Can someone tell me why the moisture is red?
My config is
plant:
drachenbaum:
sensors:
moisture: sensor.drachenbaumfeuchtigkeit
battery: sensor.drachenbaumbatterie
temperature: sensor.drachenbaumraumtemperatur
conductivity: sensor.drachenbaumfeuchtigkeit
brightness: sensor.drachenbaumlichtintensitat
min_moisture: 15
max_moisture: 60
min_battery: 10
min_conductivity: 350
min_temperature: 15
actuell is:
thanks for your help!
i saw the problem, wrong sensor
sensor.drachenbaumbodenfruchtbarkeit was missing
Hackmett
(Fabian Peter)
3
apparently you were able to add the plant card in hass.io.
I am trying the same, but can not create the card. (see also Cannot add PLANT STATUS Card, "config is not supported" error)
How did you do it?
Hackmett
(Fabian Peter)
4
I got it, thanks to another post:
