Pi4+SSD too much to handle for powersupply? replace with
just be sure: the external PS would be only for the SSD, and not for the Pi4 would it, id keep the original Raspberry PS for that?
Power supplies do vary a fair bit in quality and power output, you want one which can reliably put out at least 3 Amps. I’d recommend getting the official Pi 4 USB-C power supply as I’ve never had any problems powering a Pi 4 and a connected M2 SSD in USB3 enclosure or 2.5" SSD with a USB3 adaptor using one. Currently have my HA setup on a Pi 4 with the latter setup along with a USB Zigbee dongle and the official Pi 4 PS is providing more than enough power.
thanks!
hmm, I am using the official Raspberry PS… are you saying that should be sufficient? or is the
the power supply for the SSD, sorry if I misunderstand you here.
The power supply is only plugged into the Pi. If you are using the official one it should be fine for your setup unless you happen to have a particularly power hungry SSD. (I assume it is the latest version of the official PS with the USB C plug rather than the older version which has a micro-usb connector and has a lower power output)
I fear I have the micro-usb, and the box states 2.5A, 5.1V …
Ah, that may well be it then. I’d recommend upgrading that first rather than trying to go down the route of y-cables for powering the SSD as it keeps the setup a lot simpler for diagnosing future problems etc.
yeah, Id love that too, but how to upgrade it, while the newer versions have the usb-c connector… use a converter plug for that?
Sorry, I mean just buy the newer USB-C version of the official RPi power supply and use that to power your Pi 4 instead. You should not need to use a converter plug, not sure which country you are in but there should be a local version of the one I linked from your local Raspberry Pi supplier or Amazon etc.
So sorry, I miss remembered… using the 3A usb-c version after all…. duh.
the box I mentioned ws from one of my other Pi’s. sorry again.
My SSD is T3, 250GBmodel MU-PT250B, and it states ‘rated +5v 0.7A’
No problem, looks like the SSD is on the more power hungry side as mentioned above after all. Sounds like Frank’s original suggestion is going to be your best bet.
I’ve found this site a good resource on which combinations are known to work and what sort of performance to expect:
https://pibenchmarks.com/
thanks! mine is bottom of the list… still, it is on the list :wink:
searching for an adapter to power the SSD then, its not very obvious where to look. see Raspberry Pi 4 Bootloader USB Mass Storage Boot Guide for example, what on earth am I looking for, Franks suggestion isn’t in that list?
there’s this explicitly mentioning a 3.5A PS…
Verify Power Supply Size (3.5A strongly recommended)
Check your Raspberry Pi’s power supply size and make sure it is delivering at least 3.5A. There are a lot of USB C adapters for the Raspberry Pi that are only 3.0A. These will typically work fine, until you plug in something like a SSD which draws power from the Pi and there is nothing left to give.
Most SSDs are quite power efficient but HDDs draw significantly more. Older generations of SSDs used quite a bit more power than newer ones as well. If you are using an older drive or a drive that you know is power hungry you need to pay extra attention to having a quality power source with plenty of capacity.
A good alternative option to relying on the Pi to power the drive is using a powered USB hub* so your drive doesn’t need to draw power from the Pi’s limited power budget. Make sure you get one that is compatible with the Pi as some powered USB hubs won’t work properly with it so check the reviews and do your research to make sure people are using it successfully with the Pi.
Using a 3.5A power supply* or powered USB hub* will ensure your drive is getting enough power without impacting the Pi’s stability.
Didn’t notice the link I gave included your solution. Looks like Sabrent Powered USB 3.0 Hub they’ve linked to and recommend may the answer to your problem.
The 3.5A PS would be a great alternative too as long as you can get one, think the Canakit one they mention is not available everywhere.
Guess I am completely missing the obvious, but, using the the powered USB Hub, how do I connect the SSD both to the Hub, and the Pi4…?
You’d power the Pi 4 with the current supply as you do now, plug the hub into one of the Pi’s USB 3.0 ports and plug the SSD into the hub. The PS that the hub should come with provides power only to the hub and the SSD you have plugged into it. You have two power supplies plugged in but one powers the Pi directly and the second powers the hub and any other external devices plugged into it (i.e. the SSD).
Not the neatest of solutions but makes sure everything has adequate power.
