Please Help try to print sensor and bianry state on nextion with more than one page
I have already made a nextion display with one page and now i try to make more with 4 pages. The button to change the page work but i can send information to nextion
Here my code
# This is ESPHome configuration file. This goes to the esphome folder
# You need to provide your WiFi ssis/password and passwords for API and OTA (or put them in your esphome/secrets.yaml)
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: xxxxxxxxxxx
password: xxxxxxxxxxxxxx
fast_connect: true
logger:
baud_rate: 0 # Disable UART logging (pins GPIO1/3 are used for Nextion communication)
uart:
rx_pin: D1
tx_pin: D6
baud_rate: 9600
api:
ota:
- platform: homeassistant # Inside salon
entity_id: sensor.netatmo_interieur_temperature
- platform: homeassistant # Inside sdb
entity_id: sensor.salle_de_bain_temperature
- platform: homeassistant # Inside parents
entity_id: sensor.sation_temperature_ambiante
- platform: homeassistant # jardin
entity_id: sensor.netatmo_jardin_temperature
entity_id: sensor.daily_energy
entity_id: sensor.daily_energy_2_kwh
entity_id: sensor.daily_power
globals:
- id: nextion_page_id
type: int
restore_value: no
initial_value: '0'
binary_sensor:
- platform: nextion
page_id: 0
component_id: 1
internal: true
on_press:
then:
- lambda: |-
id(nextion_page_id)=1;
id(display_nextion).goto_page("floor");
- component.update: display_nextion
- platform: nextion
page_id: 0
component_id: 4
internal: true
on_press:
then:
- lambda: |-
id(nextion_page_id)=2;
id(display_nextion).goto_page("page3");
- platform: nextion
page_id: 0
component_id: 5
internal: true
on_press:
then:
- lambda: |-
id(nextion_page_id)=3;
id(display_nextion).goto_page("page4");
- platform: nextion
page_id: 1
component_id: 4
internal: true
on_press:
then:
- lambda: |-
id(nextion_page_id)=0;
id(display_nextion).goto_page("home");
- platform: nextion
page_id: 1
component_id: 6
internal: true
on_press:
then:
- lambda: |-
- platform: nextion
page_id: 1
component_id: 7
internal: true
on_press:
then:
- lambda: |-
- platform: nextion
page_id: 2
component_id: 1
internal: true
on_press:
then:
- lambda: |-
- platform: nextion
page_id: 2
component_id: 2
internal: true
on_press:
then:
- lambda: |-
- platform: nextion
page_id: 2
component_id: 4
internal: true
on_press:
then:
- lambda: |-
- platform: nextion
page_id: 3
component_id: 1
internal: true
on_press:
then:
- lambda: |-
- platform: nextion
page_id: 3
component_id: 2
internal: true
on_press:
then:
- lambda: |-
- platform: nextion
page_id: 3
component_id: 3
internal: true
on_press:
then:
- lambda: |-
text_sensor:
entity_id: group.fenetre
internal: true
entity_id: group.all_lights
internal: true
display:
- platform: nextion
update_interval: 3s
lambda: |-
it.set_component_text_printf("cocon","%.1f",id(cocon).state);
it.set_component_text_printf("copro","%.1f",id(copro).state);
it.set_component_text_printf("cores","%.1f",id(cores).state);
it.set_component_text_printf("etlum","%s",id(etlum).state.c_str());
it.set_component_text_printf("etpor","%s",id(etpor).state.c_str());
it.set_component_text_printf("tepar","%.1f",id(tepar).state);
it.set_component_text_printf("tesdb","%.1f",id(tesdb).state);
it.set_component_text_printf("tesal","%.1f",id(tesal).state);
it.set_component_text_printf("tejar","%.1f",id(tejar).state);
page o object name home
page 1 object name floor
now in place of sensor i have “nan”
Can you help me ?
