Hi all. Maybe I might be on the wrong track but listening to the last Home Assistant podcast it mentioned the radar loop from the BOM here in Australia.
I had a play and added it to the system etc but I keep getting
Platform not found: camera.bom
I am ysing Hassio on a RPI. I have the weather part from the BOM working
Yeah did that as per the docs. I have another camera set up and it works. Have the bom part set up for both weather and sensor etc. Checked the config with the config generator and get Configuration invalidCHECK CONFIG
That part in the config
and as a test I copied the example after my location one threw and error
Yes I did a fresh install and thought it was the latest version but as suggested above I have a feeling its not. Downloaded it from the site but will check when I am home. Its sort of just a side project as I rewrite my node-red stuff. Heard about it on the podcast and though I would try it.
Hi all,
having similar problem with invalid config sensor: bom . Using a RPI running Hasbian with home assistant 92.1 . I have also tried the bom camera platform with the same result . Below is the code i’m using which is from the example listed . Any suggestions?
- platform: bom
monitored_conditions:
- apparent_t
- cloud
- cloud_base_m
- cloud_oktas
- cloud_type_id
- cloud_type
- delta_t
- gust_kmh
- gust_kt
- air_temp
- dewpt
- local_date_time
- local_date_time_full
- press
- press_qnh
- press_msl
- press_tend
- rain_trace
- rel_hum
- sea_state
- swell_dir_worded
- swell_height
- swell_period
- vis_km
- weather
- wind_dir
- wind_spd_kmh
- wind_spd_kt
Please format your pasted code correctly. Spacing is important.
You may also have more luck if you supply the station id (as outlined on the sensors page) rather than relying on it automatically trying to find the nearest station from the lat/lon supplied in your configuration.
e.g.
@tom_l how do you add that pic of the config animation? I am constantly telling people this, including in this thread. The animation would be good to add.
Thanks for the replies , yes I did try to format correctly for this post but just couldn’t get it right , the code i used is formatted correctly . I will have another go next time and I do appreciate the need to do so.
I did try the station ID but still the same issue , will give it another go, and if not will come back with the correct code format etc .
station
(string)(Optional)The station ID string as identified from the BOM website.
Default value: If not given, defaults to the closest station based on location data in configuration.yaml.
name
(string)(Optional)The name you would like to give to the weather station.
Here is what I have now , still "Invalid Config"
- platform: bom
station: IDT60901.94970
- apparent_t
- gust_kt
- air_temp