Al right! Yes, I wás missing the obvious :wink: thanks, problem solved.
I guess Nick, Frank and you all deserve the Solved tick, but I’ll enter it under your post with the link to that website because it holds so much info we didn’t yet have here.
Thank you all
Btw, the power status sensor integration still says all is fine, while I just experienced another blackout…
Could it be something else than a power issue ?
now I see this… blindly ordered the advised power USB hub, but apparently is suffers
BUT, if you’re going to use this on a Raspberry Pi (Pi 4 in my case), be warned that it exhibits the back-power issue whereby if you reboot the Pi, it won’t boot up again until you either remove the power adapter from the hub, or unplug it from the Pi.
now what, how to tell if this is true (I know, just try it…) and if another hub wont suffer this… I hadn’t seen it (back-power) being mentioned yet
yep, its true:
powered usb hub arrived today, and it seems to work. needed a second boot, but after that all went well. takes a bit longer to startup I feel. not sure yet. However, I seem to be bothered by the so called back-power… updating the OS to rc3 requires a reboot which isn’t performed until I turn-off power completely, and back on. Hardly a fine situation…
learned that we can either cut the power thread in the usb cable between the Pi and the hub (since the Hub has its own PS), or throw in another (bus powered) hub, which obviously doesnt transport the power… we’ll see :wink:
UPDATE
Nope… no success, can NOT reboot the host, not even with a tweaked USB cable with cut Red power wire. I have transposed this issue to #dev_os on Discord because it really is quite impossible to use the officially supported partition install, with regular/official power supply. Only rescue might be a 3.5+A PS, but they are hard to find. So a list of proven devices might do well in the community/documentation
Disappointed to see that didn’t work. Have you got a phone, tablet or laptop charger knocking about which uses USB type C? They may be powerful enough to provide enough power, maybe even borrow one from someone else to try it out before committing to buy any more kit. I’ve used a Google Pixelbook 45W charger for a bit when messing about with various setups which seemed to work OK. I think you may need to make sure it supports Power Delivery.
HI, and thanks.
Must say it has been a most revealing couple of days, since I ran into this. Have been testing several setups. USB powered hubs, and SSD’s, even tweaked USB cables with cut Red (power) leads. All to no avail or final solution yet…
First: providing the Pi itself with more power than designed (3.0A) to allow the USB’s to drive power hungry devices makes no sense according to the design specs. No matter how many Amps you feed the Pi via its power slot, the USB’s are maxed at 1.2A together at all times. See:
https://www.raspberrypi.org/documentation/hardware/raspberrypi/power/README.md
which is the official doc I think we all should stick to.
As stated in that document, back-power is a risky business. Bypassing the voltage protection of the PI’s fuse is not a good idea… Not only that, (and this is not mentioned, but, in my case, the issue), allowing the USB to back-power the PI prevents the Pi from being booted (simply because it never gets cut from power).
So, first I tweaked the connecting cable, but this still won’t make the PI reboot with the Sabrent Hub. meanwhile I’ve also tested a TP-Link hub, of which I read it does allow the Pi to reboot. (or must say, the new version of the one mentioned…) Doesn’t even startup …!
The older version is also on its way, so maybe that will work.
For now, Ive hooked up the new (faster, larger, better ranked in your doc) Sandisk Extreme portable 500GB SSD directly to the Pi once again, and have seen no problem yet. No Idea of the power rating, for that isn’t mentioned on the device or the packaging.
To be continued… and on the quest for this most important paragraph in the doc you posted:
for reference, (the above mentioned new SSD functioned fine, and no bricks happened, but nonetheless) I tested 3 USB hubs.
  • the Sabrent mentioned in the posted by Ian: it allowed the Pi to startup, but no reboot host, probably because of back-power. However, even with a tweaked usb cable it wouldn’t reboot.
  • the Tp-Link which is the modernized version of the one below. This one didnt even start the Pi… no idea why , but I immediately disconnected, because that feels really dangerous…
finally the
  • Tp-link, which started up the Pi alright (…), but also allowed me to reboot the host! yeah… guess Ill leave the testing at that, it seems to be a well built Hub alright, with a single power button (no selectable ports like the Sabrent, but I dont need that)
all in all a mixed experience, of which I learned a lot.
