Based on the Blueprint by @apollo1220
Control brightness of a single light by rotating the dial.
Create custom actions for any of four buttons.
The buttons currently only support single click.
blueprint:
name: Philips Tap Dial Switch
description: 'Control brightness of one light with the dial on a Philips Hue Tap Switch. Use the four buttons
to assign your own actions.'
source_url: https://github.com/nnmalex/ha-blueprints/blob/3caff790c415e9e2ae84f58ef77e84a43fc52992/philips_tap_dial_switch.yaml
domain: automation
input:
remote:
name: Philips Hue Tap Switch
selector:
device:
integration: zha
manufacturer: Signify Netherlands B.V.
model: RDM002
multiple: false
dimmable_light:
description: The light to be controlled with the dial
selector:
entity:
domain: light
button_1_press:
name: Button 1 Press
description: Action to run in a single press of button 1
default: []
selector:
action: {}
button_2_press:
name: Button 2 Press
description: Action to run in a single press of button 2
default: []
selector:
action: {}
button_3_press:
name: Button 3 Press
description: Action to run in a single press of button 3
default: []
selector:
action: {}
button_4_press:
name: Button 4 Press
description: Action to run in a single press of button 4
default: []
selector:
action: {}
mode: restart
max_exceeded: silent
variables:
event: '{{ trigger.event.data.command }}'
scene: "{{ trigger.event.data.args[1] }}"
step_mode: "{{ trigger.event.data.params.step_mode }}"
step_size: "{{ trigger.event.data.params.step_size }}"
- platform: event
event_type: zha_event
event_data:
device_id: !input remote
- choose:
# Dial rotatation
- conditions:
- '{{ event == "step_with_on_off" }}'
- '{{ step_mode == "StepMode.Up" }}'
sequence:
- service: light.turn_on
target: !input dimmable_light
brightness_step_pct: '{{ step_size }}'
transition: 1
- conditions:
- '{{ step_mode == "StepMode.Down" }}'
sequence:
brightness_step_pct: '{{ -step_size }}'
transition: 1
# Buttons
- conditions:
- '{{ event == "recall" }}'
- '{{ scene == 1 }}'
sequence: !input button_1_press
- conditions:
- '{{ scene == 0 }}'
sequence: !input button_2_press
- conditions:
- '{{ scene == 5 }}'
sequence: !input button_3_press
- conditions:
- '{{ scene == 4 }}'
sequence: !input button_4_press
