFECT_RHYTHM
                    elif effect == "MODE_RANDOM":
                        self._effect = EFFECT_RANDOM
        else:
            self._state = False
    def update(self):
        self.getState()
    def set_effect(self, effect):
        if effect:
            if effect == EFFECT_MANUAL:
                self._hs = (OLD_STATE[0], OLD_STATE[1])
                self._brightness = OLD_STATE[2]
            elif effect == EFFECT_STANDARD:
                self._postReq('ambilight/currentconfiguration', {"styleName":"FOLLOW_VIDEO","isExpert":False,"menuSetting":"STANDARD"})
            elif effect == EFFECT_NATURAL:
                self._postReq('ambilight/currentconfiguration', {"styleName":"FOLLOW_VIDEO","isExpert":False,"menuSetting":"NATURAL"})
            elif effect == EFFECT_IMMERSIVE:
                self._postReq('ambilight/currentconfiguration', {"styleName":"FOLLOW_VIDEO","isExpert":False,"menuSetting":"IMMERSIVE"})
            elif effect == EFFECT_VIVID:
                self._postReq('ambilight/currentconfiguration', {"styleName":"FOLLOW_VIDEO","isExpert":False,"menuSetting":"VIVID"})
            elif effect == EFFECT_GAME:
                self._postReq('ambilight/currentconfiguration', {"styleName":"FOLLOW_VIDEO","isExpert":False,"menuSetting":"GAME"})
            elif effect == EFFECT_COMFORT:
                self._postReq('ambilight/currentconfiguration', {"styleName":"FOLLOW_VIDEO","isExpert":False,"menuSetting":"COMFORT"})
            elif effect == EFFECT_RELAX:
                self._postReq('ambilight/currentconfiguration', {"styleName":"FOLLOW_VIDEO","isExpert":False,"menuSetting":"RELAX"})
            elif effect == EFFECT_ADAP_BRIGHTNESS:
                self._postReq('ambilight/currentconfiguration', {"styleName":"FOLLOW_AUDIO","isExpert":False,"menuSetting":"ENERGY_ADAPTIVE_BRIGHTNESS"})
            elif effect == EFFECT_ADAP_COLOR:
                self._postReq('ambilight/currentconfiguration', {"styleName":"FOLLOW_AUDIO","isExpert":False,"menuSetting":"ENERGY_ADAPTIVE_COLORS"})
            elif effect == EFFECT_RETRO:
                self._postReq('ambilight/currentconfiguration', {"styleName":"FOLLOW_AUDIO","isExpert":False,"menuSetting":"VU_METER"})
            elif effect == EFFECT_SPECTRUM:
                self._postReq('ambilight/currentconfiguration', {"styleName":"FOLLOW_AUDIO","isExpert":False,"menuSetting":"SPECTRUM_ANALYSER"})
            elif effect == EFFECT_SCANNER:
                self._postReq('ambilight/currentconfiguration', {"styleName":"FOLLOW_AUDIO","isExpert":False,"menuSetting":"KNIGHT_RIDER_ALTERNATING"})
            elif effect == EFFECT_RHYTHM:
                self._postReq('ambilight/currentconfiguration', {"styleName":"FOLLOW_AUDIO","isExpert":False,"menuSetting":"RANDOM_PIXEL_FLASH"})
            elif effect == EFFECT_RANDOM:
                self._postReq('ambilight/currentconfiguration', {"styleName":"FOLLOW_AUDIO","isExpert":False,"menuSetting":"MODE_RANDOM"})
    def _getReq(self, path):
        try:
            if self._connfail:
                self._connfail -= 1
                return None
            resp = self._session.get(BASE_URL.format(self._host, path), verify=False, auth=HTTPDigestAuth(self._user, self._password), timeout=TIMEOUT)
            self.on = True
            return json.loads(resp.text)
        except requests.exceptions.RequestException as err:
            self._connfail = CONNFAILCOUNT
            self.on = False
            return None
    def _postReq(self, path, data):
        try:
            if self._connfail:
                self._connfail -= 1
                return False
            resp = self._session.post(BASE_URL.format(self._host, path), data=json.dumps(data), verify=False, auth=HTTPDigestAuth(self._user, self._password), timeout=TIMEOUT)
            self.on = True
            if resp.status_code == 200:
                return True
            else:
                return False
            self.on = False
            return False
after updateing to 2021.6.0 this integration stopped working. Im the only one?
When checking the configuration, I receive an error “Platform error light.ambilights - Integration ‘ambilights’ not found.”
.py Scripts in /www/x/ are present.
I have the same problem.
Me too, every philips ambi integration crashed:
  • Platform error: light - Integration ‘philips_ambilight’ not found.
  • Platform error: media_player - Integration ‘philips_android_tv’ not found.
  • Platform error: switch - Integration ‘philips_ambilight+hue’ not found.
I write this for those, who just want to sync an old Philips TV (no android) with their LED strip or something. I havent seen this solution yet so I decided to share if someone needs it.
I am using a REST Sensor like this:
- platform: rest
  resource: http://192.168.0.4:1925/1/ambilight/processed
  json_attributes_path: "$.layer1.left.0"
  json_attributes:
    - r
    - g
    - b
  value_template: "OK"
  scan_interval: 0.010
And an automation like this:
  - alias: TVWand synchron zum Ambilight
    mode: restart
      - platform: state
        entity_id: sensor.ambilight
    condition:
      - condition: state
        entity_id: input_boolean.boofernsehen
        state: "on"
      - condition: state
        entity_id: input_boolean.boofolgentvwand
        state: "on"
      service: light.turn_on
      entity_id: light.extended_color_light_12
      data_template:
        transition: 2
        brightness: 80
        rgb_color: "[{{ state_attr('sensor.ambilight', 'r') | int }},{{ state_attr('sensor.ambilight', 'g') | int }},{{ state_attr('sensor.ambilight', 'b') | int }}]"
Its not perfect. For example it is using only one section of my TV Ambilight (left side, section 0…i think this is the bottom one). Also the colors of my LED strip doesnt match the ambilight colors totally.
I took a long transition of 2 seconds as sometimes its not fully synced (especially if ambilight is changing fast) and this way for me it feels better.
Maybe someone has ideas to optimize?
Greetings,
Chris
