thanks for all of the responses chaps. apologies for the slow reply today, The wife factor became an issue!
ok, so now i know where to look (thanks Marc), i have 2 logs for you. 1st one with node red active
2020-05-07 18:33:16 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hive which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-05-07 18:33:16 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-05-07 18:33:17 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:33:17 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
[SQL: UPDATE recorder_runs SET "end"=?, closed_incorrect=? WHERE recorder_runs.run_id = ?]
[parameters: ('2020-05-07 17:33:17.307946', 1, 137)]
(Background on this error at: http://sqlalche.me/e/4xp6)
2020-05-07 18:33:17 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
(Background on this error at: http://sqlalche.me/e/4xp6) (retrying in 3 seconds)
2020-05-07 18:33:20 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:33:20 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:20 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:23 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:33:23 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:23 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:26 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:33:26 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:26 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:27 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2020-05-07 18:33:29 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:33:29 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:29 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:32 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:33:32 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:32 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:35 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:33:35 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:35 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:38 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:33:38 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:38 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:41 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:33:41 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:41 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:44 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:33:44 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:44 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:33:44 ERROR (MainThread) [homeassistant.setup] Setup failed for recorder: Integration failed to initialize.
2020-05-07 18:33:45 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of history. Setup failed for dependencies: recorder
2020-05-07 18:33:45 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Could not set up all dependencies.
2020-05-07 18:34:10 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: recorder
2020-05-07 18:34:10 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not set up all dependencies.
2020-05-07 18:34:11 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: history, logbook
2020-05-07 18:34:11 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
2020-05-07 18:34:14 WARNING (MainThread) [aiohue.util] Received unexpected bridge id: 93eadbeef13
second one with node red turned off.
2020-05-07 18:37:42 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-05-07 18:37:42 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-05-07 18:37:42 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hive which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-05-07 18:37:42 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:37:42 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
[parameters: ('2020-05-07 17:37:42.754812', 1, 137)]
2020-05-07 18:37:42 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:37:46 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:37:46 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:37:46 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:37:49 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:37:49 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:37:49 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:37:52 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:37:52 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:37:52 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:37:52 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2020-05-07 18:37:55 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:37:55 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:37:55 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:37:58 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:37:58 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:37:58 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:38:01 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:38:01 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:38:01 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:38:04 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:38:04 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:38:04 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:38:07 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:38:07 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:38:07 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:38:10 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=137 from 2020-05-06 12:05:27.897827)
2020-05-07 18:38:10 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:38:10 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed
2020-05-07 18:38:10 ERROR (MainThread) [homeassistant.setup] Setup failed for recorder: Integration failed to initialize.
2020-05-07 18:38:12 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of history. Setup failed for dependencies: recorder
2020-05-07 18:38:12 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Could not set up all dependencies.
2020-05-07 18:38:15 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: recorder
2020-05-07 18:38:15 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not set up all dependencies.
2020-05-07 18:38:16 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: history, logbook
2020-05-07 18:38:16 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
2020-05-07 18:38:52 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 9 not ready after 30 seconds, continuing anyway
2020-05-07 18:38:52 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave entity Unknown Node 9 Level (node_id: 9) not ready after 30 seconds, continuing anyway
Burningstone, seems I did miss of the first line that shows homeassistant: full file below.
homeassistant:
latitude: 52.3xxx
longitude: -0.2xxx
unit_system: metric
time_zone: Europe/London
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
#ircontrol: !include ircontrol.yaml
zwave:
usb_path: /dev/ttyACM0
hive:
username: xxxxxxx
password: xxxxxxx
#emulated_hue:
# listen_port: 80
# off_maps_to_on_domains:
# - scripts
# - scenes
# expose_by_default: true
# exposed_domains:
# - light
# - switches
# - scripts
remote:
- platform: harmony
host: 192.168.1.xxx
- platform: harmony
host: 192.168.1.xxx
Worst case, I could roll back to my last snapshot and redo the configrations I have done since then(was probably more ālearning timeā than actual configuration). BUT, I would like to know what I have done wrong so I dont make the same mistake again.
Thanks for taking time out to assist me(tell me what I am doing!) to try and rectify this.
