Hi everyone,
Hope you are all doing well. I had a question about a Picture Glance card. I am trying to get the image to change based on state. I can’t quite seem to figure out what am doing wrong. This is what I have:
type: picture-glance
title: chris
entities:
- person.chris
state_image:
Work: /local/chris - BW.png
home: /local/chris1.png
not_home: /local/chris - BW.png
entity: sensor.phone_battery_level
Any direction would be appreciated!
Menelao
(Roberto)
April 2, 2020, 1:53pm
2
The state_image options use the entity variable.
Try like this:
title: chris
entities:
- person.chris
state_image:
entity: person.chris
petro
(Petro)
April 2, 2020, 1:54pm
3
just use a state filter
title: chris
image: /local/chris1.png
state_filter:
Work: grayscale(100%)
'not_home': grayscale(100%)
EDIT: Yes @Menelao pointed out you need to use entity
updated to this not grabbing the image…
title: chris
entities:
- person.chris
state_image:
Home: /local/chris1.png
entity: sensor.moto_battery_level
Not an image issue as this works fine…
title: chris
entities:
- person.chris
state_image:
Thanks again
petro
(Petro)
April 2, 2020, 3:49pm
5
You’re still doing it wrong…
title: chris
entities:
- sensor.moto_battery_level
state_image:
Menelao
(Roberto)
April 2, 2020, 3:53pm
6
If you use as states “Work - Home and not_home” you need to use an entity that provide such states.
petro
(Petro)
April 2, 2020, 3:55pm
7
which should be his person
so…
title: Anna
entities:
- sensor.moto_g_7_battery_level
state_image:
Work: /local/Anna - BW.png
Home: /local/Anna1.png
not_home: /local/Anna - BW.png
entity: person.anna
petro
(Petro)
April 2, 2020, 5:03pm
9
yeah, but you don’t need to make a black and white image… you can use the state_filter like i mentioned above and only have a single image.
Tried it this way:
title: Anna
entities:
- person.anna
image: /local/Anna1.png
state_filter:
Home: greyscale(100%)
J-Work: greyscale(100%)
entity: sensor.moto_g_7_battery_level
and this way:
title: Anna
entities:
state_filter:
entity: person.anna
Still doing something wrong…
petro
(Petro)
April 3, 2020, 1:11pm
11
shaikmonster:
Home
that’s not a valid state.
it’s ‘home’ or ‘not_home’ or zone friendly name.
To verify the correct states, go to the developer tools / states page. The state in the state column is what you want to use.
that is 100% wrong, stop trying it.
So I tried ‘home’, but everytime I go back in to look, it has been changed to home…
entity: person.anna
show_name: false
state_filter:
J-work: greyscale(100%)
home: greyscale(100%)
type: picture-entity
petro
(Petro)
April 3, 2020, 1:26pm
13
what?
Can you just post a screenshot of person.anna in the developer tools / states page. Include the attributes.
Also, when you reply to people click this reply, not the bottom reply.
Will do! Sorry about that.
petro
(Petro)
April 3, 2020, 1:55pm
15
Alright, so valid states are:
home
not_home
Zone Friendly Name
Zone firendly name is case sensative. So if your zone name is Anna Work
then you MUST use Anna Work
this should work (assuming your zone name is J-Work) right out of the box.
entity: person.anna
show_name: false
state_filter:
if that doesn’t work, this should
entity: person.anna
show_name: false
state_filter:
'home': greyscale(100%)
petro
(Petro)
April 3, 2020, 2:01pm
17
that’s because show_name isn’t an option. You keep switching between picture-entity and picture-glance. They do not share the same fields.
Stick with one or the other. If you want to keep picture glance, remove the show_name field.
EDIT:
It seems like state_folter is just broken. I tried this on both cards and it’s not working as the documents state.
EDIT2:
state_image is not broken. So use that:
title: Anna
entities:
state_image:
home: /local/Anna1.png
entity: person.anna
LAST EDIT: Greyscale is grayscale… it does work
entity: person.anna
entities:
state_filter:
J-Work: grayscale(100%)
home: grayscale(100%)
Perfection! Thanks for the help! Sorry for the confusion!
I looked through this topic but it seems this isn’t a solution for me.
This is my glance card:
- badges: []
cards:
- aspect_ratio: 0%
title: Keuken
entities:
- entity: binary_sensor.keuken_motion
- entity: group.afzuigkap
icon: 'mdi:lightbulb-on-outline'
- entity: light.aanrecht_2
- entity: group.keuken
icon: 'mdi:toggle-switch-off-outline'
state_image:
'on': /local/rooms/keuken-on.jpg
'off': /local/rooms/keuken-off.jpg
But I can’t fix this error:
Expected a value of type
undefinedfor
state_imagebut received
{“on”:"/local/rooms/keuken-on.jpg",“off”:"/local/rooms/keuken-off.jpg"}.
I looked at the lines and this topic, but I can’t figure out what’s wrong.
petro
(Petro)
July 7, 2020, 10:14am
20
Is that error in the UI? If so, you can safely ignore it because it’s a warning not an error.
