I was wondering whether I could place text with some properties inside the picture-elements card
same question from me.
Already treid the type: markdown but it doesnāt work.
Anyone an idea for configuration?
Well, i could do with a pictureā¦
Tahnks, Ralf
You can use type: state-label with a dummy sensor and place the text in prefix.
I have one with non-existence sensor.blank to display the text āFront Doorā in my picture-elements:
- type: state-label
entity: sensor.blank
prefix: "Front Door "
style:
top: 90%
left: 14%
font-size: 1.1vw
color: white
font-weight: bold
Wondering if you have solved this with a more recent release @JTPublic. This just produces a yellow warning triangle now.
Yes, latest HA tightened entities, that āhackā would work anymore.
Youāll have to use something valid, like define an input_text entity for state-label.
I use this:
@Holdestmade the custom-cards/text-element was recently depreciated. Do you know of any other options.?
Itās only archived, so no more development, still works fine. Iāve removed it from HACS and manually installed it
Not aware of any other way to do it.
It does not still work fine.
Works for me with manual install
Try this alternantive:
2024 now.
Anyone know how i add just text to an element?
Greetings!
In order to display the text and other necessary information, I made a new sensor. With this you can display whatever information you want. The sensor code is located in the template.yaml file.
I added the following line to the configuration.yaml file:
# include
template: !include template.yaml
In template.yaml:
- sensor:
- name: 'Greeting'
state: >
{%- if states('sensor.time') > '22:00' and states('sensor.time') < '06:00' %}Good night!
{%- elif states('sensor.time') >'06:00' and states('sensor.time') < '12:00' %}Good morning!
{%- elif states('sensor.time') > '12:00' and states('sensor.time') < '18:00' %}Good day!
{%- elif states('sensor.time') > '18:00' and states('sensor.time') < '21:59' %}Good evening!
{%- endif %}
MORE TEXT HERE IF YOU WANT
An example. Sensor information in the upper right corner:
I hope it helps someone. I am a beginner and have no programming knowledge.
Best wishes!
The original solution of using a state-label
still works (2024.09), but you will need to create a fake sensor that you can address.
Add this to configuration.yaml
sensors:
blank_blank:
friendly_name: "Blank Blank"
value_template: " "
Then just like the original solution you can use a state-label
, but the only change is that you need to reference your fake blank_blank
sensor.
- type: state-label
entity: sensor.blank_blank
prefix: Living Room
style:
left: 51%
top: 65%
font-size: 1.5em
color: rgb(200,200,200)
font-weight: bold
Thank You very much, I was missing the add to configuration part. Now if I could only remove the āCā from my temperature value.
Have a great day!
