Here is my blueprint to use your philips hue dial switch (4button version)
You can use the blueprint to perform actions. Like control the volume with the dial of your mediaplayer. Like your sonos or google speaker.
Also the buttons you can program to call a service or perform actions like switching lights or whatever.
It is originally based on appollo1220 Philips Hue Tap Dial Switch - ZHA - Blueprints Exchange - Home Assistant Community (home-assistant.io)
Also used ZHA - Philips Hue Dial Switch with custom button actions - Blueprints Exchange - Home Assistant Community (home-assistant.io) for inspiration.
Although i wanted to control lights/or perform actions with the buttons AND control my mediaplayer with the dial. This blueprints works for me.
Note: The Philips Hue is connected directly to the Zigbee coordinator of my system. No use of the Philips HUB.
potts-mike
(Potts Mike)
February 17, 2023, 7:44pm
3
Should this work with a tap-dial connected through the hue hub?
Yulathh
February 20, 2023, 5:38pm
4
Hi there, I have exactly the same question, does this work with a tap-dial connected through a Hue hub or via ZHA ?
Yulathh
February 21, 2023, 3:01pm
5
I received one today and this blueprint doesn’t work with a tap-dial connected through a hue hub, but it works well in HA even without any blueprint, it just requires a bit more of typing into HA to configure the switch
No i directly connected it to HA with a Zigbee coordinator. Works best
jrathg
(James)
April 18, 2023, 9:54am
7
Is it possible to include the step_size value in the turn wheel left and turnwheel right sequences so you can adjust volume in small, med, and large increments depending on how fast you spin the dial?
jmsblah
(Jms)
May 10, 2023, 10:48am
8
Welcome!
I know how to do it in node red, let me know if you need help.
Did anyone find a way to make the press and hold work?
I’m also looking for the long press.
A long press always triggers a left turn.
Sadly this is an error in the ZHA implementation. With Z2M I don’t have this problem…
1aranzant
(1aranzant)
October 7, 2023, 11:23am
12
when I turn the wheel, it only increments the volume once, I need to stop turning the wheel and turn it again a second time for a second incrementation. Do you have the same issue?
this is normal. it wil only send the command if you stop spinning the wheel .
1aranzant
(1aranzant)
October 23, 2023, 4:04pm
14
well that really sucks… guess I need to move to Node-RED then
You can overcome this by setting the automation to run mode Parallel .
Here is my automation for inspiration:
alias: Sonos Kitchen(Køkken) and Living Room (Stue) Volume on Hue Tap Dial Switch
description: ""
- device_id: a10964bf3ca4c62896e022e231e2834e
domain: hue
platform: device
type: repeat
subtype: clock_wise
unique_id: 5e1ef413-d10e-4b64-8669-aede619718f2
domain: hue
platform: device
type: repeat
subtype: counter_clock_wise
domain: hue
platform: device
type: initial_press
subtype: 1
unique_id: 35aaa0ec-27cc-4b33-89c8-79532d308bdf
id: Play Musik I Køkken
domain: hue
platform: device
type: start
subtype: clock_wise
id: Volume Up initially
domain: hue
platform: device
type: start
id: Volume Down initially
domain: hue
platform: device
type: initial_press
subtype: 2
unique_id: 4422a570-4f5d-44d0-bbb2-a9cc5197e87f
domain: hue
platform: device
type: initial_press
subtype: 3
unique_id: dae5d653-4f68-4c78-9da5-80535a46b082
id: Sonos Stue join Køkken
domain: hue
platform: device
type: initial_press
subtype: 4
unique_id: e5a00a1d-8db4-4bc7-b5bb-71618cfa9998
id: Sonos Stue Unjoin Køkken
condition: []
- alias: >-
Turnup volume on kitchen, if Kitchen is already playing do the same with
Stue
choose:
- conditions:
- condition: trigger
id:
- Volume-Up
- Volume Up initially
sequence:
- if:
- condition: state
entity_id: media_player.stue
state: playing
then:
- service: media_player.volume_up
data: {}
entity_id:
- media_player.kokken
- media_player.stue
else:
data: {}
entity_id: media_player.kokken
- alias: >-
Turnup down on kitchen, if Kitchen is already playing do the same with
Stue
choose:
- conditions:
id:
- Volume-Down
- Volume Down initially
sequence:
- if:
- condition: state
state: playing
then:
- service: media_player.volume_down
data: {}
entity_id:
- media_player.stue
else:
data: {}
- choose:
- conditions:
sequence:
- service: media_player.media_play_pause
data: {}
alias: "Button 1 play music Køkken "
- choose:
- conditions:
- condition: state
state: playing
sequence:
- service: media_player.media_next_track
data: {}
alias: "Button 2 Play next "
- alias: "Button 3 Stue joins Køkken "
choose:
- conditions:
id:
- Sonos Stue join Køkken
sequence:
- service: media_player.join
group_members:
- media_player.stue
- choose:
- conditions:
id:
- Sonos Stue Unjoin Køkken
sequence:
- service: media_player.unjoin
data: {}
alias: Button 4 Stue unjoins køkken
mode: parallel
max: 10
sundar2012
(Sundar2012)
January 29, 2024, 12:28am
16
thanks for the inspiration. I took this (much more elegant than parsing all the trigger_event.data.x info) and made a few mods including controlling multiple speakers and lights. happy to share the automation - im still cleaning it up a bit. That said, one suggestion to make the dial feel more responsive is to use set_volume and increase based on the speed of the dial turn. Here’s that code:
volume_level: {{state_attr(states('MEDIA ENTITY HERE'), 'volume_level')
- (trigger.event.data.steps / 1500)}}
Based on how the standard hue integration reports “steps” on dial rotation, ive found 1500 to be the sweet spot as a divisor.
