is it possible to rotate a text field 90 degrees?
I can’t find an answer here: Picture Elements Card - Home Assistant
Is it possible to rotate the 7,4 C 90 degrees in below:
type: picture-elements
elements:
- type: state-label
entity: binary_sensor.test
style:
rotate: 90deg
Thanks! So simple… where could I have found that myself
Hmz… the android app does not show it correctly…
Sorry, I’m blind but I cannot find it there…
You can basically map any CSS with that, rotate being one of that
What did you mean with this?
You asked about styling - you got the tutorial.
What is not clear?
I asked about rotating and got it answered. Marked it as solution. But then I discovered it was not properly displayed in my android app, only in my browser.
so I am not sure if that is covered in your styling guide? If so, please direct me to the solution since I am not able to find id there.
Thank you for taking the time to respond!
It’s literally the 3rd post in the linked guide click here
Maybe that method works better on mobile.
Picture elements may produce a different picture on mobile in part of position, scale. As for rotating - I did not see any differences.
No no no. This is not about degrees or turn. Use translate function.
Actually, whole setup should be reviewed in part of translate.
Sorry, I am not a styling expert It works… why is it not ok?
If it looks ok both on PC and mobile - then fine.
In my experience I had to use same coordinates system (that translate function) for each element.
