Hi!
I have many PAN04 in my house, and I’m trying to switch from Vera to HASS.
So from start - i have problem with them - and strange thing is - three of them, where one works different from two others.
So, Device 1:
- From webpanel - When i use Switch A, it toggle Light A, when use Switch B, it toggle Light B,
- From wall - When i use Switch A, it toggle Light A, on webpanel in a moment Light A is on. When i use Switch B, it toggle Light B and on webpanel Switch A is on - until i manually refresh node or enable pooling - it switch to correct info.
Device 2 and 3:
- Switching from webpanel switch them immediately. But, when using wall switches, I can wait for ages to change them on webpanel. Only when pooling is enabled - i see that correct one switched.
Anyone - had this problem (i saw on github that 2 years ago was some proposal of repair - i’ve tried it, it didn’t work at all…). Any proposal or solution, other than ‘throw away 15 of them’ ? Or if it is any way to solve it - can You recommend other in wall dual switches (or if there is - 4 way switches) which will work with hass, and send state update immediately from wall switch to app?
Edit:
Got some help using Vera support with Device 1 - but now, it behaves like Device 2 and 3:
Also, found out on z-wave log that i got message right after click on wall switch:
2020-04-25 13:43:39.924 Detail, Node013, Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x0d, 0x07, 0x60, 0x0d, 0x03, 0x00, 0x25, 0x03, 0x00, 0xb4
2020-04-25 13:43:39.925 Error, Node013, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_SWITCH_BINARY endpoint 3
Any ideas what could be done here?
