Plotly interactive Graph Card
You need to use the resample filter on both so the arrays are aligned (i.e. each index points to the same date on both), and then the store_var filter on the secondary entity.
This way you can access both histories from within the filters of one.
I suggest you visit the discussions section of the repository and see the examples there. It requires some thought but it will hopefully click after that :slight_smile:
Thank you. I’ll post in the repo’s discussion board. :slight_smile:
Thanks a lot ! It works fine
This thread and the examples in it have been a huge help! Maybe I can return the favor for someone out there by sharing where I’m at with my graph of room temps and HVAC stuff.
Is there a way to limit the X-axis panning to a specific range? I’ll often end up panning or zooming to a mostly blank graph of future time.
type: custom:plotly-graph
hours_to_show: 24
refresh_interval: auto
autorange_after_scroll: true
defaults:
  entity:
    show_value: false
    line:
      width: 2
    yaxis: 'y'
  yaxes:
    fixedrange: true
entities:
  - entity: sensor.temp_sensor_1_temperature_2
    line:
      color: green
  - entity: sensor.temp_sensor_2_temperature_2
    line:
      color: dodgerblue
  - entity: sensor.temp_sensor_3_temperature_2
    line:
      color: chocolate
  - entity: sensor.temp_sensor_5_temperature_2
    line:
      color: 8F54D3
  - entity: sensor.temp_sensor_4_temperature_2
    line:
      color: gold
  - entity: climate.alarm_com_smart_thermostat
    attribute: current_temperature
    unit_of_measurement: °F
    line:
      color: lightgray
      width: 1
    opacity: 0.6
    attribute: target_temp_low
    line:
      color: red
      dash: dot
      width: 1
    opacity: 0.6
    attribute: target_temp_high
    line:
      color: blue
      dash: dot
      width: 1
    visible: false
    attribute: hvac_action
    filters:
      - map_y: 'y === "heating" ? 150 : 0'
    yaxis: y2
    fill: tozeroy
    fillcolor: rgba(255, 99, 71, 0.3)
    line:
      color: tomato
      width: 0
    filters:
      - map_y: 'y === "cooling" ? 150 : 0'
    yaxis: y2
    fill: tozeroy
    fillcolor: rgba(4, 90, 150, 0.2)
    line:
      width: 0
  - entity: sensor.openweathermap_temperature
    yaxis: y2
    fill: tozeroy
    fillcolor: rgba(200, 200, 200, 0.15)
    line:
      color: white
      width: 0
layout:
  margin:
    t: 50
    l: 15
  showlegend: false
  legend:
    x: 0.1
    'y': -0.8
  yaxis:
    side: right
    tickfont:
      color: lightgray
    autorange: true
    showgrid: true
  yaxis2:
    side: left
    visible: false
    overlaying: 'y'
    tickmode: sync
    range:
      - 0
      - 150
  xaxis:
    tickangle: 0
    tickfont:
      color: lightgray
    tickformat: |-
      %I%p
      %b %d
    hoverformat: '%I:%M%p'
    rangeselector:
      bgcolor: rgba(0,0,0,.45)
      x: 0.01
      'y': 0.03
      buttons:
        - count: 12
          step: hour
        - count: 18
          step: hour
        - count: 24
          step: hour
        - count: 36
          step: hour
        - count: 72
          step: hour
  annotations:
    - text: |-
        $fn ({hass}) =>
          "<span style='font-size: 24px;'><span style='color: green'>"
          + Math.round(hass.states['sensor.temp_sensor_1_temperature_2'].state) + "</span></span>ĀŗF<br>"
          +  "</span><span style=''>Bedroom</span><br>"
      xref: x domain
      yref: y domain
      xanchor: center
      yanchor: center
      x: 0.06
      'y': 1.3
      showarrow: false
    - text: |-
        $fn ({hass}) =>
          "<span style='font-size: 24px;'><span style='color: dodgerblue'>"
          + Math.round(hass.states['sensor.temp_sensor_2_temperature_2'].state) + "</span></span>ĀŗF<br>"
          +  "</span><span style=''>MBR</span><br>"
      xref: x domain
      yref: y domain
      xanchor: center
      yanchor: center
      x: 0.27
      'y': 1.3
      showarrow: false
    - text: |-
        $fn ({hass}) =>
          "<span style='font-size: 24px;'><span style='color: chocolate'>"
          + Math.round(hass.states['sensor.temp_sensor_3_temperature_2'].state) + "</span></span>ĀŗF<br>"
          +  "</span><span style=''>Front Office</span><br>"
      xref: x domain
      yref: y domain
      xanchor: center
      yanchor: center
      x: 0.51
      'y': 1.3
      showarrow: false
    - text: |-
        $fn ({hass}) =>
          "<span style='font-size: 24px;'><span style='color: #8F54D3'>"
          + Math.round(hass.states['sensor.temp_sensor_5_temperature_2'].state) + "</span></span>ĀŗF<br>"
          +  "</span><span style=''>Playroom</span><br>"
      xref: x domain
      yref: y domain
      xanchor: center
      yanchor: center
      x: 0.75
      'y': 1.3
      showarrow: false
    - text: |-
        $fn ({hass}) =>
          "<span style='font-size: 24px;'><span style='color: gold'>"
          + Math.round(hass.states['sensor.temp_sensor_4_temperature_2'].state) + "</span></span>ĀŗF<br>"
          +  "</span><span style=''>Living Room</span><br>"
      xref: x domain
      yref: y domain
      xanchor: center
      yanchor: center
      x: 0.99
      'y': 1.3
      showarrow: false
I’ve just installed Plotly and it seems to be doing exactly what I want.
I must admit that I’m not really sure where to get the documentation for it other than looking at the example and guessing.
Anyway, I have managed to get my gas usage plot by month with the following yaml:
entities:
  - entity: sensor.daily_gas_consumption
    type: bar
    statistic: sum
    period: month
    texttemplate: '%{y}'
    filters:
      - filter: x < new Date(Date.now() - 1000*60*60*24*31)
    type: bar
    statistic: sum
    period: month
    filters:
      - filter: x > new Date(Date.now() - 1000*60*60*24*31)
refresh_interval: 30
hours_to_show: 6M
layout:
  xaxis:
    rangeselector:
      'y': 1.2
      buttons:
        - count: 1
          step: month
        - count: 3
          step: month
        - count: 6
          step: month
and it works well (although much of it is copied without full understanding).
However when I change the button to (say) 1 month, it would be great if I could somehow change the ā€˜period’ to be ā€˜week’.
Is there a way?
Susan
Happy to hear you find it useful!
There’s a way, see GitHub - dbuezas/lovelace-plotly-graph-card: Highly customisable Lovelace card to plot interactive graphs. Brings scrolling, zooming, and much more!
The period can be set to auto or custom ranges for each period can be defined
Hello everyone - having trouble with the color scheme of the card itself.
By default the card background is black
If I add
layout:
paper_bgcolor: transparent
plot_bgcolor: transparent
I get this
I want the card on the right to use the same color scheme (driven by theme) as the card on the left here for illustration purposes.
Can someone help ?
Thanks !
Try rgba(0, 0, 0, 0.3) instead of transparent
Thank you - much better !
How about formatting the legend so it does not hide under the buttons (1h, 1d, 7d) and also changing the styling of those, black font for instance to improve visibility ?
Thank you so much :slight_smile:
found it :slight_smile:
added in layout section
legend:
y: 1.5
This card is absolutely amazing! Using it a lot for visualizing energy long term statistics.
Long term statistics are updated every 5 min during the HA recording period (10 days in my case). After the recording period, longterm statistics are kept standard on an hourly period.
I don’t know if it’s possible, but is there any way to show the long term statistics for a 5 min period for as long as the 5 min period data is available and then seamlessly move over to the 1 hour period data as soon as there is no 5 min period data available anymore?
Now I need to choose:
A combination of both would be great :slight_smile:
Happy to hear you’re putting it to good use!
You can indeed do that:
  • Add a trace with the recent history, but set it as internal and store it with a store_var filter
  • Add a trace with the 5 minutes statistics also set as internal. Using a a filter filter remove all data whose x is greater or equal than the first x val of the first trace. Then append both xs and ys using the fn filter and store it back to a var
  • Repeat with the hourly statistic but don’t set it to internal
Alternatively, look into period: auto
first, thanks for this great card. Fast, and feature-rich!
second, I have a small issue: When restarting home assistant, then the curves shown by plotly have a gap for that period. Typically this gap is small, but for values which do not change often (e.g. a setvalue for a temperature), the gap is really big, and it is almost impossible to see the curve for this value.
The normal ā€œHistory graph Cardā€ does not have this behaviour. Of course, this can be seen also as a feature of the plotly card, but I would need the behaviour of the history graph card with the plotly card.
My Yaml configuration looks like this:
refresh_interval: 100
hours_to_show: 24
layout:
  height: 800
  xaxis:
    rangeselector:
      'y': 1.2
      buttons:
        - count: 6
          step: hour
        - count: 1
          step: day
        - count: 7
          step: day
        - count: 1
          step: month
entities:
  - entity: sensor.esp32_soundroom_bathroomtempsensor
  - entity: sensor.esp32_soundroom_soundroomtempsensor
  - entity: number.esp32_soundroom_bathroomtempsetvalue
  - entity: number.esp32_soundroom_soundroomtempsetvalue
And this is how the graph looks like with the gap (esp. the green and the red curves, the set values), you can also see the standard card (only one of the two setvalues is visible there):
Did I miss any configuration? How could I solve this?
Thanks a lot,
Klaus
P.S.: If needed, here is the configuration of the standard card:
type: history-graph
entities:
  - entity: binary_sensor.esp32_soundroom_leadingroombathroom
  - entity: binary_sensor.esp32_soundroom_heatingon
hours_to_show: 10
Thanks for the kind words!
Try the force_numeric filter.
Alternatively, I think you can set connections: true in the entity
What am I missing? I received an email, about a ā€œScreek Workshopā€, which lead me this Plotly interactive Graph Card. Liked what I was reading, and decided to install this Plotly Graph Card.
I am running HA and HACS which are both up-to-date, but when is search (in HACS) for ā€œPlotly Graph Cardā€. I get as far as ā€œPloā€ when I get the message, ā€œNo Repositories foundā€ .
What did I miss?
Found my mistake, I was searching in the Integration section, should have been in the Frontend section.
Thanks a lot, force_numeric did the job!
Has anybody an idea how to do a barpolar chart for wind direction?
I’ve tried a few things but as a rookie don’t know where to get started and the documentation has absolutely nothing in this respect.
That should be possible, what do you have in mind?
Can you make a pen and pencil drawing and show what the data looks like and what exactly you want to visualize
I suspect the OP is after a windrose card, this may meet his need although it would be good to solve the issue using plotly, one less integration to load into HA…
