The Philips Hue wall module can be used with the Zigbee integration to trigger automations. It is fairly straight forward to get single short button presses to work. However, long presses of double, triple or quadruple button presses are more tricky.
This blueprint helps to get all of the above working.
Note:
- You must use the wall module together with the Zigbee integration (ZHA)
- Both the old (RDM001) and the new (RDM004) module are supported
- Make sure to configure the correct mode depending on the type of button(s) you use. More information on how this is done can be found here.
- If you have trouble setting up the mode on a new (RDM004) module, check the information here.
Hope this helps others getting their module to do what they want ![]()
blueprint:
name: Philips Hue Wall Module
description: "# Philips Hue Wall Module (RDM001 / RDM004)\nThis blueprint allows
you to use a Philips Wall Module (RDM001 and RDM004) to trigger automations.\n
You need to have the module paired to your Home Assistant Zigbee integration
(ZHA). Depending on the physical switch used (single/double and rocker/push).
More information on how to do this can be found [here](https://rudd-o.com/linux-and-free-software/how-to-use-the-philips-hue-wall-switch-module-with-push-button-wall-switches-in-home-assistant).
If you have a RDM004 module and the 'PhilipsBasicCluster' option is not shown,
follow the steps layed out [here](https://community.home-assistant.io/t/how-to-configure-the-philips-hue-wall-module-to-use-push-button-momentary-type-wall-switches-zha/451125/27).\n\n
This blueprint supports the left and right button, single, double, triple,
quadruple, long press and long press release events.
domain: automation
input:
remote:
description: Signify switch to use
selector:
device:
filter:
- integration: zha
manufacturer: Signify Netherlands B.V.
model: RDM001
- integration: zha
model: RDM004
button_left_single_press:
name: Left button single press
description: Action to run on a single press of the left button
default: []
selector:
button_left_double_press:
name: Left button double press
description: Action to run on a double press of the left button
default: []
selector:
button_left_triple_press:
name: Left button triple press
description: Action to run on a triple press of the left button
default: []
selector:
button_left_quadruple_press:
name: Left button quadruple press
description: Action to run on a quadruple press of the left button
default: []
selector:
button_left_long_press:
name: Left button hold
description: Action to run on a long press of the left button
default: []
selector:
button_left_long_release:
name: Left button release
description: Action to run when releasing the left button after a long press
default: []
selector:
button_right_single_press:
name: Right button single press
description: Action to run on a single press of the right button
default: []
selector:
button_right_double_press:
name: Right button double press
description: Action to run on a double press of the right button
default: []
selector:
button_right_triple_press:
name: Right button triple press
description: Action to run on a triple press of the right button
default: []
selector:
button_right_quadruple_press:
name: Right button quadruple press
description: Action to run on a quadruple press of the right button
default: []
selector:
button_right_long_press:
name: Right button hold
description: Action to run on a long press of the right button
default: []
selector:
button_right_long_release:
name: Right button release
description: Action to run when releasing the right button after a long press
default: []
selector:
mode: single
- platform: event
event_type: zha_event
event_data:
device_id: !input remote
- variables:
command: "{{ trigger.event.data.command }}"
cluster_id: "{{ trigger.event.data.cluster_id }}"
endpoint_id: "{{ trigger.event.data.endpoint_id }}"
args: "{{ trigger.event.data.args }}"
- choose:
- conditions:
- "{{ command == 'left_press_release'}}"
sequence:
- wait_for_trigger:
- platform: event
event_data:
command: "{{ command }}"
timeout:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
enabled: true
- if:
- condition: template
value_template: "{{ not wait.trigger }}"
then: !input button_left_single_press
else:
- sequence:
- wait_for_trigger:
- platform: event
event_data:
timeout:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
- if:
then: !input button_left_double_press
else:
- sequence:
- wait_for_trigger:
- platform: event
event_data:
timeout:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
- if:
then: !input button_left_triple_press
else: !input button_left_quadruple_press
- conditions:
- "{{ command == 'right_press_release'}}"
sequence:
- wait_for_trigger:
- platform: event
event_data:
timeout:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
enabled: true
- if:
then: !input button_right_single_press
else:
- sequence:
- wait_for_trigger:
- platform: event
event_data:
timeout:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
- if:
then: !input button_right_double_press
else:
- sequence:
- wait_for_trigger:
- platform: event
event_data:
timeout:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
- if:
then: !input button_right_triple_press
else: !input button_right_quadruple_press
- conditions:
- "{{ command == 'left_hold'}}"
sequence:
- sequence: !input button_left_long_press
- wait_for_trigger:
- platform: event
event_data:
command: "left_hold_release"
- sequence: !input button_left_long_release
- conditions:
- "{{ command == 'right_hold'}}"
sequence:
- sequence: !input button_right_long_press
- wait_for_trigger:
- platform: event
event_data:
command: "right_hold_release"
- sequence: !input button_right_long_release
